kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Fri Jul 11, 2014 6:34 am Post subject: |
So how do people get the propane tank filled on their campers? Most places require the grill tanks to be filled behind a cage, etc. Will some place like Ace Hardware run a hose to my bus if it's close enough? _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Jul 11, 2014 8:44 am Post subject: |
Any gas station with a propane tank will fill it. Just be sure to open the vent befire filling. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
dugfresh Samba Member
Joined: November 04, 2012 Posts: 651 Location: Seattle
Posted: Fri Jul 11, 2014 10:55 am Post subject: |
Stuartzickefoose wrote: |
Any gas station with a propane tank will fill it. Just be sure to open the vent befire filling. |
Some people report having problems at gas stations with knuckleheads. Best to find one place that can handle it and give them your business everytime you fill up any tank. GL _________________ 78 Riviera
http://flic.kr/s/aHsjDRJPa1 |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Jul 11, 2014 3:30 pm Post subject: |
My adventurewagen is filled without question as all the pumpers fill the big RV's here and are used to the system- the bigger 5 on the roof of the split is a "Lay down design" which really can be filled from laying flat. It can either be taken down from the rack (if you don't bolt it down) and filled standing up or laying down as the vent tube is gone inside the tank.
Knuckle heads???? You can't fix stupid. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Fri Jul 11, 2014 3:41 pm Post subject: |
Bala wrote: |
Are the upper and lower rear shock bolts the same diameter (12mm).
I could have sworn the upper was larger when I replaced my shocks a few weeks ago. I've searched and it looks like they are the same, but I dunno... |
Some shock rubber end mounts had a steel sleeve inside which would rust to the bolt and make it look over sized- hit it with a big chisel length wise and it would usually brake loose- OR remove the sleeve from the new shock and bolt it to the old sleeve. _________________ some days I get up and just sit and think. Some days I just sit.
khalimadeath Samba Member
Posted: Fri Jul 11, 2014 7:41 pm Post subject: |
I am having some trouble finding a transmission rebuild kit for my 70 bay. Does anyone know of a company that sells everything together? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 11, 2014 7:54 pm Post subject: |
khalimadeath wrote: |
There's a few, but they all come already installed in the rebuilt transmission. Nobody can predict what parts you will need or the sizes of shims you'll require, if they did offer a "every part you may possibly need" kit it'd cost more than a rebuild by an experienced shop. You are aware there are some pricey special tools and training involved to work on a VW transaxle, right? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jul 11, 2014 7:57 pm Post subject: |
busdaddy wrote: |
There's a few, but they all come already installed in the rebuilt transmission. Nobody can predict what parts you will need or the sizes of shims you'll require, if they did offer a "every part you may possibly need" kit it'd cost more than a rebuild by an experienced shop. You are aware there are some pricey special tools and training involved to work on a VW transaxle, right? |
Hmm I didnt know that. i thought it was a pretty standard rebuild. It doesnt NEED a rebuild, I was just gonna do it.. but if its not like other rebuilds I might pass. I Know it needs a new input shaft bearing at the least.. |
Tcash Samba Member
Boyet Samba Member
Joined: March 22, 2009 Posts: 37 Location: Philippines
Posted: Sun Jul 13, 2014 9:24 am Post subject: |
Where can I buy a steering box for my '73? Links or websites please...thanks! |
airschooled Air-Schooled
Posted: Sun Jul 13, 2014 9:29 am Post subject: |
Boyet wrote: |
Wolfsburg West listed them as "in stock" a few days ago. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
cameronhoule Samba Member
Joined: July 09, 2014 Posts: 34 Location: Bend, Oregon
Posted: Mon Jul 14, 2014 8:46 am Post subject: Auto transmission conversion |
Stupid question number one.. I think the Tranny on my 1978 bay window 2.0 fuel injected bus is going out. I found a guy selling a automatic transmission for a late bay window for just $50. Would this conversion be pretty difficult?? |
germansupplyscott Samba Member
Posted: Mon Jul 14, 2014 7:59 pm Post subject: Re: Auto transmission conversion |
cameronhoule wrote: |
the gear selector and throttle linkages will be the major issue. it's possible but far, far from a bolt-in swap. easy answer is it's too much work to be worth the effort but that's subjective. how badly do you want an automatic or are you just being frugal (cheap). the automatic linkages, mounts, gear lever etc. will not be easy to put together unless you have a complete donor automatic vehicle with everything available. _________________ SL |
sonofamitch Samba Member
Joined: May 27, 2012 Posts: 325 Location: Evergreen, CO
Posted: Fri Jul 18, 2014 5:46 pm Post subject: |
Can a type 4 case be welded? Specifically the part of the case where the lower case bolt runs through the oil sump and threads into the other side of the case (picture for reference). Will the case need to be aligned bored after the welding?
_________________ '77 Westy 2.0L FI
http://www.thesamba.com/vw/forum/viewtopic.php?t=568454&highlight= |
encsdaddy Samba Member
Joined: September 16, 2007 Posts: 156 Location: Inland Empire, CA
Posted: Sat Jul 19, 2014 5:09 pm Post subject: Welding a case |
sonofamitch wrote: |
I believe that I remember seeing and reading about just such a proceedure here on the samba. I believe that the poster was chrisradioman. I don't recall if the post was on his current bus "Milly", or his previous bus. Can't find the post, but I will keep looking. _________________ 77 Westy named Tiki - Daily Driver 80 miles a day!
(2.0L with hydro lifters)
78 Bus (8 seater w/ front bench) - Still trying to get it running! (fuel pump cuts out)
69 Sqauareback - RIP (Rear ended by a Volvo)
72 Bug - RIP (Rusted away!) |
guitarman63mm Samba Member
Joined: September 03, 2008 Posts: 797 Location: Asheville, NC
Posted: Sat Jul 19, 2014 5:39 pm Post subject: |
On the T4 case:
That's the little hidden 8mm bolt, isn't it? I'm guessing you missed it and tried to pull the case apart with it still there?
It can be welded, yes, but you're going to want to take it to a machine shop that is comfortable TIG welding and machining aluminum. From what I've read, MIG is a real dirty PITA on aluminum.
I don't see why it would need to be line bored though, welding aluminum requires a lot of heat, but I can't imagine it would warp the case. All you would need to do to ensure it lines up is to put the case together with a few nuts/bolts before you drill the new hole, no?
Another possibility is using an insert, like a heli-coil, but you'd have to make sure you have enough material to do so. I believe that bolt is an M8x72, and the Heli-coil hole size for the 8mm-1.25 insert is 8.3mm. _________________ Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine. |
fon Samba Member
Joined: July 23, 2010 Posts: 97 Location: San Juan, Puerto Rico
Posted: Sun Jul 20, 2014 3:17 pm Post subject: |
Hi Guys,
I don't kwon if this qualifies as an stupid question, but I had been working on my 1970 Westy for the last few years buying her back on the road again.
I replacecet all the steering components including a trbuilt steering box.
I notice that when I turn the steering well all the way to the left the inside of the right tire tuch the Stabilizer bar. So what I did wrong ?
Miss alignment the steering box with the peg or Drag link adjustment?
Thanks for the help!! |
Posted: Sun Jul 20, 2014 11:45 pm Post subject: |
fon wrote: |
Hi Guys,
There is a very certain order that our front steering assemblies go together in. It's outlined in detail in your service manual, but the basics are:
1- Center the steering box, ignore the steering wheel.
2- Center the center pin (with the drag link.)
3- Center the tires with the one adjustable tie rod.
4- Pull the steering wheel and center it.
Again, the service manual will be more detailed, but I think those are the basic steps, and you ALWAYS start with a centered box and END with the steering wheel.
My guess- one of two things:
- Drag link was adjusted too long, and now your straight tracking is actually a "right turn" according to the box which is not centered.
- Someone installed a second adjustable tie rod, so they could bypass steps 1 and 2 above and just use the tie rods to center the road wheels. This is WRONG, and partly why VW did NOT equip these cars with two adjustable tie rods.
Let us know if going through your linkage by the book doesn't help.
Tcash Samba Member
Posted: Mon Jul 21, 2014 7:14 am Post subject: |
X2
If it still rubs after you set up the steering per the manual. You may need to adjust your Steering Stops.
fon Samba Member
Posted: Mon Jul 21, 2014 7:29 am Post subject: |
Thank guys!!
Excellent advice, I will get under the bus hopefully this week,
with my trusted Bentley Manual. Verify that everything is according to specs . Will try to make a video or pictures of my findings,
Thanks! |
