Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Thu May 19, 2011 7:38 am Post subject: |
miniman82 wrote: |
Glenn wrote: |
I can't even get wiper blades locally. |
Just cut a long one in half, like everyone else. |
No need... i have a spare set. Just like I have spare cap/rotor/points/condenser in case i need them. _________________ Glenn
Member #1009
#BlueSquare |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu May 19, 2011 7:40 am Post subject: |
Spare parts are for systems prone to fail. Mine never will, since there's nothing to wear out. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Glenn Mr. 010
Posted: Thu May 19, 2011 8:00 am Post subject: |
miniman82 wrote: |
Spare parts are for systems prone to fail. Mine never will, since there's nothing to wear out. |
What's the fun in that?
So you're saying that electronics never fail? Seriously? _________________ Glenn
Member #1009
#BlueSquare |
craigman Samba Member
Posted: Thu May 19, 2011 8:13 am Post subject: |
Hey mini,
wasn't it you that not to long ago had kept having injector problems and then to come to find out you had a problem with your electronic board? |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Thu May 19, 2011 10:09 am Post subject: |
miniman82 wrote: |
Proximity sensors go bad. Just ask anyone who ever had a crank or cam position sensor or ABS sensor fail on a modern car.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Thu May 19, 2011 12:40 pm Post subject: |
I just love the gadgets. I wanted to get the digital but it wasn't advised. I'm sure as soon as the bugs are worked out between the digital distributor and the quick tune are hammered out, I'll go that route. Or crank triggered _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
Posted: Thu May 19, 2011 1:26 pm Post subject: |
craigman wrote: |
We're talking ignition parts here, try to keep up. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Thu May 19, 2011 1:31 pm Post subject: |
Yes i know, but your board has no moving parts and it wore out. That was my point.
Things can and do wear out even parts that are non-moving parts. |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Thu May 19, 2011 1:57 pm Post subject: |
craigman wrote: |
My only complaint about solid state equipment(non-moving parts) is that they usually fail without any warning, that's why I keep that POS .009 as a spare. I really thought the negitive info about the .009 was just BS until now.
Posted: Thu May 19, 2011 1:59 pm Post subject: |
Yep, good old 009 for me also. And an extra set of points and condensor! |
Posted: Thu May 19, 2011 5:31 pm Post subject: |
[quote="craigman"]Yes i know, but your board has no moving parts and it wore out.[quote]
You're confusing my fuel injection computer for my ignition system, they have nothing in common besides 2 wires. If you want to split hairs, it failed because of an overvoltage condition over a long period of time (years). Had it not happened, I would never have known about an issue with the alternator.
Quote: |
That was my point. Things can and do wear out even parts that are non-moving parts. |
My point stands, the ignition is bulletproof. I would trust EDIS 1,000 times before I'd ever go back to caveman style points. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
RanX0R0X Samba Member
Posted: Tue Jul 31, 2012 9:02 am Post subject: |
Glenn wrote: |
vwracerdave wrote: |
With EFI you might gain a tiny bit of power. If your running carbs your wasting your money on all that hi-tech electronics. |
I agree. |
For me it wasn't a matter of gaining power. It was gaining the stability and eliminating variables from the tuning of the engine.
It helped me considerably as I was having problems that seemed to be both from fuel delivery and ignition. I'm not an aircooled Guru like you guys so running down a multivariate problem like that was going to be difficult. It's difficult in software engineering where I've been working for over 20 years and know the "smells" of code failures.
One criticism that has been leveled at the electronics is that they are fail fast. That is, if a capacitor pops and lets its smoke out, the ignition quits working. I'd rather have that then chugging and bogging or dying when I'm accelerating and not not knowing why.
If the electronic dizzy is working, its going to be pretty dead on and I can always plug into it and monitor it directly. If I have any sort of problem I can pretty quickly "look" at the ignition and tell if it is a problem.
After I put this in I still had some problems but they weren't as severe. The car didn't bog down. What was required was some tuning and work on the Del 40's and a friend kindly helped with those.
Power? As you suggest, there are likely better ways to get that. The only thing I want the electronic ignition for is stability. |
