vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Mon Oct 24, 2011 3:29 pm Post subject: |
Another question? can the needle bearings be removed without damaging them and be reused, or do I need to buy NOS set of them?
Both of my beams have perfect bearing but I just want to replace the inner bushings as they seem to wear 10 times the rate at which the bearings do.
one has 46k on it, the other has about 20-25k on it from memory but one bent control arm so I wont use that bearing nor the beam just in case, though it still looks feels and seem to work perfect with a new control arm. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
69sback Samba Member
Joined: March 06, 2010 Posts: 216 Location: Somewhere
Posted: Tue Feb 10, 2015 4:35 pm Post subject: |
I'm about to start this job myself. After pulling the upper torsion arms, the ends of the arms were beat up pretty bad with some definite play in the arm when installed. So the inner bushings are shot. The outer needle bearings are fine.
I bought the ISPwest bushing replacement kit and hope to install it this spring sometime. I'd like to replace just the inner bushings as the needle bearings are ok. However, to remove the inner bushings, or rather install, I definitely need to remove the needle bearings. I'd hate to just destroy them in the process, so I'm going to try something like this tool here:
http://www.harborfreight.com/blind-hole-bearing-puller-95987.html
It expands to fit the inner diameter of the bearing, the lip catches, and then the slide hammer will pull it out. I'm hoping this will save my needle bearings.
And for the reaming job required on the inner bushings once installed, harbor freight also sells a cheap reamer <$100.
if all goes well, i'll start refurb'ing type 3 beams for a living and quit my day time job
PS. does anyone know the inner diameter of the upper needle (outer) bearing? I'd like to make sure the blind hole puller will work before I buy it. I fear the bearing might be too big...
Thanks |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Feb 11, 2015 11:02 am Post subject: |
I think it was Salty in Australia that was machining new bushings/pullers etc for his car & to sell/rent? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vlad01 Samba Member
Posted: Wed Feb 11, 2015 9:34 pm Post subject: |
I seen these little beauties on fb the other week.
asked the guy if he was planing to make them for others. currently testing them for a year to see how they wear.
_________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Feb 12, 2015 7:14 am Post subject: |
Looks like a decent solution. |
stretch521 Samba Member
Joined: December 16, 2014 Posts: 16 Location: McMinnville
Posted: Thu Feb 12, 2015 12:38 pm Post subject: |
Awesome info!! and great pics!! |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Sun Apr 19, 2015 4:23 pm Post subject: |
Max Welton wrote: |
Back to the upper arm question ... having followed Bentley it seems to me that those o-rings are now acting as thrust bearings, preventing axial movement of the upper trailing arms.
It looks and reads like it's supposed to be like that. But it does seem strange to me.
Here's a before and after:
Max |
I was looking at the Bentley today and from what I read the upper left arm has a thrust ring that wears and takes the load and you adjust the right upper arm bolt in the center of the upper arm to take up the play .
I did it a few times .
I have never had my front beam apart . I lube the 4 fittings but have no idea what the inner bushings look like . I don't hear any noise or clunking over bumps . I don't want to know what the inner bushings look like . I would imagine if they were bad I would hear something .
I do recall many years ago I hear a slight creak over bumps after a lot of rain so I greased the 4 points and bounced it and it went away and never returned. The grease comes out by the seals which I suppose is what it is supposed to do. I do wonder why all T3 years other than the 73 need to be greased every 6K and the 73 18k . Mine is a 73. |
Salty Samba Member
Joined: April 28, 2010 Posts: 197 Location: Melbourne, Australia
Posted: Mon Jan 04, 2016 6:22 am Post subject: Re: Beam disassembly / reassembly |
I finally got some barn-time and popped the outer bearings from the upper tube out. I also pulled the bearings out of another rusty beam I had from the pile.
The left trailing link looks nice, and well greased.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1447627
The right link for whatever reason wasn't getting lubed where the roller lives. Not good. It was that outer bearing that died. I actually think the inners are OK (for now). But I'm going to need a new upper trailing link for the right side, plus the bearing of course.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1447626
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1447618
Although I now have three upper roller bearings that look ok, there is some grit in each assembly and I don't see any way to clean them out. That's the problem with junk-yard parts.
But before I go out and source a new link, I'm going to take the good trailing link and one of the bearings to Whisler Bearing to see if there is a current bearing that is close. My idea is to find a bearing with a slightly smaller than stock ID and see if a machine-shop will turn the trailing link down to match the new bearing. Likewise, a bearing the is slightly oversized on the OD might be made to fit by opening up the beam to receive it.
Hey Vlad, do you have any more information on those bearings you posted pictures of?
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Mon Jan 04, 2016 8:05 pm Post subject: Re: Beam disassembly / reassembly |
Max Welton wrote: |
I am looking for a way to get some without buying several thousand units.
Max |
Several of the Chinese suppliers will sell a 'sample' (1-2 pieces). Most will but some will not. Sometimes if you offer a surcharge to make it worth their while, they'll do it.
If not, try searching for them on AliExpress.com - you can find just about anything on that site... |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Mon Jan 04, 2016 9:34 pm Post subject: Re: Beam disassembly / reassembly |
Go to your local bearing shop and ask for the HK354420 part number, many different high quality manufacturers make needle roller bearings, don't buy Chinese junk unless you want it to fail. I'm not at work otherwise I could check North American stock for that number with a few manufacturers _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
W1K1 Samba Member
Posted: Tue Jan 05, 2016 8:23 am Post subject: Re: Beam disassembly / reassembly |
so the actual number for that bearing is HK3520 which is 35 x 42 x 20mm, should be around $10 ea for a good manufacturer like INA, NTN, SKF, etc
I can find other options, what is the actual size of the OEM bearing? _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Posted: Tue Jan 05, 2016 9:24 am Post subject: Re: Beam disassembly / reassembly |
The OD of the OEM VW bearing is 44mm, so it's a 35x44x20. That's the rub. It isn't a standard size. My local bearing shop "Whisler Bearing" could not match it.
I'm in communication with ZhongHeng Bearing CO at this time. They have HK354420s for ~ $3.69 USD per so I don't expect OEM quality. On the other hand I can buy bunch and just inspect them every year or so.
If you can find a better option, I'm all ears. Cuz I'm done scraping around for NOS originals. It's just not a good long-term solution.
W1K1 Samba Member
Posted: Tue Jan 05, 2016 3:40 pm Post subject: Re: Beam disassembly / reassembly |
so OEM 311 401 305A is 35 x 44 x 20
INA HK3520 is 35 x 42 x 20
and an inch series SCH2212 is 34.925 x 44.45 x 19.05
or the longer version is SCH2216 at 25.40mm long.
it would be interesting to know why the Chinese manufacturer is making the OEM sized one. there isn't much to the construction process of the needle bearings, a spun steel housing, bearing cage, and some needle bearings.
If they can do them, that's one less obsolete item to look for _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
