kombisutra  Samba Member
Joined: October 02, 2003 Posts: 3769 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Thu Jun 16, 2011 9:55 pm Post subject: |
| 61TXghia wrote: | | Dumb question, but what do the front seat rails look like? |
They look like these:
... and when idiots cut them out, they look like this:
Since your bus looks like this:
...you might consider selling these:
...and instead, find a set of these:
...and your bulkhead will likely need these oddballs:
VIN of this bus: 720734
Of course, since you already have the seats, and it may well be a "Service Installation" covered in the Bentley, grab a welder and have at it. The hardest part was drilling the spot welds and grinding off the welds from my seat stands, but since you don't have those, half the battle is already over. The spot welds on the four pieces you'll need to collect, of course, need to have the spot welds drilled out too, but in the end, it's worth it. I still like Bench Seating better though, it smacks of earlier buses, which yours is.
big bus mike Samba Member
Joined: June 16, 2004 Posts: 2131 Location: New Mexico
Clara  Samba Member
Posted: Thu Jun 16, 2011 10:53 pm Post subject: |
Those green lower corner panels are original. The repros WW sells are vinyl covered, which is incorrect.
Also the green panel above the engine is og. The best way to remove that is lift the passenger side up to clear the gas filler, and pull the whole thing forward keeping it straight with the bus, then pull it out the cargo door. Twisting makes it trickier. (Installation you bring in the cargo door, straight with the bus, drop the drivers side down so just the edge is on the flat area above the engine, and slide it straight back, drop the passenger side down when it clears the gas filler bump.)
You have the armrest brackets still on the long wall. Those black metal strips with nut/bolt at each end
keep those pieces.
Seat belt mounts look like the bus was factory optioned.
61TXghia Samba Member
Joined: July 17, 2009 Posts: 890 Location: El Paso, TX
Posted: Thu Jun 16, 2011 10:59 pm Post subject: |
| Thanks Clara, I made sure to keep all the screws also when I removed them. I do think I will go bench route on this bus. Anyone want to buy some seats? LOL |
Posted: Fri Jun 17, 2011 12:24 am Post subject: |
Glenn A Samba Member
Posted: Fri Jun 17, 2011 7:27 am Post subject: |
Art lets see some pics of the frame,rockers,the back of the lower nose and all that dry Texas goodnest.  _________________
| mannys66 wrote: | | In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it. |
65 walk through EzCamper
67single cab huge project
010 TDI sportwagen
And a stupid Baywindow. |
Posted: Fri Jun 17, 2011 6:38 pm Post subject: |
Got a bit ahead of myself and was just curious if a rattle can primer would cover up the awful graffitti on this bus. Whatever they painted it with left massive runs, can I just sand these down and rattle can over them for now? What grit should I use and how much should I sand?
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1032 Location: Vallejo, CA
Posted: Fri Jun 17, 2011 11:45 pm Post subject: |
| You could probably sand down the runs with some 220 grit and then hit it with some 400 to smooth it out. Then hit it with some primer. It would lookm better than that stupid graffiti. Krylon sprays on nice, it has a nicer nozzle than rustoleum. |
Posted: Sat Jun 18, 2011 1:13 am Post subject: |
Yes, with a common orbital sander you can flatten those high school drools and follow up with an appropriate primer.
The images you show portray a hugely more restorable bus than the first found pictures.showed, congratulations, that bus is gonna' survive, and not because of us, but because of YOU!
Good on you!  |
Posted: Tue Jun 21, 2011 9:18 pm Post subject: |
Took the diamond tuck material off of my interior panels and found what looks to be OG colors. I wet the panel down and put it between two boards and a large sheet of metal. I parked my car on top of it for most of the day and the panel came out flat as a pancake. Hopefully when it dries completely it will stay flat.
 _________________ 61 Ghia
62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
| bill may wrote: | | Camping is cheaper than therapy. |
www.swaircooled.com |
EverettB  Administrator
Joined: April 11, 2000 Posts: 41916 Location: Phoenix, AZ
Posted: Tue Jun 21, 2011 10:34 pm Post subject: |
Cool! Yes, those are all original panels _________________ How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
"Water is the only drink for a wise man" | "Communication prevents complaints" |
peterpanic Samba Member
Joined: August 17, 2010 Posts: 48 Location: Philadelphia, PA
Posted: Wed Jun 22, 2011 6:44 am Post subject: |
| 61TXghia wrote: |
cute kid with cool hat. driving a standup bus. who needs safaris! |
Posted: Wed Jun 22, 2011 5:49 pm Post subject: |
I plan on taking the front end out and fixing the steering and doig the brakes. PO had started to take front end out so I think there are missing pieces. If anyone spots one, let me know. Check out the sloppy tow bar that I borrowed, it ruined the steering damper when I backed the bus up.
EmpiGT Samba Member
Posted: Wed Jun 22, 2011 7:07 pm Post subject: |
From 2 of the pics there is some bolts that hold the beam in missing. Can't tell from pics if any are in it, is there any in it? If not you're lucky that tow baring it only damaged the dampener!  |
Posted: Wed Jun 22, 2011 9:04 pm Post subject: |
Wow, that's sick! Possibly all four main front end bolts and the swing lever/drag link nut.  |
mannys66 Samba Member
Joined: November 21, 2001 Posts: 5274 Location: the 108
Posted: Wed Jun 22, 2011 9:15 pm Post subject: |
| kombisutra wrote: | Wow, that's sick! Possibly all four main front end bolts and the swing lever/drag link nut.  |
I was just gonna say that, and whats with the late beam in there? _________________
| zuggbug wrote: | | Manny you are an inspiration. |
http://the108tradingpost.com/ |
quartermilecamel Samba Member
Posted: Wed Jun 22, 2011 10:54 pm Post subject: |
Ok all you late beam haters..chill  _________________ Looking for the U shaped swing arm for sliding door split. Left hand drive. Baywindow arms are 1/2 inch longer. |
Posted: Wed Jun 22, 2011 10:58 pm Post subject: |
| mannys66 wrote: | | kombisutra wrote: | Wow, that's sick! Possibly all four main front end bolts and the swing lever/drag link nut.  |
I was just gonna say that, and whats with the late beam in there? | Manny, so that beam does not go in this bus? How can I tell for sure? _________________ 61 Ghia
Culito 11010101
Joined: December 07, 2006 Posts: 4965 Location: Columbia Missourah
Posted: Thu Jun 23, 2011 8:31 am Post subject: |
Was the bus sanded down before all that graffiti was sprayed on there? There might be some good OG paint left.
http://www.thesamba.com/vw/forum/viewtopic.php?t=76072
Nice work on the panels, btw. _________________ Copyright 2012-apocalypse, CJ Industries, Inc.
'62 Turkis fleet
| johnnypan wrote: | | ...dont pay no attention to Culito,he's a cornhole.. |
