Would coolant leaking ONTO exhaust ruin O2 Sensor?
SCM
SCM is offline
PostPosted: Fri Apr 15, 2011 8:53 am    Post subject: Would coolant leaking ONTO exhaust ruin O2 Sensor? Reply with quote
It seems strange to me that my O2 Sensor would go bad with only a few thousand miles on it. And it also seems like a big coincidence that it would go bad the day after I replaced my coolant expansion tank.
I still need to check the wiring coming from the sensor - but is it possible that coolant spraying out of the tank could have entered the exhaust through some leaks (I have at least 2 bad exhaust gaskets) and fouled the sensor?
'91 Westfalia GL Automatic
2.3L GoWesty Engine
fastwagens
fastwagens is offline
PostPosted: Fri Apr 15, 2011 9:08 am    Post subject: Reply with quote
Chances are slim but you never know. The 4 wire u2 sensors have a heated element to burn off debris from the sensor but that came out after vans.
wbx
wbx is offline
PostPosted: Fri Apr 15, 2011 9:54 am    Post subject: Reply with quote
I thought the 4th wire was just a dedicated ground wire? 3 wire O2 sensors also have the heater, but there is no control over them in the vanagon other than on or off, AFAIK.
-Damon
'84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go.
6984vwvanagon
6984vwvanagon is offline
PostPosted: Fri Apr 15, 2011 10:27 am    Post subject: Reply with quote
For what it's worth Fords use Bosch O2 sensors, and
we have seen coolant contaminate them.
84 Vanagon GL van "Horst"
69 Beetle (sold)
73 Beetle (sold, darn it!)
"Ain't this some beautiful mess." - Dude Watson
psych-illogical
psych-illogical is offline
PostPosted: Fri Apr 15, 2011 10:34 am    Post subject: Reply with quote
I'm curious as to why an O2 sensor would need a heater. It's hard to imagine that any 12v heating element could get the exposed element of the sensor hotter than the 1000+ degree environment that it is constantly bathed in.
83 1/2 Westy waterboxer
'57 Beetle-sold Sad
Coupla '81 BMW motorcycles (R80G/S; R100RS)
'96 BMW R1100GS
wbx
wbx is offline
PostPosted: Fri Apr 15, 2011 11:10 am    Post subject: Reply with quote
At extended idle conditions with the O2 sensor fairly downstream from the mainfolds, it can cool off enough to be unresponsive (IIRC, activation temperature is around 600-650F). During extended idle, my exhaust is around the low 500s at the cat where my O2 sensor is located.
Also, when going down a long hill, the engine is just pumping cool air (shuts off the injectors) which will cool the sensor very quickly and will take some amount of time (not much) to get back to temp.
The heated sensor is just an optimization and not critical to function, but as emissions controls have tightened up over time, these optimizations have become increasingly necessary.
xoo00oox
xoo00oox is offline
It is very common-
This is the only sensor that makes its own voltage. The voltage signal is proportional to the amount of unburned oxygen in the exhaust. When hot (at least 600. F), the zirconium dioxide element in the sensor's tip produces a voltage signal that varies according to the difference in oxygen content between exhaust and out side air .
They need reference air to work, taken from where the wires go in.
They need a heater to get working quicker.
SCM
SCM is offline
PostPosted: Fri Apr 15, 2011 11:21 am    Post subject: Reply with quote
[quote="xoo00oox"]They need reference air to work, taken from where the wires go in.
[quote]
Does it sound reasonable that coolant could have dripped/sprayed onto the part where the reference air is taken in and messed something up?
I appreciate the insight folks are giving about why the sensors are heated etc but more importantly I'm trying to figure out if there's some reason (beside coincidence) that a new sensor would go bad simultaneously with a coolant leak from the expansion tank occuring and then being fixed.
2.3L GoWesty Engine
SCM
SCM is offline
PostPosted: Fri Apr 15, 2011 11:23 am    Post subject: Reply with quote
Did it happen pretty quickly (in a few days) or was it after a longer period of contact with the coolant?
2.3L GoWesty Engine
xoo00oox
xoo00oox is offline
PostPosted: Fri Apr 15, 2011 11:30 am    Post subject: Reply with quote
......if you have a wbx, your coolant tank is right above the O2 sensor. It is know to happen from oil or antifreeze leaking on them. It can happen right away.
