galaxie065 Samba Member
Posted: Sun Sep 05, 2010 7:03 pm Post subject: Altenator |
I just installed an altenator of 65 which I am converting to 12 v. It looks like this altenator has an internal voltage regulator. It has 4 connection. my question is does anyone has a wiring diagram for this type of altenator? |
microbus Samba Member
Joined: October 12, 2007 Posts: 527 Location: Alberta, Canada
Posted: Sun Sep 05, 2010 7:19 pm Post subject: |
An internally regulated usaully has 2 connections, 8mm screw is battery/push on connector is dash bulb! _________________ Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician |
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Mon Sep 06, 2010 2:37 am Post subject: |
Yeah, if you have a 3-terminal plug plus a separage 8mm stud, then you have an externally regulated alternator. Does it look something like one of these?
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Mon Sep 06, 2010 4:34 am Post subject: |
And BTW....alternator has 2 r's in it. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Mon Sep 06, 2010 10:56 am Post subject: |
glutamodo wrote: |
Thanks it does. I need a regulator |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Mon Sep 06, 2010 11:48 am Post subject: Re: Altenator |
galaxie065 wrote: |
73 or 74 beetle?. external regulator for this motorola alternator is no longer in service/ availible.. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76904 Location: Sneaking up behind you
Posted: Mon Sep 06, 2010 12:09 pm Post subject: Re: Altenator |
bill may wrote: |
73 or 74 beetle?. external regulator for this motorola alternator is no longer in service/ availible.. |
Bill,
The Motorola regulator works with a Bosch alternator so i'd assume the Bosch regulator will work with the Motorola regulator. _________________ Glenn
Member #1009
#BlueSquare |
oldvolkz Samba Member
Joined: September 28, 2005 Posts: 321 Location: Hollister, Califaztlan
Slow Steve Samba Member
Joined: October 23, 2008 Posts: 715 Location: Midlothian, VA
Posted: Mon Jan 24, 2011 10:49 pm Post subject: |
I have done this same alternator/reg combo twice now. It needs an external regulator. Autozone has them for $29.99, just ask for a regulator. Part #VR650. It's the same 12v reg for alternator for any bug 68 and up, I even think it's the same for bay buses.
Here is how you wire it:
Just cut the plug off the end of the regulator and wire it to the alternator(starting from right) red, brown, green to the corresponding colors on the reg. And DONE! _________________ BarryL wrote:
100 years from now when they have reverse atom regeneration attractor technology perfected and in a hand held back yard mechanic's price range, someone will dig up this thread and go, "What were those guys thinking? The whole thing was all there just waiting to be re-atomized. Funny how easily they cut them up back then."
___________________
74 911
72 914
65 13w Deluxe
60 Ragtop |
Posted: Tue Jan 25, 2011 7:26 am Post subject: |
bill may wrote: |
thanks for showing part number and hook up for this alternator. most now adays are the 2 wire internal regulator. |
No problem Bill. I appreciate all the info and help I get on here, so when I have a chance to help out I do. I know being on here has made my life a little easier, so I try to do the same for others. _________________ BarryL wrote:
___________________
74 911
72 914
65 13w Deluxe
60 Ragtop |
dbelkhart Samba Member
Posted: Sun May 01, 2011 8:41 pm Post subject: |
Just wanted to double check before I do this. I also have a rebuilt 1600 dp that I have installed in a 67'. Wired up most of everything except for the alternator. The engine came out of one of my 74'. The alternator/Generator looks like the one in the pics in this post. How can you tell if you have an interal/external regulator? Pleaase confirm If I need the part number mentioned in this post and where should I mount the regulator? Also according to the wie drawing in this post can I bypass the starter solenoid and go direct to the battery?
Thanks for the replies. _________________ Banging on all four cylinders.... |
Posted: Sun May 01, 2011 8:54 pm Post subject: |
Internally regulated alternator have two connections on top - one push-on and one bolt-on. Externally regulated alternators have 4 connections, one bolt-on and three push-on terminals in a "U" shape for a for a round plug to fit onto. More examples:
-Andy
Posted: Sun May 01, 2011 8:58 pm Post subject: |
Yep, looks to be the last external one. I seen the wiring diagram that was drawn up. The auto zone regulator will work fine? _________________ Banging on all four cylinders.... |
Posted: Mon May 02, 2011 5:22 am Post subject: |
If I have the external regulator from a 74' can I use that instead of the aftermarket one from Autozone? _________________ Banging on all four cylinders.... |
Posted: Mon May 02, 2011 8:00 am Post subject: |
What brand is this 74 regulator - Motorola or Bosch? |
Posted: Mon May 02, 2011 4:18 pm Post subject: |
It is a motorola and I believe it is the one that was used with the engine I have installed now when it was in my 74. _________________ Banging on all four cylinders.... |
Posted: Mon May 02, 2011 5:37 pm Post subject: |
Use it! |
Posted: Mon May 02, 2011 5:38 pm Post subject: |
Will do and thanks. _________________ Banging on all four cylinders.... |
