Posted: Tue Jul 10, 2012 8:37 am Post subject: |
| airkooledchris wrote: |
the filler tube gasket. I replaced the dipstick boot and that's still holding up - for now.
I do have another spare one of those at least as I had heard from others they don't last as long.
is there a special search term im missing or does nobody actually carry that filler tube gasket? |
Silicone works well and will last longer than any engine you rebuild. Just don't gob too much on there as with time the excess will end up in the oil pickup screen. |
curtis4085 Samba Member
Posted: Tue Jul 10, 2012 8:44 am Post subject: |
Sorry I got confused your not talking about the grommet that seals the filler tube to the coolin tin, your looking or the gasket between filler and case? This part should be available. I bought one last year. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
71 Pastel White Panel Van current restoration
73 Westfalia (sold)
73 Westfalia (accident)
73 Kombi (Sold)
75 Panel Van
79 Sage Green Westfalia fully restored
http://www.thesamba.com/vw/forum/viewtopic.php?t=479199&postdays=0&postorder=asc&start=0 |
airkooledchris Samba Member
Joined: January 25, 2005 Posts: 1735 Location: Eureka, CA
Posted: Tue Jul 10, 2012 9:57 pm Post subject: |
| curtis4085 wrote: |
| Oil filler tube gasket 071 115 315A 1 $4.37 paper |
Thanks Curtis! _________________ Join the IAC Facebook group here! |
phoneguy Samba Member
Joined: March 14, 2008 Posts: 157 Location: Long Island
Posted: Wed Jul 11, 2012 11:24 am Post subject: |
Is there a factory hole in late model heater boxes to let condensation drain? _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3307 Location: Australia
Posted: Thu Jul 12, 2012 4:16 pm Post subject: |
What are those trim clips called like on the slider door? They go all the way through and have a shiny metal top on them like a stud. Also can that sort of things still be purchased? If so I'm willing to do all the measuring to get the holes for trim pieces in the right place to use them.
So close to finishing now and I kind of don't want to drill holes for screws if I can clip panels in. Going to make them from that 3mm ply because it's only like $19 / sheet. Missing the bottom half of the slider panel, the one next to the back seat, the one between the C/D pillar (although there is no obvious way of attaching anything) and the back hatch panel. Some of these never even existed. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 24143 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Thu Jul 12, 2012 4:25 pm Post subject: |
| phoneguy wrote: |
| Is there a factory hole in late model heater boxes to let condensation drain? |
Yes, one little v shaped punchmark near the front. _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
Posted: Thu Jul 12, 2012 4:36 pm Post subject: |
| busdaddy wrote: |
| phoneguy wrote: |
Yes, one little v shaped punchmark near the front. |
Thanx BD, almost welded that shut. _________________ "When my ship comes in I'll be at the airport"
1971 Supervert
1977 Westfalia |
Posted: Thu Jul 12, 2012 5:47 pm Post subject: |
| RatCamper wrote: |
| What are those trim clips called . |
Expensive: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=221867615A , you may be better off finding something here (possibly plastic) and sourcing them locally. _________________ Rust NEVER sleeps and stock never goes out of style.
Blue Bear Samba Member
Posted: Sun Jul 15, 2012 1:03 am Post subject: |
My bus is a '79 and the numbers on the fan case and oil breather are the same, GE039000. From that it tells me my engine is a '79. I got that down.
What I don't get is that my exhaust system doesn't look like that off a '79 and when I went to get new gaskets for the muffler I had to buy 72-74 gaskets. It's 2 different spots entering the Muffler and one exit at the tailpipe on the passenger side of the engine. Is this something that some '79 engines had or do I have a wrong/mixed exhaust system? _________________ 1979 Westy |
Posted: Sun Jul 15, 2012 9:06 am Post subject: |
Sounds like a 79 system to me, the ports at the heads will be the final answer, own a camera? http://www.thesamba.com/vw/forum/viewtopic.php?t=6 _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Sun Jul 15, 2012 2:43 pm Post subject: |
| Blue Bear wrote: |
What I don't get is that my exhaust system doesn't look like that off a '79 and when I went to get new gaskets for the muffler I had to buy 72-74 gaskets. It's 2 different spots entering the Muffler and one exit at the tailpipe on the passenger side of the engine. Is this something that some '79 engines had or do I have a wrong/mixed exhaust system? |
Sounds right for a Federal '79, while the Cali '79 was a hybrid. |
secretsubmariner Samba Member
Joined: January 08, 2011 Posts: 1817 Location: Midtown, watching cops lights go by. 74112
Posted: Tue Jul 17, 2012 10:00 am Post subject: |
This is super stupid and I think I'll get a better response here.
Where can I find an engine number that's at a different location than the shroud?
My shroud is not original to my engine, and I want to know what the engine is out of.
It is a type 4, with the original oil dipstick location on the top sorta by the AAR. Probably Porsche or maybe Vanagon?
Can I see the engine number without pulling a bunch of crap off of it? _________________ -Tony
1978 Champagne- "Lord Puber"- first love.
1978 Champagne- "Scuttlebutt"
1978 Deluxe Auto Westfalia- "Samsquantch"
| Amskeptic wrote: |
| Anybody dissing any year air-cooled Volkswagen is not on board. |
| germansupplyscott wrote: |
| i like auto transmissions in buses. it's a lot easier to roll a joint while driving with an automatic. |
Posted: Tue Jul 17, 2012 1:09 pm Post subject: |
| secretsubmariner wrote: |
The block is stamped right at the base of the breather tower. You have to stick your head in the engine compartment and kind of look behind the fan shroud to see them. |
Posted: Tue Jul 17, 2012 1:29 pm Post subject: |
thanks! _________________ -Tony
| Amskeptic wrote: |
rustbus Samba Member
Posted: Wed Jul 18, 2012 8:47 pm Post subject: |
Dudes, does the ballast resistor and / or double relay need to be metal to metal grounded to the firewall or just the brown wire on the fuel pump harness only?
I want to fasten these units to the firewall without screws. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
get_a_pet Samba Member
Joined: April 01, 2012 Posts: 5 Location: Owen Sound ON Canada
Posted: Wed Jul 18, 2012 11:00 pm Post subject: Power steering |
| Hi I was just wondering if any one can tell me when power steering was added to the Westys. Thanks |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5573 Location: Edmonds, WA.
Posted: Wed Jul 18, 2012 11:37 pm Post subject: |
like 1985...on the vanagons... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
