Maxdog2 Samba Member
Joined: August 06, 2009 Posts: 206 Location: Grand Junction, Colorado
Posted: Fri Apr 22, 2011 8:47 pm Post subject: Broken fuel pump pedestal |
I’m in the process of trying to replace any gasket possible while the engine is out to prevent future leaks. Today I broke the fuel pump pedestal off down inside the case. Has anyone ever done this and if so how did you get the remaining plastic out? Thanks |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Fri Apr 22, 2011 8:59 pm Post subject: |
Tap it. Deep, then pull the tap out _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Fri Apr 22, 2011 9:02 pm Post subject: |
Thanks, makes sense and I will do just that. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
mark tucker Samba Member
Posted: Sat Apr 23, 2011 7:21 am Post subject: |
turn the car up side down??fish it out with a wire, shop vac, or try the above. |
Posted: Sat Apr 23, 2011 3:07 pm Post subject: |
Got it out!!!
VIN Samba Member
Posted: Sat Apr 23, 2011 7:14 pm Post subject: |
big ass sheet metal screw, good call. ive pulled many seals out with washers and screws |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Apr 24, 2011 4:21 am Post subject: |
What I use is a paint can opener........ _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Apr 24, 2011 12:20 pm Post subject: |
I have one of those, but never thought of that. Thanks |
Posted: Sun Apr 24, 2011 12:23 pm Post subject: |
so you didnt try turning the car up side down?rats.gladd you got it out with out any problem. |
Posted: Sun Apr 24, 2011 12:54 pm Post subject: |
I would have, but sure wanted to try other options first. |
tikitime Samba Member
Joined: December 12, 2006 Posts: 443 Location: New Westminster, BC, Canada
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Mon Apr 25, 2011 8:20 am Post subject: |
tikitime wrote: |
mark tucker wrote: |
I guess that's what them thar rotiseries are for! |
The car is easier to shake back and forth when it's on the rotisserie. |
oarse Samba Member
Joined: August 21, 2009 Posts: 530 Location: Washington DC
Posted: Mon Apr 25, 2011 9:23 am Post subject: Re: Broken fuel pump pedestal |
Nice work. It's a good thing it stayed in one piece. |
johnR Samba Member
Joined: August 25, 2009 Posts: 668 Location: Virginia
Posted: Mon Apr 25, 2011 9:28 am Post subject: |
Same thing happened to me and I got lucky same as you. A big old lag bolt screwed in just enough to pull it out without breaking. Phew! |
Posted: Mon Apr 25, 2011 3:01 pm Post subject: |
Started with a tap, but the ones I had were either too small or a little too big. The large one put just a few small shavings inside and I was able to vaccum them out. I feel very lucky. |
