BrainFartHeadache Samba Member
Posted: Sat Apr 23, 2011 8:06 pm Post subject: Fan shroud lever? |
There is a small lever on the lower right of the shroud, behind the intake runner, and looks to have a cable attached to it at one time. I assume this helps cool the engine, so without being hooked to a cable, which way should the lever go for best cooling? What should this be hooked up to? _________________ Every time i do this.....THAT happens!
68 beetle |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55841 Location: Long Island, New York, USA
Posted: Sat Apr 23, 2011 8:08 pm Post subject: |
It connects via a cable to a valve on the air cleaner that controls if the engine gets cold air or warm air to the carb.
Do not mess with it because if it jams closed the thermostat will not open the flaps in the shroud and you can cook your engine. _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 2754 Location: 37.54N 77.18W
Posted: Sun Apr 24, 2011 6:00 am Post subject: |
| Quote: |
| Do not mess with it because if it jams closed the thermostat will not open the flaps in the shroud |
Just use it as an indicator that the flaps are moving. Cold, lever points one way. Hot, lever points other way. _________________ *DISCLAIMER* What you see might not be what I typed! |
sxuxrxf  Samba Member
Joined: May 18, 2005 Posts: 1133 Location: Oceanside, CA
Posted: Sun Apr 24, 2011 7:23 am Post subject: |
Lever leaning to the right means flaps are open and cooling the engine.
Lever more straight up means closed. _________________ (ignore the X's )
Volker Rader Klub
Join us Saturday nights at IN-N-OUT on Hwy 76 and Frazee in Oceanside.
West Coast Bays |
Posted: Sun Apr 24, 2011 11:54 am Post subject: |
Thanks, it is leaning to the right so now i won't "test" which way works better, and just leave it alone. _________________ Every time i do this.....THAT happens!
68 beetle |
jtgh Banned
Posted: Tue Jun 07, 2011 7:37 pm Post subject: |
your lucky, mine has missing thermostat.
so goes nowhere.
flops at random.
im hooking up a remote cable to min, with cold start label.
PO lost my STAT. _________________ nobody. |
