ashman40 Samba Member
Joined: February 16, 2007 Posts: 5697 Location: (West) Tokyo, Japan
Posted: Sat Apr 07, 2012 5:23 pm Post subject: |
The important thing is the brass ring is electrically connected to the metal of the steering wheel. Use your ohm meter to test this.
Just as the brown wire connected to the horn's negative (-) terminal is an extension of the terminal, the turn signal switch "brass ears", the brass ring, the steering wheel and the entire steering column are and extension of this terminal too.
The wire that comes from the steering box is the permanent ground. It comes out the top of the steering column and connects to the horn ring. When you press on the ring you make the ring contact the steering wheel which closes the horn switch. _________________ AshMan40
'75 Beetle 1200LS (RHD)
"stock" 1600 w/ 34 PICT-3 carb & S/A tranny |
emu88 Samba Member
Joined: May 20, 2009 Posts: 1438 Location: Antalya, Turkey
spanky324 Samba Member
Joined: September 28, 2006 Posts: 751 Location: Greeley Pa
Posted: Sun Apr 08, 2012 6:35 am Post subject: |
| Try to get it all from one supplier better chance it will fit/ work also cheaper shipping! |
emu88 Samba Member
Posted: Sun Apr 08, 2012 12:58 pm Post subject: |
| spanky324 wrote: | | Try to get it all from one supplier better chance it will fit/ work also cheaper shipping! |
Finding the horn ring in the UK will be a tough cookie. Shipping is extortionate from all US based stores, i think i will have to approach a kind forum member to see if they will ship to me with regular USPS! _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
SVDA Bosch distributor |
Posted: Sun Apr 08, 2012 5:07 pm Post subject: |
Does your '71 SB have the wiper switch on the steering column? I thought the ' 71 was the last year for the dash mounted wiper switch?
That turn signal switch in your link is for the '72-later steering column with the wiper switch lever. If you use that turn signal lever in an earlier year steering column it will hit/interfere with the starting wheel. Later (US '72 onward) turn signal switches had deeper dished steering wheels that cleared the turn signal lever.
You want the '71-only turn signal switch that has loose wires, not the plastic connector. This was the transition year. '71 still used the '68-'70 steering wheel, but used the '71-onward horn wiring which used "brass ears" to maintain electrical contact with the steering wheel. Unless you have a different steering column?
What turn signal switch do you have on there now?
BTW, whether it has one or two "ears" doesn't make a difference. Functionally they ares the same. _________________ AshMan40
Joel Samba Member
Joined: September 04, 2006 Posts: 7990 Location: NSW Australia
Posted: Sun Apr 08, 2012 6:04 pm Post subject: |
Ashman is right, your car uses the older hardwired style switch without the modular plug at the base
emu88 Samba Member
Posted: Mon Apr 09, 2012 2:06 am Post subject: |
Bummer, the 71 only switch is like twice the price. It doesnt say for super beetles but i buess its the best one then. Thanks for the input. What about my ignition switch (few posts back)? _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
Posted: Mon Apr 09, 2012 3:39 am Post subject: |
Ignition switch for '71 is again a one-year only item (at least from the US point of view), though all post-'71s that used the early style two spoke steering wheels (1200s and 1300s outside the US) probably had '71 steering column assemblies (at least mine does). It was the last year that would allow the early style steering wheels.
You have two choices:
buy and install the proper '71 ignition switch.
buy the later '72-'73 ignition switch (much cheaper). Cut the wires at the base of the old ignition switch (below the dash) and crimp on spade connectors and add heat shrink over the entire connector so they won't short on each other. Should look something like this:
You may not have the room to use the crimp on spades with plastic insulation. The heat shrink is "slimmer".
Once you have the female spades crimped in place and insulated, plug them onto the male spade terminals on the switch. You will need to make a small connector for the small terminal. I usually bend the normal size (0.25") female spade in half until it tightly grabs the terminal.
I plan to use option #2 if my ignition switch starts giving me trouble again. _________________ AshMan40
emu88 Samba Member
Posted: Wed Apr 11, 2012 11:29 am Post subject: |
Thanks Ashman. Now I have confused my terminology and switches up. I need:
1.Turn signal switch
2.Plastic end with all the terminals for the ignition switch
So for the turn signal switch, if I understand correctly, I CANNOT get:
Switch, Indicator, Plug in connector, Bug / Beetle 72-, 1302 / 1303
because this is for models where the wipers are NOT controlled by the dash knob. So instead I need to get:
Switch, Indicator, With horn contacts, Bug / Beetle 71-
Is this correct? It's twice the price of the 72 onwards one
For the ignition switch, the barrel is fine on mine and the part where teh key goes in is okay apart from sometimes needing to wiggle the key for the gen and alt lights to come on. I have a crack in this part where the plastic is coming away and the spring inside keeps the split open:
It slides into the barrel fine and the barrel holds the split back in place, but my question is would this cause me needing to wobble the key in the ignition to get the gen and alt lights on? If not, then I will need to get a whole new ignition switch rather than just the plastic end bit. _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
Posted: Wed Apr 11, 2012 5:25 pm Post subject: |
| emu88 wrote: | Thanks Ashman. Now I have confused my terminology and switches up. I need:
2.Plastic end with all the terminals for the ignition switch |
As far as your steering wheel and turn signal switch... you are trying to get a pre-71 steering wheel to work on your '71 steering column that requires the brass contact ring on the front side of the wheel. I'm hoping you can just swap in the later contact/canceling ring... I've not actually tried it.
My suggestion above was so you wouldn't need the stock multi terminal connector at the bottom of the ignition switch. Just wire individual non-insulated crimp on connectors to the old wires and then insulate them from each other using heart shrink tubing.
If you can find a stock connector and the locking crimp on connectors to insert into it, that would make a very clean swap to the newer style switch.
| emu88 wrote: | So for the turn signal switch, if I understand correctly, I CANNOT get:
Is this correct? It's twice the price of the 72 onwards one |
'71 turn signal switch is the ONLY one that supports the earlier "shallow" steering wheel + later horn wiring with the contact ring instead of wired bearing.
| emu88 wrote: | | For the ignition switch, the barrel is fine on mine and the part where teh key goes in is okay apart from sometimes needing to wiggle the key for the gen and alt lights to come on. I have a crack in this part where the plastic is coming away and the spring inside keeps the split open... |
A cracked ignition switch case could definitely cause contact issues inside the switch. If you use the later ignition switch they are inexpensive. Just be sure to install a "hard start relay" to extend the life of your ignition switch. _________________ AshMan40
emu88 Samba Member
Posted: Thu Apr 12, 2012 2:31 am Post subject: |
You mean my steering wheel is not correct!?!? But this type was used up to 71 and 72 went to the plastic wheel, that's what I thought? Do you mean to say there were slight variations in the type up to 71 and because mine was from a 69 bug it isn't the correct one despite being the pre-plastic wheel?
From the ignition switches listed here the cheapest one is the plastic insert one for 72 onwards. It matches the cracked one I have currently:
http://www.machine7.com/search.php?xSearch=ign+switch&submit=Search
So I guess I have a 72 onward ignition switch installed on my beetle already, not the proper 71 one? Someone must have replaced it before then and chose the cheaper 72 onwards option. So I just need to but a new 72 onwards plastic switch and that's it... _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
Posted: Thu Apr 12, 2012 4:43 am Post subject: |
| emu88 wrote: | | You mean my steering wheel is not correct!?!? But this type was used up to 71 and 72 went to the plastic wheel, that's what I thought? Do you mean to say there were slight variations in the type up to 71 and because mine was from a 69 bug it isn't the correct one despite being the pre-plastic wheel? |
I know the US (non-SB) models because I'm always trying to figure out which model year US parts fit my non-US 1200.
'68-'70 had the same steering column. In '71 they kept the steering wheel style but changed how the horn worked. Instead of using an upper column bearing with a wire, they switched to the "brass ears" riding on the brass ring on the wheel. This would seem much less expensive to produce.
In '72 they changed to the 4-spoke wheel and moved the wiper switch to the column. This required the wheel to move closer to the driver to clear the levers. Then in mid-year '74 the diameter of the splines in the steering wheel was reduced and the nut that holds the steering wheel down went from a 27mm socket to a 24mm one.
| emu88 wrote: | | From the ignition switches listed here the cheapest one is the plastic insert one for 72 onwards. It matches the cracked one I have currently: |
This is great! It saves you from having to buy the more expensive one. _________________ AshMan40
emu88 Samba Member
Posted: Thu Apr 12, 2012 5:07 am Post subject: |
| ashman40 wrote: | | emu88 wrote: | | You mean my steering wheel is not correct!?!? But this type was used up to 71 and 72 went to the plastic wheel, that's what I thought? Do you mean to say there were slight variations in the type up to 71 and because mine was from a 69 bug it isn't the correct one despite being the pre-plastic wheel? |
This is great! It saves you from having to buy the more expensive one. |
Good news about the ign switch!
So about the steering wheel, in that case even though my steering wheel is from a 1969 car, it should still fit. The only thing that is different is the steering COLUMN where the indicator switch is and if I had a switch that didn't have the brass ears my steering wheel would fit?
I am confused
Is there really no way I could get any other of these switches to fit on the column and with my steering wheel apart from the 71 only one?
http://www.machine7.com/section.php?xSec=196 _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
Posted: Sat Apr 14, 2012 8:08 am Post subject: |
| emu88 wrote: | So about the steering wheel, in that case even though my steering wheel is from a 1969 car, it should still fit. The only thing that is different is the steering COLUMN where the indicator switch is and if I had a switch that didn't have the brass ears my steering wheel would fit?
I am confused
http://www.machine7.com/section.php?xSec=196 |
You are getting into the fabrication area. You are trying to get parts from different years to work together.
Have you considered installing a separate momentary switch for your horn? All it would need to do is ground the (-) terminal of the horn while it was pressed. It would need to be robust enough to handle at least 8A.
http://www.amazon.com/Wolo-Model-HS-2-Switch-Hook-up/dp/B001HJR9XE _________________ AshMan40
emu88 Samba Member
Posted: Sat Apr 14, 2012 2:10 pm Post subject: |
| ashman40 wrote: | | emu88 wrote: | So about the steering wheel, in that case even though my steering wheel is from a 1969 car, it should still fit. The only thing that is different is the steering COLUMN where the indicator switch is and if I had a switch that didn't have the brass ears my steering wheel would fit?
I am confused
http://www.amazon.com/Wolo-Model-HS-2-Switch-Hook-up/dp/B001HJR9XE |
Hmm I suppose, but I wouldn't really want a dash mounted button for the horn
I have just bought this item, 1971-79 cancelling ring: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113415660A
It says 1971-1979 but all those years except 71 had the PLASTIC padded wheel. Only 71 had the earlier type. My steering wheel is from a 1969 Beetle, so I suppose this ring will not fit it?
HOWEVER, the turn signal switch for models UP TO 1970 is much cheaper than the 71 only type: http://www.machine7.com/product.php?xProd=3006 so since my steering wheel is a 69, would this turn signal switch work with it? I could then get the cancelling ring for up to 1970 models and then I guess only my horn would be left. Would this all work?
What I have written sounds so muddled, but what I am proposing is this:
1. Got a 1971 steering column
2. Put a PRE 1971 turn signal switch on (cheaper)
3. Install a PRE 1971 cancelling ring
4. Install my 1969 steering wheel
5. Rig up horn to work some other way
OR, is this the only option that would work:
2. Buy 1971 ONLY turn signal switch
3. Install 1971 onwards cancelling ring
4. Get an exact 1971 steering wheel (different for Supers?)
5. Connect horn
Edit: I should also add that compared to my old, small steering wheel, with the 1969 wheel there is now a greater gap between the face of the turn signal switch and the bottom of the steering wheel. The semi-circular metal lip is longer than my old wheel. Would therefore a pre 1971 turn signal switch fit in this extra space?
Bocar 34-pict 3
emu88 Samba Member
Posted: Sun Apr 15, 2012 7:54 am Post subject: |
There is this item on ebay that is from a 1971 bug, but the owner says it might have been from a 1303 (impossible right for this type of wheel?) but definitely a Super.
It is different from the 1969 wheel I bought before in that the 69 one has a METAL tab, but this one is plastic and part of the cancelling ring. Is THIS the correct one for 1971 supers?
http://www.ebay.co.uk/itm/120895598726?ssPageName=...500wt_1287
It ends in 3 days!! _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
emu88 Samba Member
Posted: Mon Apr 16, 2012 1:54 pm Post subject: |
Please!! Time's running out on the ebay steering wheel, I need some advice on my above detailed post! _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
mrbigmax Samba Member
Joined: September 10, 2011 Posts: 1065 Location: Modesto, CA
Posted: Mon Apr 16, 2012 2:23 pm Post subject: |
That one should work. In 1972, VW switched to this type of steering wheel.
emu88 Samba Member
Posted: Mon Apr 16, 2012 2:36 pm Post subject: |
Yeah but I have a 71 Super! The 1969 wheel I bought fits but it is wrong for the horn contacts to work.
Edit: oops sorry, misunderstood your post. Ok so it should work. If I get a new turn signal switch though it would HAVE to be the 71 only type though right for it to work with the steering wheel? _________________ 1971 1302 1600 DP Super Beetle
Bocar 34-pict 3
emu88 Samba Member
Posted: Wed Apr 18, 2012 10:12 am Post subject: |
This is under the horn button of the ebay 1971 wheel. This is all good yes? Got the horn wire there too.
Bocar 34-pict 3
