minispdrcr Samba Member
Joined: September 13, 2010 Posts: 272 Location: Oklahoma City, OK
Posted: Tue Nov 15, 2016 1:35 pm Post subject: Re: The Stupid Question Thread |
We have tried two tools and both broke, have tried a 45 ton and a 60 ton press and the tools just disintegrated. So, we are looking at other avenues. _________________ Marcin P.
1969 Westfalia Weekender Edition
1973 Morris Mini 1300 Super
1998 Audi A6 |
Posted: Tue Nov 15, 2016 2:20 pm Post subject: Re: The Stupid Question Thread |
minispdrcr wrote: |
We have tried two tools and both broke, have tried a 45 ton and a 60 ton press and the tools just disintegrated. So, we are looking at other avenues. |
You still haven't told us if you are just trying to remove the ball joints from the eyes on the steering knuckle or if you are trying to press the BJ from the trailing arms. Two very different procedures. |
Posted: Tue Nov 15, 2016 2:25 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
minispdrcr wrote: |
Trailing arms. Sorry! _________________ Marcin P.
1998 Audi A6 |
Posted: Tue Nov 15, 2016 3:13 pm Post subject: Re: The Stupid Question Thread |
minispdrcr wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Trailing arms. Sorry! |
Most people today just get rebuilt exchange arms with new joints pressed in from one of many vendors. Other wise you can have yours reworked by a shop that has experience in dealing with them. There is also a good video out there of someone changing them out with a ball joint puller/press while the arms are still installed on the car.
I have a local suspension shop that has been able to do the work for me. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Nov 15, 2016 4:22 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
minispdrcr wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Grind the backs off and run a hot bead of weld around the joint, it'll shrik and almost fall out of the arm. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
beatles4 Samba Member
Posted: Tue Nov 15, 2016 5:16 pm Post subject: Re: The Stupid Question Thread |
I wanted to double verify that this is what I need. Bus needs a new clutch and for the price I might as well replace everything.
https://www.fcpeuro.com/products/vw-clutch-kit-kf193-01
Description says it fits up to 70 transporter and campmobile. This model seems to be the spring loaded version of a clutch.
If so I am buying it now along with things I needed for my Volvo.
Edit: Forgot to mention my bus is a 69 camper with the original engine. _________________ Click to view image
http://www.vw-mplate.com/mplate2-27771.png |
Posted: Wed Nov 16, 2016 5:47 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Grind the backs off and run a hot bead of weld around the joint, it'll shrik and almost fall out of the arm. |
I have tried our shops, and they want to heat them. That is why I was asking if its OK to heat. _________________ Marcin P.
1998 Audi A6 |
Posted: Wed Nov 16, 2016 8:00 am Post subject: Re: The Stupid Question Thread |
minispdrcr wrote: |
busdaddy wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Grind the backs off and run a hot bead of weld around the joint, it'll shrink and almost fall out of the arm. |
I have tried our shops, and they want to heat them. That is why I was asking if its OK to heat. |
Not with oxy/acetelene, propane can't get hot enough to soften it but if it reaches the point it's starting to glow it's too hot. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Nov 16, 2016 11:00 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Wildthings wrote: |
minispdrcr wrote: |
Last winter I did a couple of ball joints by grinding off the backside, pounding the main part through the joint body, then cutting the joint outer ring with a sawzall. No special tools and the second one took me fifteen minutes.
Pressing the new ones back in was easy as pie. I will see if I can find that video link I followed.
EDIT: found it... http://www.thesamba.com/vw/forum/viewtopic.php?p=7915482 _________________ nothing |
Sage79 Samba Member
Joined: September 13, 2008 Posts: 433 Location: Holland MI
Posted: Thu Nov 17, 2016 9:40 am Post subject: Re: The Stupid Question Thread |
I also did a set the way Corey advocates above. If you're careful it's a great way to go. Don't be afaid of it. Any good shop can then press new ones in. _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
wcfvw69 Samba Purist
Posted: Thu Nov 17, 2016 11:18 am Post subject: Re: The Stupid Question Thread |
http://www.thesamba.com/vw/forum/viewtopic.php?t=620643&highlight=
Here's how I did mine. _________________ Contact me at [email protected]
The Samba member since 2004.
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sat Nov 19, 2016 5:47 am Post subject: Re: The Stupid Question Thread |
I picked up a timing light at an estate sale so I could learn to do the timing on my bus. 5 bucks, and it looks brand new. got it home and was checking it out, and see it is for 6.5 volts. useless for what I need? no difference? change the bulb and good to go? |
Posted: Sat Nov 19, 2016 8:29 am Post subject: Re: The Stupid Question Thread |
alman72 wrote: |
Strobe bulbs don't care about primary system volts, but the electronics that trigger it likely do. You'll have to find some sort of voltage dropping resistor, or power it from a lantern battery or other 6V source. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Sat Nov 19, 2016 7:58 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
alman72 wrote: |
Strobe bulbs don't care about primary system volts, but the electronics that trigger it likely do. You'll have to find some sort of voltage dropping resistor, or power it from a lantern battery or other 6V source. |
Try using your trusty 12v timing light to diagnose a no-start. An hour and a half later the owner will come out and tell you that the car is 6v. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Wed Nov 23, 2016 10:23 pm Post subject: Re: The Stupid Question Thread |
asiab3 wrote: |
busdaddy wrote: |
alman72 wrote: |
Try using your trusty 12v timing light to diagnose a no-start. An hour and a half later the owner will come out and tell you that the car is 6v. |
why are you using a timing light to diagnose a no- start? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Thu Nov 24, 2016 12:42 am Post subject: Re: The Stupid Question Thread |
TomWesty wrote: |
asiab3 wrote: |
busdaddy wrote: |
alman72 wrote: |
why are you using a timing light to diagnose a no- start? |
It was a customer's car and we used an inductive timing light to see that there was spark at the coil and center pin on the distributor, while there was no spark at at plug wires.
The rotor was the wrong rotor for the cap, and the inductive clamp was a quick way to see that spark was making it in but not out.
I'll also often use one to diagnose an ignition misfire, either connected to the center coil wire or each spark plug wire while watching the light for missing flashes during missed combustion events.
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Thu Nov 24, 2016 8:57 am Post subject: Re: The Stupid Question Thread |
alman72 wrote: |
If you were in AZ I would trade you for a 12v one.
Yes, I would be worried it might burn out.
My 12v light works on my 6v Bus but I usually have to hook it straight to the generator so it gets >6v _________________ How to Post Photos
ToddMatthews Samba Member
Joined: September 30, 2016 Posts: 6 Location: Petaluma
Posted: Sun Nov 27, 2016 1:28 pm Post subject: Re: The Stupid Question Thread |
I like this stupid question thread! So, here's mine.
Lug nut wrench size for a 1970 Type 2? Mine is missing and I'm a bit lazy to pull the hubcaps at this time! Thanks! |
Posted: Sun Nov 27, 2016 1:59 pm Post subject: Re: The Stupid Question Thread |
ToddMatthews wrote: |
19mm or 3/4" _________________ nothing |
Posted: Sun Nov 27, 2016 2:20 pm Post subject: Re: The Stupid Question Thread |
Is it usually enough to replace the shocks for rear bus sag? Are the expensive Koni's worth it? or will KYB's do the job just as well? Thanks in advance for all replies! Much appreciated! |
