dawerks Samba Member
Posted: Fri May 06, 2011 8:52 am Post subject: A new faster way to PAINT? |
OMG.
Ok, I think I might have invented this one myself, but I'm sure someone else tried this. I love to spray epoxy. This is miracle wonder stuff. Easy to spray, easy to mix, low voc, dries fast, dries HARD! Amazing. No drawbacks basically.
Then I thought, hey! Why can't I just leave it like that? But it's a little dull. But basecoat is dull! Why not throw clear over it?? And TA DA! I did, and it's sic!
I will get pics but get this. It's basically cutting out basecoat! Your colour choice is very very limited (gray, white, green, black etc), but hot damn, I am in love!
The result? Super cheap, easy to spray (the clear is pretty deadly stuff, but what can ya do), super hard finish. I have no idea how it will hold up or what will happen as the epoxy has on UV protection, but it's just something new I decided to try. By new I mean I have never heard of it here or on AB forums... _________________ "There is only one sin; disconnection from self." |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Sat May 21, 2011 9:38 pm Post subject: |
I look forward to hearing more. _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Rockstar Suzuki Samba Member
Joined: April 04, 2008 Posts: 178 Location: Central Florida
Posted: Wed May 25, 2011 12:28 pm Post subject: Re: A new faster way to PAINT??! |
dawerks wrote: |
OMG.
The result? Super cheap, easy to spray (the clear is pretty deadly stuff, but what can ya do), super hard finish. I have no idea how it will hold up or what will happen as the epoxy has on UV protection, but it's just something new I decided to try. By new I mean I have never heard of it here or on AB forums... |
So you spray the epoxy (BASECOAT) and then you clear over it (CLEARCOAT)? If it's gray,white green etc how are you eliminating it? |
Posted: Wed May 25, 2011 2:04 pm Post subject: |
So I didn't get really good pics, but if you look at the side of my 23... (Sad thing to experiment on huh??)
Basically at the far back of the bus is the epoxy + clear and some really quick colour sanding. The front half is just the epoxy with no (or overspray) clear.
As you can easily see even in my crappy pic, the rear of the bus has a grey with shiny appearance, and the front has a grey/dull appearance. The 'shine' is in the clear (as we all know), not in the basecoat. So why spend $$$ on basecoat? I don't see the point really.
The drawback is of course limited colours or you have to gamble with tinting epoxies. _________________ "There is only one sin; disconnection from self." |
schell '59 Samba Member
Posted: Wed May 25, 2011 3:41 pm Post subject: |
cool but one problem....will it dye back?...since epoxy primer flashes different than clear and also regualer surfacer primer, it will take the clear with it when it does finish flashing....i wonder if it'll dull?
park it out in the sun as much as possible and let us know about the results. aslo epoxy takes days to flash to dry completely,while clear flashes immediately...curious to see what happens...
you can spray primer,wait for it to flash and spray clear over it too,since it's a urethane system...guys do this with epoxy's and primers in the "rat rod scene and matt clear em....same system, just no glossso if it were to dye back they wouldn't care....so it's not new sort of. _________________ WWW.401RESTOS.COM
see my "gallery" for more pics other than the website. |
Posted: Wed May 25, 2011 4:49 pm Post subject: |
The epoxy was dry for 24-48ish hours and then I was a little bored after spray clear on something else. Then I though, eeeh, why not? I cleaned up the epoxy a bit and sprayed the clear and the result was a real shocker.
I don't think the epoxy has any UV protection, but I have left it outside for weeks/months and nothing has happened to it (on something else).
The bus hardly sees sunshine though Garaged and barely even sees fresh air yet.
Maybe someone in Cali/AZ can do a test panel?? _________________ "There is only one sin; disconnection from self." |
Posted: Mon May 30, 2011 5:54 am Post subject: |
34-48 is quite along time the epoxy is definately kicked for sure...
you should try d/a ing the clear and see if it feathers back..if it does then you have good adhesion and the clear bites well to the epoxy.
if it does not feather you are going to have to remove all the clear and recoat your epoxy..but helll you gotta do that anyways as your still the "works"
i love experimenting too!!!! _________________ WWW.401RESTOS.COM
Chubber Samba Member
Joined: November 12, 2003 Posts: 334 Location: Clermont, Central Florida
Posted: Wed Jun 01, 2011 7:38 am Post subject: |
dawerks wrote: |
I think it would look better if you just clearcoated right over the front end without priming it. THAT would look unique. _________________ Chubber
'71 Deluxe 7 Passenger Bus (Resto thread)
'72 Fastback
'74 Super Beetle Convertible (Sold) |
Posted: Wed Jun 01, 2011 10:08 am Post subject: |
I colour sanded with 1000,1500 and it's really tough and on there good, so adhesion is not an issue. The epoxy is urethane chemical comp and so is the clear so they should be friendly to each other
It looked better before the filler (don't worry, it's really thin).
I should clear the roof but I don't think it will stick..
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Jun 01, 2011 10:36 am Post subject: |
You are trying for the "I just rolled it out of the Body Shop 1/2 done" look? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Jun 01, 2011 2:37 pm Post subject: |
yeah you need to stop bro' your trying to make your own steps...
just finish d/a ing that thing and epoxy the entire ride...then do your body work..stop trying to remove steps..your not rewriting the bible bro' this has been done 1000x's over.
i don;t understand your point...uerethane products will adhere to anything and your point?....how about straightening them panels,blocking them and showing your "body" skills rather than your temptations. _________________ WWW.401RESTOS.COM
Posted: Wed Jun 01, 2011 2:38 pm Post subject: |
Mike Fisher wrote: |
You are trying for the "I just rolled it out of the Body Shop 1/2 done" look? |
Can I stop sanding now?? _________________ "There is only one sin; disconnection from self." |
Posted: Wed Jun 01, 2011 2:52 pm Post subject: |
dude just prep the thing the right way..180,320 etc and epoxy that thing already..your skipping steps and rushing something...your still behind the 8 ball _________________ WWW.401RESTOS.COM
Posted: Wed Jun 01, 2011 4:26 pm Post subject: |
I don't think I'm skipping steps, I think I'm taking longer than I should sanding it. It had some horrible white paint on it that was in all the nooks and crannies, just taking the time to get it all off.
I don't have a DA, just hand sanding it (see, wasting time!)
The passenger side was totally stripped, then I put a little epoxy on it just 'to see' and the clear is just an experiment. The only body work that has started is on the nose.
The metal work is done and the bus is already pretty straight, just took a little detour along the way.
I would never just epoxy/clear the 23, and leave it. The side will be resanded, re-epoxy'd, bodyworked', 2K'd. All the stuff is SPI, which is stellar stuff for the price. _________________ "There is only one sin; disconnection from self." |
Posted: Thu Jun 02, 2011 10:56 am Post subject: |
you need to buy a d/a !!! good lord your gonna hate that bus by the time your ready for primer!!
...just get that old girl in high build!!! _________________ WWW.401RESTOS.COM
Posted: Thu Jun 02, 2011 11:09 am Post subject: |
Kansas Beige Hot Rod Flatz. _________________ https://imgur.com/user/FisherSquareback/posts
lyrikz Samba Member
Joined: September 12, 2011 Posts: 249 Location: Seattle, WA
Posted: Wed Mar 28, 2012 1:59 pm Post subject: Re: A new faster way to PAINT? |
You arent the first. I did it on my 71 chevy. Had the front in black epoxy, then just applied clear. It looks perfect compared to the black fenders. You cant tell
I also clear coated over the steel dash.
Pics
Dash. It looks way shinier in person. All the sand swirls in it.
craigman Samba Member
Posted: Fri Mar 30, 2012 10:43 am Post subject: |
One thing i would worry about is fading. I doubt sealer has any UV protection at all. Don't think the pigments will hold up to sunlight. It will probably turn a milky black color. |
lyrikz Samba Member
Posted: Fri Mar 30, 2012 10:49 am Post subject: |
craigman wrote: |
Uhm, the uv protection in the clear should take care of those worries. I could be wrong. But im not. lol. |
Posted: Fri Mar 30, 2012 12:41 pm Post subject: |
lyrikz wrote: |
craigman wrote: |
Actually, you are wrong. |
