Broken Fuel Pump Spacer In Case.What Should I do?
scratchs68
scratchs68 is offline
PostPosted: Wed May 04, 2011 7:11 pm    Post subject: Broken Fuel Pump Spacer In Case.What Should I do? Reply with quote
I was having trouble with existing fuel pump so I bought a new pump, rod, spacer, and gaskets. Took the bolt off the old pump and spacer was stuck really good to case. I got a razor knife under the old gasket and it broke the seal. As I pulled out the old spacer only half came out. The other half is stuck in the engine case. I tried to remove it , but it won't move. So I cut the new spacer off at the same spot as the other one. I put it back together and its pumping fuel. Will I have a problem with oil getting into pump? Or does oil go into rod tube anyways? Or should I buy a electric pump and block- off plate and forget about it. The piece is not going anywheres. I hit it with a punch and it didnt move. Any help or suggestions would be great.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed May 04, 2011 7:22 pm    Post subject: Reply with quote
Use an EZ-Out,
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
busdaddy
busdaddy is offline
PostPosted: Wed May 04, 2011 7:44 pm    Post subject: Reply with quote
Similar situation here: http://www.thesamba.com/vw/forum/viewtopic.php?t=455164
HRVW
HRVW is offline
PostPosted: Wed May 04, 2011 7:56 pm    Post subject: fuel pump support Reply with quote
:lol:Over the yrs have seen quite a few broken when rebuilding a block...by others and myself included.
Best to leave the old piece inside as it is so as not to have any broken bits in the crank case or drop into the cam gear.
It is a taper fit and can only (safely that is) be removed with a punch from the inside of the case.
Trust me...have done many over the yrs building engines.
Steve
scratchs68
PostPosted: Thu May 05, 2011 4:03 am    Post subject: Reply with quote
So the pump should still work fine with it being in two pieces?
Greezy Joe
Greezy Joe is offline
PostPosted: Thu May 05, 2011 5:21 am    Post subject: Reply with quote
It should work fine, I too have seen this and done this.
Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound".
Cusser
Cusser is offline
PostPosted: Thu May 05, 2011 6:22 am    Post subject: Reply with quote
I chiseled the bottom part of my broken one out. I think I retrieved broken pieces out from the oil strainer screen after. Anyway, this episode did no noticeable damage.
This was on my 1971's original engine. I did this to attempt to stop a very small oil leak near there, which wasn't the distributor seal or the oil sender either. But this didn't stop the little leak. Anyway, a few years later, one of the oil studs vibrated loose, Mrs. Cusser kept driving after the oil leaked out, bearing shells on the strainer, we drove it several more years, I've posted this before...
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
