installing empi trigger shifter
Squashcar67
Squashcar67 is offline
PostPosted: Sat Apr 23, 2011 11:56 pm    Post subject: installing empi trigger shifter Reply with quote
I'm trying to adjust my new EMPI trigger short shifter and its giving me problems. I can find reverse 3/4 fine. I can't get it into 1/2 unless i pull the trigger. I don't want to get this wrong and shift into reverse and grind away while shifting into 2nd gear Shocked are there any trick's to adjusting this trigger shifter?
bill may
bill may is offline
PostPosted: Sun Apr 24, 2011 7:01 am    Post subject: Reply with quote
i believe someone posted original literature that came with a hurst trigger shifter. it would be nice to find it as it is on samba.
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
rat70fj
rat70fj is offline
PostPosted: Sun Apr 24, 2011 9:38 am    Post subject: Reply with quote
http://www.thesamba.com/vw/archives/manuals/hurst_saf_t_trigger_shifter.php
edlutzenberg
edlutzenberg is offline
PostPosted: Sun Apr 24, 2011 10:00 am    Post subject: Reply with quote
Hey bro, I have the exact same problem with what is probably the same shifter. Im not sure if it is because the pattern is so short and tight that I haven't got used to it yet or if there actually a problem.I have done a lot to this lil car over the winter and haven't put any miles on it yet to work out the bugs. (pun intended). If I don't figure it out I will try the the stock shifter again with the $5.00 short shift kit. Also make sure the little cage and bushing under the back seat are new and put synthetic oil in your trans. Good luck-Ed
Squashcar67
PostPosted: Sun Apr 24, 2011 10:17 am    Post subject: Reply with quote
yeah it just seems realllllly finicky. Thank you for the INSTRUCTIONS!!!! I'm gonna check the bushing/linkage and try again this morning. We'll see how it goes. Think i'll try putting it in first gear and snugging up a bit, then getting reverse adjusted in and working right 3/4 should fall into place. VW Logo
Squashcar67
PostPosted: Sun Apr 24, 2011 10:52 am    Post subject: Reply with quote
bushing on tube is non even there!!!!! and the cage has a bit of slopp in it Off to vee parts for linkage bushing's etc. On my way we'll test drive a MINI coop S we've had our eye on. Pray
