durfeec Samba Member
Posted: Mon Nov 25, 2013 4:42 pm Post subject: |
This shouldn't have been fully welded. There should have been a visible seam where the top panel, the one you welded in, and the nose met.. _________________ 1960 Bus Panel/Camper |
type47fan1 Samba Member
Joined: December 03, 2011 Posts: 828 Location: McDonough GA
karl h Samba Member
Joined: October 10, 2005 Posts: 578 Location: austria
Posted: Tue Nov 26, 2013 6:59 am Post subject: |
thanx guys
its isnt fully welded at the joint between window frame and front, the stock seam is all on the donor piece. i did this because it is very hard to get a stock looking joint. this is welded at the factory with a spot welder, with my spot welder i cant reach around the dashboard. at the factory the dashboard was mounted after welding the two front pieces i assume. sorry for the bad pics
did some more work on the torsoin tube:
from the top:
new inner frame made from 2.5mm sheet metal:
first positioned with the mig welder, i used the arc welder for getting enough penetration on the tube. the new piece is thicker than the stock tube
thanx for looking _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert
Posted: Tue Nov 26, 2013 8:06 pm Post subject: |
I posted that and then went and tinkered on my bus. I remembered the pic kinda and realized that you had welded lower than the og seam. Sorry about that. _________________ 1960 Bus Panel/Camper |
karl h Samba Member
Posted: Thu Nov 28, 2013 1:42 am Post subject: |
if i motivate somebody to get going on their own bus, thats cool!
strangly i have been pretty motivated too:
fabrication of the outer part of the frame:
outer part testfitted:
broke out hammer and dolly to shape the upper ond lower part:
i have only spotwelded them to make a good fit. the part now kinda snaps in place. i will weld it on the inside before instalation:
stay tuned _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
86 Caravelle
04 new beetle vert |
karl h Samba Member
karl h Samba Member
karl h Samba Member
karl h Samba Member
karl h Samba Member
Posted: Thu Dec 12, 2013 2:47 am Post subject: |
the torsion tube is now fully welded, some more cleanup to do after sandblasting
i have also repaired the framepart where the handbrake goes with the help of the donor part. a torch and some colourful words were necessary to take out the handbrakeleverpin
at last i started to cut off the rear part of the roof to graft in the rear donorsection and repair the inner gutter
comments and critique welcome _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
86 Caravelle
karl h Samba Member
karl h Samba Member
karl h Samba Member
Posted: Mon Dec 16, 2013 6:24 am Post subject: |
when the rear part was cut i found out the roof had come off about a foot from the raingutter, so i cut a donorpiece. this was taken from the passenger side of it, the donor was rusted on the driversside too:
cutting:
flange exposed. i had a little trouble getting it off clean at the strengthener inside, but finally managed
trial fit:
this thread doesnt seem to generate a lot of interest, but posting progress keeps me going _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
86 Caravelle
04 new beetle vert
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Mon Dec 16, 2013 6:28 am Post subject: |
It is VERY interesting, and I for one enjoy watching your efforts. Please keep posting, and please keep including the pics. You're providing a lot of valuable insight for others that may be looking forward to the same repairs. |
karl h Samba Member
Posted: Tue Dec 17, 2013 12:40 am Post subject: |
thanx guys, i really appreciate it!
next i removed the rotted part of the inside gutter. pretty tricky to get just the upper part out, but i managed to cut it with the airdisc and airsaw, then wiggle off the rest:
fabrication of the new upper part was next, it reaches to the roof bow and attaches to it with a little flange. the bow is loose on the sides (probably from the body flexing during decades of driving)
a littel crude, but it works for a part you can hardly see. i will spot weld it in place after sandblasting the gutter. hope there will be no more holes to patch then....
the donorpiece was fitted next, welded from the inside
i will fit the large rear part before finishwelding the roofskin. and yes i used a flange tool. i know this can be seen from the inside, but i feel i can do better adjustments that way - and hey, this is no pebble beach resto
68 ghia vert
86 Caravelle
karl h Samba Member
Posted: Thu Dec 19, 2013 12:19 am Post subject: |
next i drilled out the chanell for the rear hatch seal from the old roofpart
and checked the fit:
i pulled the sidewalls together a bit:
and checked the gaps with the help of the (donor) hatch and some wooden wedges
after tapping all of the screwholes i attached the hatch to the roofsection
some more tweaking necessary, but you get the idea. its not so easy getting this part on alone
68 ghia vert
86 Caravelle
karl h Samba Member
eastcoast63 Samba Member
Joined: April 29, 2004 Posts: 1424 Location: Ft. Lauderdale
Posted: Thu Dec 26, 2013 2:17 pm Post subject: |
Keep up the good work....subscribed!
Ant _________________ Fort Lauderdale, Florida
1967 Standard Microbus
Wide 5 Vintage Volkswagen Club |
rustytortoise Samba Member
Joined: September 14, 2006 Posts: 100 Location: williston, fl
Posted: Thu Dec 26, 2013 2:39 pm Post subject: |
fixing roofs is so fun! cool thread, i like the extraction of the 66.
_________________ -Jonathan |
