GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
House Minutia Militia
Posted: Thu Jun 09, 2011 10:24 am Post subject: |
glutamodo wrote: |
Considering how rare it is in the US |
guteandtite wrote: |
now i need to find the rest of the set up! |
PM me.
Posted: Thu Jun 09, 2011 8:50 pm Post subject: |
Posted: Fri Jul 22, 2011 3:07 pm Post subject: |
THANK YOU SO MUCH CHRIS! Im so excited to get this all set up on my car and enjoy driving my car with it!
i had fun taking everything out of the box and checking it out
the clutch looks good! and the sindered bronze disc too! the solenoid works and I sucked on the servo and it works great too, very little suction yields enough pull that i couldnt hold the plunger back with my arm no matter how hard I pull- NEAT!!! _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse" |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Fri Jul 22, 2011 4:06 pm Post subject: |
Please take photographs and also measurements of key wear items, so others will have this data for their units. |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Sat Jul 23, 2011 8:31 am Post subject: |
There is (or was) a Saxomat equipped beetle in California owned by VW collector Carl Belcher (aka Peanuts) for years. He had a small VW museum as I recall. The car was in a couple of books proported to be a 1960 but sure looked like a 61 to me. Maybe someone knows its whereabouts as it was a running driving car. _________________ Midwest Autosavers, Inc. Woodstock, IL |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Sun Jul 24, 2011 10:27 am Post subject: |
THANK YOU SO MUCH CHRIS! Im so excited to get this all set up on my car and enjoy driving my car with it! |
No problem, I'm excited that it went to a good home and it will be able to help other Saxomat owners with this thread... |
Posted: Mon Jul 25, 2011 1:00 pm Post subject: |
link here: http://www.vwar.org/delenr.php
Picture: Sparepartnumber: Part-name: Pieces: Typ and Modell:
Automatic Clutch (Saxomat) M5
1 113 105 305 hollow screw with needlebearing 1
2 113 105 317 layer for needlebearing 1
3 113 142 021 clutch with clutchhood 1
4
113 142 025 clutchcover and pressuredisc 1
5 N 10 212 3 bolt M6x12 6
6 N 12 006 2 springlayer B6 6
7 113 142 031 clutchdisc 1
8 113 142 055 servomotor 1
- 113 142 061 vacuumtank 1 141-144,151-152 for chassis 5199980 until 6502399 M5: 141-144
9 113 142 061 A vacuumtank 1 1 M5: 113,114,151,152 for chassis 5199980 until 6502399 and forwarts chassis 115000001 1 M5
- N 10 241 3 bolt M8x22 1 for chassis up to 5199979 3 M5: 113,114,141-144, 151,152 for chassis 5199980 until 6502399 3 M5: 141-144
- N 12 228 2 springlayerB8 3
M5: 113,114, for chassis up to 5199979 141-144,151,152 for chassis 5199980 until 6502399 3 M5: 141-144
10 113 142 071 flywheel 1
11 113 142 073 centrifugal-disc 1
12 113 142 081 roller-house 1
13 113 142 091 roller-flyweight 10
14 113 142 093 cylinderbolt M6x12 9
15 N 12 026 1 springlayer 6 9
16 113 142 095 free wheel with drive-house 1
17 113 142 105 cylinderbolt M6x12 2
18 N 12 026 1 springlayer 6 9
19 113 142 109 strech-pieces 9
20 113 142 125 free-run layer 1
21 113 142 129 free run arm 3
22 113 142 133 bolts for arm 3
23 113 142 137 special nuts for bolts 3
24 113 142 139 layers for special nuts 3
25 113 142 141 spring-clip 3
26 113 142 151 clutch spring outside 9
27 113 142 155 clutch spring inside 9
28 113 142 161 case for clutch-pressurespring 9
- 111 141 165 bearing and case 1
- 111 141 177 springclip for bearing 2
29 113 142 191 clutch/friction materialparts 2
30 113 142 195 rivet for friction parts 12
31 113 142 301 pistonrod for servomotor 1
32 311 142 303 bracket for servomotor 1 for chassis forwarts 5199980
33 N 12 232 1 springlayer B12 1 for chassis forwarts 5199980
34 N 11 020 2 bolt M12x1,5 1 for chassis forwarts 5199980
- 113 142 305 bracket for servomotor 1 for chassis up to 5199979
- 113 142 315 manchette for servomotor 1 for chassis up to 5199979
35 N 12 008 2 springlayer B8 3
36 N 11 008 bolt M8 4
- N 14 395 3 stift-bolt AM 8 A x42 for bracket 3 for chassis up to 5199979
- N 12 228 2 springlayer B8 3 for chassis up to 5199979
- N 11 008 8 bolt M8 3 for chassis up to 5199979
37 311 142 319 arm for clutchrod 1 for chassis forwarts 5199980
38 113 142 347 A distance bolts for vacuumtank 4 for chassis forwarts 5199980
39 N 12 234 1 springlayer B7 4 for chassis forwarts 5199980
40 N 11 007 1 Bolts M7 4 for chassis forwarts 5199980
41 113 142 351 valveblock 6Volt for Saxomat 1
42 113 142 353 airfilter for valveblock 1
43 113 142 355 A gummi/metall bearing for valveblock 3
44 N 12 006 2 springlayer B6 3
45 N 11 006 2 bolt M6 3
46 113 142 357 tulle for tube connection 1
47 N 20 390 1 tube 12x3,5 as needed
48 113 142 367 connection tube 4,5x620 1
49 113 142 371 A tube clip 6
50 113 142 391 Bolt 8x45x38 1 for chassis forwarts 5199980
51 113 142 393 safety clip for bolts 1 for chassis forwarts 5199980
52 311 142 711 clutchrod for servomotor 1
53 111 721 349 A adjustment nut M7 for clutchrod 1 for chassis forwarts 5199980
54 N 11 007 1 bolt M7 1 for chassis forwarts 5199980
(52) 113 142 715 clutchrod for servomotor 1 for chassis up to 5199979
- 113 142 717 (between)plate 1 for chassis up to 5199979
(55) 113 142 719 A clutchrod 1 for chassis up to 5199979
55 111 141 719 B clutchrod 1 for chassis forwarts 5199980
56 N 12 416 1 safety clip 16x1 1
- N 10 230 3 bolt BM 10x30K 1 for chassis up to 3399498
- N 10 252 4
bolt M10x20 1 for chassis 339499 until 5199979
- N 12 231 1 springdisc A10 1 for chassis up to 5199979
- N 11 010 4 bolt M10 1 for chassis up to 3399498
113 142 721 adjustment nut for clutchrod 1 for chassis up to 5199979
57 311 142 721 adjustment nut for pistonrod 1 for chassis forwarts 5199980
(57) N 12 608 1 safety nut M8 1 for chassis up to 5199979
- N 12 512 1 split-clip 2x12 1
58 113 141 723 pull-back spring for clutcharm 1 for chassis forwarts 5199980
(5 113 142 723 pull-back spring for clutcharm 1 for chassis up to 5199979
A big thanks to Frank Schroën for this information. _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
