Brake Booster Vacuum Hose
Page: Previous  1, 2
germansupplyscott
germansupplyscott is offline
PostPosted: Fri May 27, 2011 8:34 pm    Post subject: Reply with quote
aeromech wrote:
I wonder if they are interchangeable?
i would say not. in a pinch maybe but not the same part.
SL
aeromech
aeromech is offline
PostPosted: Fri May 27, 2011 9:11 pm    Post subject: Reply with quote
Yeah, My local VW Parts House only stocked one. I bought the last one at $2.95. The one I got has the recesses in the rim.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
dubluvv
dubluvv is offline
PostPosted: Sat May 28, 2011 2:59 pm    Post subject: Reply with quote
OK, got a hard plastic hose from aeromech. It's not a two-piece one but I think I can at least make it work with some 15/32" hose attached at the other end. Thanks for all of the input.
-Mitch
'76 Westy 2.0L FI "Lucy" Project Thread
'84 Rabbit L Diesel - Potential Greasecar Project
[quote="chazz79"]"Aw honey, I got another one of those bay-bus things on my shoe again...dammit"[/quote]
aeromech
aeromech is offline
PostPosted: Sat May 28, 2011 3:02 pm    Post subject: Reply with quote
Don't forget the black rubber seals/bushings that go in the bell shaped ends of the hose. They are very similar to the ones used in the plastic brake fluid hose coming from the reservoir.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
kinggeorge13
kinggeorge13 is offline
PostPosted: Fri May 24, 2013 8:00 pm    Post subject: How to remove vacuum hose check valve for brake booster Reply with quote
Hi guys. I have a problem so simple, I just cannot figure out the best/safest way to do it. I need to replace the check valve in the vacuum hose that goes to the brake booster. 1975 Westfalia camper but it has a 2.0 Litre Westy engine in it. The valve is located right over the engine and the vacuum hose is the original fairly hard plastic black hosing. One end over the valve stem (engine side) has a clamp, the other side does not. Where the stems are rammed into the hoses, the hoses are stretched plenty wider than the rest of the hosing. Therein lies my problem. How do I get that hose off the valve stems/connectors? I removed the one clamp but I can tell you, pulling/wiggling lots has gained nothing. I sure don't want to damage those hoses. I suppose I could go at it with a hair dryer to try and soften it but surely guys in repair garages don't pull out a hair dryer? Thanks!
Hoody
Hoody is offline
PostPosted: Fri May 24, 2013 10:27 pm    Post subject: Reply with quote
Contact Scott at German Supply. He sells the valves and I am sure he has done this swap more times than most. You will only get one chance to do it right. With 35 year old plastic you are very wise to ask for advice. Perhaps he will chime in. The way those valve ends are they are meant to almost be a one time install. Are you sure the check valve is shot? I would not put any direct heat to the plastic tubing without first hearing from someone who has made the mistakes and knows exactly how to do it correctly. Good luck!
Page: Previous  1, 2
Page 2 of 2
