andelises Samba Member
Posted: Mon May 30, 2011 3:37 am Post subject: 1967/8 resto |
hi all. i am new here and wanted to share my new restro with you. i picked this up a few weeks ago and payed £420 for it.
here is a few photos so far
Posted: Mon May 30, 2011 4:43 am Post subject: |
ok so after finding all the rust im thinking time to get the body off. i got the doors lined up and welded a support frame on the inside. took all the bolts out and fuel tank, wires and all that. it was then ready to lift so i lifted the body and the wife slid some stools (almost stools somewere els to) under. same with the back and rolled the floor pan out. i the knocked up a dolly so a can move the body easy.
gt1953 Samba Member
Posted: Mon May 30, 2011 7:15 am Post subject: |
You are going in the correct direction. Most deffinetly have your work cut out for you. I always like to see picture of those in different countries and the surroundings. Heck I had to goggle Wales to get a geography lesson. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon May 30, 2011 11:05 am Post subject: |
ye plenty to do on it. we are in pembrokeshire in wales and live no more than 15 mins away from around 30 beaches. so the salt air has got to it. im hoping i will have it on the road this time next year. we have small houses dont we. and to think i payed £175000 for it. bet you get more for you cash over there. |
shepp10 Samba Member
Joined: February 14, 2011 Posts: 12 Location: Sandy, Utah
Posted: Mon May 30, 2011 12:28 pm Post subject: |
That car would make one badass volksrod, you should consider staying fenderless. |
Posted: Mon May 30, 2011 12:31 pm Post subject: |
iv taken the front beam off a few days ago and cut in some say-a-way adjusters. that gave me a 3" drop with no load or whight of the floor pan or body so im gessing it will give me arond 4" when car sitting on it aswel. just got to grid the welds flat now and sand blast it ready for paint. then gave it 2 coats of zinc 182 then two coats of hammerite.
over the weekend i took the motor and gear box off along with all the running gear
Posted: Mon May 30, 2011 12:50 pm Post subject: |
shepp10 wrote: |
i have been thinking about what to do with it but im still unshore. here it one a mate done that is now for sale
dasdachshund Samba Member
Joined: March 29, 2010 Posts: 728 Location: Vancouver, WA USA
Posted: Mon May 30, 2011 3:25 pm Post subject: |
Good job on the beam.
Bet your neighbors love that chasis reolling around.
-dasdachshund |
Posted: Mon May 30, 2011 3:37 pm Post subject: |
thanks. it was tempting to use it as a board |
Posted: Tue May 31, 2011 11:13 pm Post subject: |
well its rained sinc i was last on here so i have spent hours and hours rebiulding the gear box and starter.
also sand blasted a small bit of the floor pan and gave it a coat of acid and a coat of zinc 182
a.wilson Samba Member
Joined: January 11, 2007 Posts: 2033 Location: Georgia
Posted: Wed Jun 01, 2011 12:02 am Post subject: |
andelises wrote: |
looking great! Pan inserts seem to be in good condition.. skipping the need for replacements. _________________ Be kind to all critters. America's "H8TERZ" can drink sludgy used Motor Oil!
oemwolf |
Posted: Wed Jun 01, 2011 8:58 am Post subject: |
thanks. ye they are very gud apart from the battery tray will need replacing. but thats not the end of the world |
Posted: Sun Jun 12, 2011 4:45 am Post subject: |
hi does any one no if i will need short shocks and caster shims as i am lowering the front on say-a-way adjusters and the back 2 inner splines |
twowheeletex Samba Member
Posted: Sun Jun 12, 2011 3:58 pm Post subject: |
I'll start off with I'm not an expert, but i'd say no on the short shocks. your range of travel is still the same. you just changed the preload on your spring packs in the beam. if you plan on going super low it might not hurt though. as far as camber shims. depends on what you plan to do with the rear end. if it stays the stock height giving the car an overall rake look then probably, but an overall even drop in height shouldn't mess with the stock caster. just my 2 cents fwiw. |
Posted: Mon Jun 13, 2011 12:20 am Post subject: |
hi thanks for that. its one thing that i was really unshore about . the front will be going down around 3inches and back 2 splines. |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Mon Jun 13, 2011 12:29 am Post subject: |
nice.. be looking for updates _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
JonF Samba Member
Joined: December 16, 2005 Posts: 2030 Location: Oklahoma
Posted: Mon Jun 13, 2011 12:31 am Post subject: |
hmm someone has hacked that car up! look the steering wheel is on the wrong side! you need to fix that asap! lol just kidding with you. looks like you have done some really nice work to what you have done. _________________ 68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix |
Posted: Mon Jun 13, 2011 12:38 am Post subject: |
thanks guys
ye i thort there was something rong with it. must have put the dash in upside down |
Posted: Sat Jul 02, 2011 1:31 pm Post subject: |
hi all been a bit held up on the bug dew to work. anyway iv welded up all the holes and gave it all 3 coats of zinc 182. just gota top coat it now and the start rebuilding it .
Posted: Mon Jul 04, 2011 2:08 pm Post subject: |
o and one of bottom ready for stone chip and top coat
