2055fasty Samba Member
Posted: Sat Apr 23, 2011 6:00 pm Post subject: Pops out of 1st |
Hey guys does any 1 know what would couse first gear to pop out Can some one help it's 64 thanks guys |
jamesvw209 Samba Member
Joined: March 23, 2011 Posts: 83 Location: sonora california
Posted: Sat Apr 23, 2011 6:13 pm Post subject: |
your clutch may need adjusting. mine was popping out of second especially going down hill letting off the gas, tightened up the clutch and it does not do it anymore. is it hard to put in gear? does it grind putting it in reverse? these are signs of your clutch needing adjusting. just put the car on some jackstand get under the car and on your transmission theres a lever and on the lever is your clutch cable and wing nut you just adjust with your hand take some liquid wrench with you mine needed it. |
Posted: Sat Apr 23, 2011 9:44 pm Post subject: |
Dude yea it does grind and all that I am going to do that tomorrow morning thanks for your help |
Posted: Sat Apr 23, 2011 10:49 pm Post subject: |
ya adjust it to where you are getting a half inch to an inch free play in your clutch pedal. |
6Kabrio7 Samba Member
Joined: July 22, 2006 Posts: 2387 Location: California
Posted: Sat Apr 23, 2011 11:17 pm Post subject: |
You need a transmission i'd say. _________________ 67 Convertible July 67 Yukon Yellow
67 Sedan May 67 Zenith blue |
Posted: Sun Apr 24, 2011 10:19 am Post subject: |
ya of course you would say that everybody on here says the worst possible senario at first like ohh my car is idling wrong (oh no got replace the engine because the valves are stuck or some shit like that) my point being dont take everybodys opinion to heart on the samba cause some guys on here will tell you some crazy shit wrong with your car and you will go out buying new parts when all you needed to do was do a little adjusting, or timing or something really small and simple almost every case and senerio I have ran into was usually something easy or small. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32432 Location: Reading Pennsylvania
