63 brakes
jesus_chrysler
jesus_chrysler is offline
PostPosted: Fri Apr 08, 2011 2:47 pm    Post subject: 63 brakes Reply with quote
I have an early 63 single cab. It has the newer front brakes from what I can tell so far. They match the brakes off a 66 beam I have.
I am trying to order new brakes for the rear. How can I tell if it had the pre or post 63 brakes? Whats the difference?
My collection:
58 beetle rag top
63 Single cab
67 11 Window
70 Charger 440
76 Kawasaki H1 triple 2stroke
71 Yamaha R5
06 Chopped HD
tpinthepack
tpinthepack is offline
PostPosted: Fri Apr 08, 2011 3:00 pm    Post subject: Reply with quote
you need to look at the rear drum diameter, or the axle nut actually. The later brakes are like 250mm drum, and the early ones are around 230mm. The dead giveaway is the 36mm nut for early, and the 46mm nut for late. There is some rare others, so just measure the drum diamether to be safe. Pictures work really well on the samba also.
Tony P
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1990 Doka WBX 2.1
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon CARAT
2007 Rabbit
2007 Passat Wagon 3.6 VR6
jesus_chrysler
PostPosted: Fri Apr 08, 2011 3:33 pm    Post subject: Reply with quote
Well I must have one of those bastard setups. Its a 36mm nut with 250mm dia drums. Are these drums valuable? 211 501 615B drums?
So would the 64up shoes be right?
My collection:
58 beetle rag top
63 Single cab
67 11 Window
70 Charger 440
71 Yamaha R5
06 Chopped HD
Campy
Campy is offline
PostPosted: Fri Apr 08, 2011 5:46 pm    Post subject: Reply with quote
My 1963 camper had a 1967 transaxle with the one year only 1963 one ton RGBs (one year only brake drum) and the 1963 frontend with the odd front drums, so I put big stub axle RGBs on the rear and a 1964-1967 frontend on it. The 1963 drums are a pain in the butt to find.
Don't worry; be happy. (Baba)
jesus_chrysler
PostPosted: Fri Apr 08, 2011 6:01 pm    Post subject: Reply with quote
Well my 63 has a bent trailing arm. stupid PO bent it with a winch i think. I got a 66 beam for the front. I am going beetle IRS in the rear with the bus brakes.
So would the '64-'67 shoes work?
My collection:
58 beetle rag top
63 Single cab
67 11 Window
70 Charger 440
71 Yamaha R5
06 Chopped HD
PostPosted: Fri Apr 08, 2011 11:10 pm    Post subject: Reply with quote
If you have the "wacky" 63-only 1-ton setup, it takes the later brakes.
Campy
Campy is offline
PostPosted: Fri Apr 08, 2011 11:30 pm    Post subject: Reply with quote
Now I remember that I installed the later model frontend on my 1963 bus so there would be thicker link pins.
