What year is this Bus? (Added more Pics)
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
61TXghia
61TXghia is offline
PostPosted: Wed Apr 04, 2012 9:19 pm    Post subject: Reply with quote
I am digging my exhaust note.
61 Ghia
62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
bill may wrote:
Camping is cheaper than therapy.
www.swaircooled.com
Z
Z is offline
PostPosted: Wed Apr 04, 2012 11:20 pm    Post subject: Reply with quote
Great transformation of that bus! Can't wait to see more. Extra cool that your kids are into it...
skaw
skaw is offline
PostPosted: Sat May 05, 2012 12:59 am    Post subject: Reply with quote
im loving your progress, and wow we have the same look, I too have cut wheel wells and I chose the gray primer and white top! looks good! congrats Applause
SKAW= SEEK KNOWLEDGE AND WISDOM
61TXghia
61TXghia is offline
PostPosted: Sat May 05, 2012 10:30 am    Post subject: Reply with quote
Thanks SKAW, we have a blast in this bus.
61 Ghia
www.swaircooled.com
Split62
Split62 is offline
PostPosted: Sat May 05, 2012 10:39 am    Post subject: Reply with quote
durfeec wrote:
61TXghia wrote:
I think that the best part is that the PO already cut the rear fenders so I can put some monster mudders on it!! YEEEEEEHAWWWW!! So, has anyone fixed rear tire fenders that have been cut? Once I confirm the year, I will order the correct panels for repair. Thanks for all your help.
yes. its fairly common for the rear tire repair. hit up Gerson. he'll get you what you need. and there is no better metal than his for patch panels.
Any contact info for Gerson? I need to fix my rear tire fenders too...
NOOB
skaw
skaw is offline
PostPosted: Sat May 05, 2012 11:09 am    Post subject: Reply with quote
congrats on the bus split 62!! I am in Vacaville if you need any help Very Happy , I believe gerson can be found at Klassic fab.
61TXghia
61TXghia is offline
PostPosted: Thu Jun 07, 2012 9:31 pm    Post subject: Reply with quote
Here is an update. My motor spun a crank bearing and the material clogged one of the oil passages on the crank going to piston 1. I took block completely apart with step by step instructions from the "Bug Me Video". I took the block and had it machined, crank, and rods also. I then started the step by step process of rebuilding it. I also replaced the two relief valves. During the process, I dropped one of my pistons and put a dent in the edge, luckily a buddy had an extra piston that he gave to me. So rings and all bearings are new now. Everything came together rather easy. Once motor was installed, it would not start. Even though I didn't remove the distributor gear, I now have to put my distributor 180 off. The motor runs perfectly and I have already adjusted the valves and changed the oil after 25 miles. So far so good, does not heat up and has excellent power. Just need to get my distributor gear flipped and it will be good.
61 Ghia
www.swaircooled.com
ccb_dan
ccb_dan is offline
PostPosted: Fri Jun 08, 2012 3:54 am    Post subject: Reply with quote
That's pretty rad that you disassembled and reassembled the motor by watching an instructional video! Too cool!
61TXghia
61TXghia is offline
PostPosted: Fri Jun 08, 2012 10:00 am    Post subject: Reply with quote
I know, right. Felt like I was painting by numbers. LOL. Hopefully I did everything right and the motor holds up.
61 Ghia
www.swaircooled.com
thecrewcrew
thecrewcrew is offline
PostPosted: Fri Jun 08, 2012 11:34 am    Post subject: Reply with quote
did you get the middle seat with it?
Eric Knight
StickerHaus
facebook.com/stickerhaus
'63 Kombi (walk thru)
View user's profile Send private message Send e-mail Visit poster's website Facebook Twitter Classifieds Feedback
61TXghia
61TXghia is offline
PostPosted: Fri Jun 08, 2012 2:15 pm    Post subject: Reply with quote
No middle seat. I have a table instead but wouldn't mind finding a middle seat.
61 Ghia
www.swaircooled.com
kitcarson
kitcarson is offline
PostPosted: Sat Jun 09, 2012 2:23 am    Post subject: Reply with quote
i have really enjoyed reading this thread. I just bought a 65 and it was in way better shape then yours. And seeing what you have done gives me some encouragement. You have done great. And everyone in your family enjoys the bus. My whole family went when I rescued mine too. It gives them some investment in it. Great job......
61TXghia
61TXghia is offline
PostPosted: Sat Jun 09, 2012 11:51 am    Post subject: Reply with quote
Thanks Kit, it is a blast to work on and your right, my kids love it. We had a get together last night and our club was happy to see the bus back on the road. Do you have pics of your rescue?
61 Ghia
www.swaircooled.com
61TXghia
61TXghia is offline
PostPosted: Sun Jun 10, 2012 10:17 pm    Post subject: Reply with quote
Went for a cruise today and noticed a weird sound coming from rear wheel. Took hubcap off and noticed a lug nut had come off. I guess the tire shop that mounted my tires stripped a lug nut and didn't tell me. I am looking to replace that rear drum now, but in the meantime, should I worry about driving with a missing lug nut on the left rear tire?
61 Ghia
www.swaircooled.com
BarryL Premium Member
BarryL is offline
PostPosted: Mon Jun 11, 2012 6:36 pm    Post subject: Reply with quote
You'll probably be ok for standard cruising.
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Sun Aug 19, 2012 11:43 pm    Post subject: Reply with quote
Any further updates 61TX?
I am impressed with your 'mechanical aptitude', especially since you've split the case and then reassembled the whole sha'bang. AND it runs too?!?! Good on ya, bro.... Cool
Lind wrote:
Apparently I was just the lucky asshole that showed up at the right time.
I am a Dick, hear me roar- Laughing
Me, an OVP Lifer...
Page 10 of 10
