airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Fri Apr 17, 2015 8:18 am Post subject: |
ccpalmer wrote: |
This is embarrassing... I've pulled T1 engines multiple times over the last 25 years and don't remember having a problem with this bolt...
How do you guys tighten (and loosen) the upper engine-to-tranny bolt on the driver's side? I have a '71 so my engine has the boss in the case so I don't need a nut on that bolt. I had a devil of a time removing the bolt and am wondering how you all do it.
Thanks! |
I like a 6" extension for my thinnest 17mm socket. Some thick (cheap) sockets have a hard time fitting around the nut and clearing the trans case. This will put the ratchet wrench above the clutch cable, with enough room for a 60* swing of the ratchet. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Fri Apr 17, 2015 9:14 am Post subject: |
asiab3 wrote: |
ccpalmer wrote: |
Thanks! |
I like a 6" extension for my thinnest 17mm socket. Some thick (cheap) sockets have a hard time fitting around the nut and clearing the trans case. This will put the ratchet wrench above the clutch cable, with enough room for a 60* swing of the ratchet. |
That's what I did. I even have a stubby ratchet that seemed to help. Especially since my regular ratchet had a lot of slop in it. It has since been replaced by Sears for free. Third one in 27 years. _________________ '71 Westy
Posted: Fri Apr 17, 2015 9:15 am Post subject: |
So is your issue with a stuck bolt? Or do you have problems accessing it? _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Fri Apr 17, 2015 9:17 am Post subject: |
asiab3 wrote: |
So is your issue with a stuck bolt? Or do you have problems accessing it? |
It just took me an extra few minutes to get it out, but I did notice that the bolt had backed out a bit so I bet I didn't get it tight enough the last time. I can get it on/off with the ratchet/6" ext. but I was trying to figure out a better way to torque the bolt down well. Tough to get a good angle with the clutch cable and heater tube in the way. But those are the fun ones.
I guess I could take off the heater tube to make access easier but I hate to mess with my very nice heater tubes since I know they're a tough one to find. _________________ '71 Westy |
THall Samba Member
Joined: August 25, 2010 Posts: 324 Location: Verona, WI
Posted: Fri Apr 17, 2015 7:03 pm Post subject: Accelerator cable linkage |
I thought for sure I could find this info in a search....hence why I'm thinking it may be a stupid question?
I'm switching my bus back to FI and right now I'm changing out the accelerator cable. The one the PO had on there has a hook that attaches to the pedal linkage like so...
The one I think I should be installing has the bent end like this...
Is this how this cable end is supposed to be installed, or am I missing anything. Bentley has the one image and I think this is correct based on that?
_________________ '78 Westy - 2.0 FI |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Apr 17, 2015 7:09 pm Post subject: Re: Accelerator cable linkage |
THall wrote: |
Is this how this cable end is supposed to be installed, |
Yes, that is correct. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
THall Samba Member
Posted: Sat Apr 18, 2015 7:50 am Post subject: Re: Accelerator cable linkage |
busdaddy wrote: |
THall wrote: |
Yes, that is correct. |
Thanks BD! _________________ '78 Westy - 2.0 FI |
aguirre59 Samba Member
Joined: August 01, 2011 Posts: 43 Location: La puente, ca
Posted: Sat Apr 18, 2015 11:08 am Post subject: |
Thanks Tcash! |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sat Apr 18, 2015 9:16 pm Post subject: |
I cut a hole for my fuel sender today, but how do you actually remove it from the gas tank? Do you just pry it out? I started trying without much luck and didn't want to force it.
On a 75 FI _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Posted: Sat Apr 18, 2015 9:34 pm Post subject: |
Thrasher22 wrote: |
On a 75 FI |
Turn the outer gold colored ring CCW, there's small rectangular ears sticking up to pry or pound on a little one side and then a little on the other. Or if it's a one peice unit turn the whole thing CCW. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Apr 18, 2015 10:37 pm Post subject: |
If you made yourself a squarish hole, you can use the corners of the hole to pry against. With a round hole it is hard to achieve good leverage. |
Mistersponge Samba Member
Joined: March 06, 2014 Posts: 20 Location: Syracuse, NY
Posted: Sun Apr 19, 2015 2:54 pm Post subject: |
Hopefully this is an appropriate place to post my dumb question, can somebody help me ID my motor? GE028590 it's in a 77 bus, but if I'm reading the chart correct its a 78 motor? _________________ 1977 Westy |
Posted: Sun Apr 19, 2015 3:10 pm Post subject: |
Mistersponge wrote: |
Hopefully this is an appropriate place to post my dumb question, can somebody help me ID my motor? GE028590 it's in a 77 bus, but if I'm reading the chart correct its a 78 motor? |
Could be, what month was your bus built? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 19, 2015 5:49 pm Post subject: |
Scroll down to the '77-78 model years
http://www.thesamba.com/vw/archives/info/chassisdating.php |
Posted: Sun Apr 19, 2015 7:05 pm Post subject: |
Wildthings wrote: |
Yea, I've been looking at that, is it as easy as "my numbers are after the example posted for 77, therefore its a 78?"
I'll look for and check the m codes tomorrow for some more clues. _________________ 1977 Westy |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Apr 20, 2015 7:35 am Post subject: |
New Stupid Question:
1970 Baywindow, pretty much bone stock and nearly complete. The spare tire (with original bias ply, now removed) rim/wheel is painted black. It appears to be factory paint.
Why would this rim alone be painted black? All the other rims/wheels are white. I cannot recall ever seeing factory painted black rims from that era. |
m.pendzick Samba Member
Posted: Mon Apr 20, 2015 1:59 pm Post subject: |
Has anyone got any good ideas on how to seal a can of POR-15 so it can be re-used? I had a tiny can of it and used most, not all of it. I put the lid back on and it wouldn't come off again. I eventually had to use snips to cut a hole in it. It's cheaper to purchase this stuff in larger quantities and I am going to be using a good amount over the life of the resurrection to my '73. I just don't want to throw good money after my mistake if I can help it. Thanks!! |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Mon Apr 20, 2015 2:03 pm Post subject: |
m.pendzick wrote: |
_________________ 1976 Westy
1966 Beetle |
Posted: Mon Apr 20, 2015 2:39 pm Post subject: |
Wasted youth wrote: |
Rims came all black with white on the outside where it shows, maybe it's a dealer replacement? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Brian Samba Moderator
Posted: Mon Apr 20, 2015 2:55 pm Post subject: |
I recall that most late bays have spares that are just black. I'm pretty sure all the space saver ones are black too. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
