Fuel pump relay
FDtoWesty
FDtoWesty is offline
PostPosted: Sun May 19, 2013 4:10 pm    Post subject: Fuel pump relay Reply with quote
Happy Sunday to all.
I have a few question for you guys. Some of you may know that I've been slowly working to get my '73 Bus back to life, it's a '73 manual with '78 2L Auto F.I. motor.
First, can I used the F.I Auto ECU to run my bus which is a manual, it also came with a smaller Decel valve, not the pancake looking one, will I still be able to use this Decel valve?
I have the complete ECU and wiring harness minus the fuel pump relay to fuel pump harness, can I hook up my fuel pump using the diagram from Ratwell's site.
Relay: 85 to ground
30 to positive battery with fuse.
86 to starter 50
87 to fuel pump power
This should get my Bus running?
