Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Jul 14, 2011 6:33 pm Post subject: |
Max Welton wrote: |
Here is one of the original inner bushings.
Max |
Did you replace the inner bushings? (The brownish red Bakelite part)
Where did you find the grease seals? |
mxracer Samba Member
Posted: Fri Jul 15, 2011 8:56 am Post subject: |
Max,
Those o-rings are "thrust rings" that cushion axial play. If you look at the first paragraph in section 8.1, Chapter 7 of the Bentley is speaks specifically to them and they are the main reason for checking end play every 6K miles.
If you checked/adjusted the drivers side to make sure the retaining bolt was in the indent and is holding fast then followed the procedure in the Bentley you should be good. I just went thru my front end a while ago (didn't go as far as you though) I had similar thoughts (if I'm understanding your question right). Once I adjusted it felt tight with me rotating the trailing arm but once on the ground and the suspension "worked" a couple of times it was apparent it was right. |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Fri Jul 15, 2011 11:50 am Post subject: |
ataraxia wrote: |
I'd recommend trying to find VW OEM seals like the one's Max is using. The aftermarket ones don't have the metal ring inside that keeps them rigid at the base.
I found these:
http://bugcity.com/shop/shop.htm?pquery=131405129 |
supaninja Samba Member
Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Sun Jul 17, 2011 6:56 pm Post subject: |
So, to re-cap...
You re-used the needle-rollers.
The ISP kit includes bushes to replace the rollers,
But you chose not to do that.
Randy Bowen used the inner bushes from the ISP kit.
He pressed (drove?) out the old inners,
and pushed in the new ones to the correct depth.
Then reamed them to the correct size...
Correct?
Just checking to see exactly how it went.
Did you get a good feel for the play, and/or freedom of movement before and after?
Dag, I'm about to go all the way out to Colorado to get this done! _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Sun Jul 17, 2011 7:34 pm Post subject: |
Correct all the way.
I also replaced the steering box with one from a 69. It felt smoother and adjusted up nice.
The amount of play in the beam seemed like quite a bit before tear-down. I could both feel and hear it when going over bumps. When I got the beam off the car I could reproduce the clunking sound by bumping the trailing arm with the heal of my hand.
The lower left arm was pretty chewed up as you can see in the picture. Luckily I had a nice one from the same 69 that donated the steering box.
I brought Randy the stripped beam and the best of the trailing links I had. Randy sourced the bushing and seal kits from ISP and did the hard work on the beam. He wound up moving the lower ball joint from the torn-up lower left to the good one and giving me back the re-fit beam and 4 good trailing links to reassemble.
Oh yeah. I hadn't been able to get the upper shock bolts out of the beam. Randy took care of that too. Said he had that thing cherry red with the torch.
So there's some minor work to do with the rear spring plates and then it's off to Rex Tire.
I'm pretty happy with it at this point.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Sun Jul 17, 2011 8:41 pm Post subject: |
You bought a *kit* from ISP West? Do you have a link? I searched their site and found the individual parts but no *kit*. Looks like they're out of stock on one of the bushings right now.
I'm going to build up a front end for my pan off resto and am interested in this process. Maybe I'll send my front end out West...
Thanks in advance! |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Mon Jul 18, 2011 7:09 pm Post subject: |
I am more interested in the seal then anything else, not that my seals are bad but would be nice to change them while I clean it all up and overhaul the steering and spindle components.
Should I try ISP for NOS seals? late model of course. |
Posted: Mon Jul 18, 2011 10:37 pm Post subject: |
Quote: |
Upper bushes inner and outer made in Delrin
Lower outer needle roller bearings
OK, now I'm good and confused...
Aren't there inner bushings on all four trailing arms?
Inners - bushings
Outers - rollers
Both top and bottom.
People are making bushes for the top outers, because they are rare.
The outer bottom rollers are Beetle items, so easier to get...
Right???
Is there a reason why T3D is not selling lower inner bushings?
ISP sold four inners, right?
??? _________________ Bus Motor Build
Posted: Tue Jul 19, 2011 5:34 am Post subject: |
Clatter wrote: |
Inners - bushings
Outers - rollers
Right???
The bulk of the 'beating' that a T3 front end takes is on the lower bearings...those are normally pretty worn out.
I think I'm going to replace all four top and the two inner with Delrin and replace the lowers with rollers. Seam seal the beam, clean it up and put it back together with new parts.
Thanks for the information, Max...I've been out of this game for a long time and things have definitely changed. |
vlad01 Samba Member
Posted: Fri Oct 14, 2011 3:43 am Post subject: |
ataraxia wrote: |
Max Welton wrote: |
Max |
Those inner metal bushings? how hard are they to replace? They are the bit that does the wearing on the inner bushing set. |
