BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1325 Location: Arizona
Posted: Sun Jul 17, 2011 4:15 pm Post subject: |
| Stuartzickefoose wrote: |
how does the brake light warning switch wire up, if i want it to turn on when i pull on my e brake, and turn off when i take off the brake?
Thanks
Stuart |
There's a button, right on the base bracket that the e-brake rests against when off (attached at the bottom of the dash panel), which is wired to the light on the dash. When depressed (brake handle released) the button is pushed, and the light is off. When the handle is pulled to set the e-brake, the button springs out, powering the dash light. I know, because I had to remove mine in order to install my new parcel tray. _________________ 1978 Sage Green Westfalia
1969 Delta Green/Cloud White Transporter
1977 Senegal Red/Atlas White Transporter
Life is short. Can I have some of yours? |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5573 Location: Edmonds, WA.
Posted: Sun Jul 17, 2011 6:01 pm Post subject: |
| BusterBrown wrote: |
Thanks
Stuart |
There's a button, right on the base bracket that the e-brake rests against when off (attached at the bottom of the dash panel), which is wired to the light on the dash. When depressed (brake handle released) the button is pushed, and the light is off. When the handle is pulled to set the e-brake, the button springs out, powering the dash light. I know, because I had to remove mine in order to install my new parcel tray. |
i understand that part of it, i just wonder how the two wire up to each other. _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
Posted: Sun Jul 17, 2011 7:20 pm Post subject: |
Thanks
Stuart |
i understand that part of it, i just wonder how the two wire up to each other. |
Umm, with a wire?
1 wire from power (fuse box) to button, and 1 wire from button to dash light.
What year is your bus? _________________ 1978 Sage Green Westfalia
busdaddy Samba Member
Joined: February 12, 2004 Posts: 24136 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Sun Jul 17, 2011 8:33 pm Post subject: |
Thanks
Stuart |
Umm, with a wire?
What year is your bus? |
Hold on there, that's a recipe for smoke
The brake handle button grounds when you pull the brake, adding a live wire from the fuse box will end badly the first time you park, luckily the brake warning light has complex internal circuits to manage these things, the diagram in your Bentley or here in the Samba's technical section can give you all the wire colors and terminal numbers to do it right  _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
Posted: Sun Jul 17, 2011 8:53 pm Post subject: |
Ahso! Thanks busdaddy san. I guess this is now the stupid answer thread too. I knew there was a wire involved though...
Negative, not positive. Stuartzick- always listen to busdaddy. _________________ 1978 Sage Green Westfalia
Posted: Sun Jul 17, 2011 11:58 pm Post subject: |
Negative, not positive. Stuartzick- always listen to busdaddy. |
i always do...lol and i figure it is more than one wire...lol what page might i find it in the bently? _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Mcpie Samba Member
Joined: April 16, 2005 Posts: 62 Location: Portland, Oregon
Posted: Mon Jul 18, 2011 12:18 am Post subject: |
| That depends on what year your bus is. But two seconds opening your bentley and you could answer your own question. If you don't have a bentley look up on any page while on this website and the dropdown menu under technical will have a wiring page. Your bus's diagram will be there, most likely in color. |
Posted: Mon Jul 18, 2011 8:26 am Post subject: |
its a 1978... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
Wildwesterner Samba Member
Posted: Fri Jul 22, 2011 11:36 pm Post subject: |
I took out my engine and transmission last weekend. What are some good things to do in the engine/tranny area while its all out?
I have already installed a second battery.
Any Ideas?
I already did a forurm search and did not find anything on the subject. _________________ 58' Beetle project
73' Bay |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 1200 Location: Northern California
Posted: Sat Jul 23, 2011 1:56 am Post subject: |
| Wildwesterner wrote: |
Any Ideas?
I already did a forurm search and did not find anything on the subject. |
This is funny! _________________ 1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Desertbusman Samba Member
Posted: Sat Jul 23, 2011 2:11 am Post subject: |
Yes it is.  _________________ The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
| 73kombi wrote: |
| when that red light goes on, you have to make a choice. |
| Amskeptic wrote: |
I am not answering that.
Respectfully,
GoBuyABentley |
71 Superbug
71 Westy |
Posted: Sat Jul 23, 2011 8:58 am Post subject: |
Any Ideas?
http://www.thesamba.com/vw/forum/viewtopic.php?t=165001
Scroll down to "What to do while the engine is out..." _________________ 1978 Sage Green Westfalia
Vis Samba Member
Joined: February 27, 2010 Posts: 56 Location: Norfolk, VA
Posted: Wed Jul 27, 2011 3:59 pm Post subject: |
i figure this question has already been covered somewhere, so i'm posting it here... what the ham sandwich is this?
 _________________ "E' meglio vivere un giorno da leone che cent'anni da pecora" |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3307 Location: Australia
Posted: Wed Jul 27, 2011 4:01 pm Post subject: |
| Vis wrote: |
Looks like it may be a Subaru Sambar. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4086 Location: Swansea (Sunny Penllergaer) Wales UK
Posted: Wed Jul 27, 2011 4:19 pm Post subject: |
Right then can someone answer me this?
In the UK your vehicle has to have:-
1.) An MOT every year, which is an inspection carried out by an MOT station (basically a garage with a special licence & equipment) they check that the vehicle is in a safe & roadworthy condition, you have to do this every 12 mths. this costs around £40
2.) You have to tax the vehicle every year at a cost of £210 for a Bay window free for any vehicle built before Jan 1st 1973
3.) You have to insure the vehicle for 12mths this cost depends on your age, how many times you have claimed where you live, what you use the vehicle for & any motoring convictions you have.
If your vehicle is declared off the road you don't have to do any of these. but you have to:-
4.) Register the vehicle in your name, this is free if you have the registration certificate otherwise it costs £25.
The registration the vehicle is given as soon as it is registered in the UK stays on the vehicle for good.
How does it work in the USA?
1.) Do you have to MOT
2.) Do you have to tax?
3.) Do you have to insure?
4.) Do you have to register?
Does the vehicle registration No. stay on the vehicle for the life of the vehicle?
In the UK when you buy an old vehicle you can write to the DVLA (Driver Vehicle Licencing Agency) with a payment of £5 & they will tell you all of the address's of previous owners, you have to be the registered keeper of this vehicle to do this, can you do this in the USA? _________________ http://www.vintagevwweddings.co.uk/contact.html |
Rick73Super Samba Member
Joined: June 30, 2004 Posts: 1905 Location: Philly - Yo!
Posted: Wed Jul 27, 2011 4:31 pm Post subject: |
| chrisradioman wrote: |
| How does it work in the USA? |
50 States = 50 different sets of rules |
Posted: Wed Jul 27, 2011 4:34 pm Post subject: |
Is there anything special about the distributor shaft O ring, or is it just an O ring. I've never actually bought one before. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Vis Samba Member
Posted: Wed Jul 27, 2011 4:35 pm Post subject: |
1.) Do you have to MOT?
most states require a state inspection. some don't (florida and oklahoma that i know of, i'm sure there are more).
2.) Do you have to tax? usually the tax is paid when you register the car.
3.) Do you have to insure? yes.
4.) Do you have to register? yes.
Does the vehicle registration No. stay on the vehicle for the life of the vehicle? no _________________ "E' meglio vivere un giorno da leone che cent'anni da pecora" |
GusC2it Samba Member
Joined: June 23, 2005 Posts: 1364 Location: Orlando, Florida, USA
Posted: Wed Jul 27, 2011 4:44 pm Post subject: |
| Vis wrote: |
Does the vehicle registration No. stay on the vehicle for the life of the vehicle? no |
Lots of people here just steal their cars and rivit on a bogus M tag. We're a bunch of outlaws you know. _________________ 75 type 2 http://gusc1.tripod.com/1975vwtype2
Old vices have now been upgraded to bad habits.
http://www.facebook.com/pages/VW-Wild-Weekend-2011-St-Pete-Fl/197064760336111 |
Posted: Wed Jul 27, 2011 4:55 pm Post subject: |
In Pennsylvania laws are different for standard and antique tags, I have antique
1.) Do you have to MOT - exempt from emissions testing, muffler must not leak, must pass standard safety inspection at licensed garage
2.) Do you have to tax? - at time of purchase I had to pay 6% state tax + 2% City tax
3.) Do you have to insure? - fully insured as an antique, about 1/3 cost of standard policy about $600 per year
4.) Do you have to register? as an antique only once, standard would be yearly, antique registration is about double standard fee around $125
5) Does the vehicle registration No. stay on the vehicle for the life of the vehicle? - with antique tag it does, not with standard; previous owner information is strictly private in US, no way to find out
If you buy a vehicle in state, you must have seller's drivers license number in order to register, not required if out of state.
Antique vehicles must be essentially unaltered, you have to submit photos with application. A friend was denied tags on his Corvair, he had the wrong hubcaps. |
