Proper Operating oil temperature 1600
Page: Previous  1, 2
kenworth
kenworth is offline
PostPosted: Sun Jul 03, 2011 8:43 am    Post subject: Reply with quote
We have seen damage like that in only twelve months on a street car in the past. In the old days when we raced . Once we ran a 3 hour endure in the rain with a new header . After the race we tore down the motor . The header already had rusty water coming from wrap .That stuff is a great horse power and heat retainer unfortunately it also has some down sides ..Another side benefit to ceramic coating, With a squirt bottle it is very easy to see which cylinder is misfiring ,just squirt the tube just past the flange .It will tell you in a heart beat if you got fire in that hole OR MARGINAL PROBLEM lol .JEFF
quartermilecamel
quartermilecamel is offline
PostPosted: Sun Jul 03, 2011 1:14 pm    Post subject: Reply with quote
Geeeez, that looks like someone took a torch to it. Shocked Well that cans the header wrap idea Crying or Very sad
Waiting for santa to drop off funky green. I can wish can't I????
advinnie
advinnie is offline
PostPosted: Sun Jul 07, 2013 8:33 am    Post subject: Reply with quote
Glenn wrote:
0-180 too cool
180-210 normal
210-230 hot but OK
230-250 very hot
250+ turn it off
hi there sorry if this sounds dum but are these figures for idle temperature or the max temperature the engine should get full stop.
PostPosted: Sun Jul 07, 2013 9:03 am    Post subject: Reply with quote
advinnie wrote:
Glenn wrote:
0-180 too cool
180-210 normal
210-230 hot but OK
230-250 very hot
250+ turn it off
Max. temp. while driving.
Although I usually check it when stopped for gas since I don't have a gauge.
If you leave the car idling it should never get that hot - it should even cool down if it is too hot.
advinnie
advinnie is offline
PostPosted: Sun Jul 07, 2013 9:19 am    Post subject: Reply with quote
Well I went for an hour ish drive the other day then outside air temperature was 28 degrees Celsius. The drive included a 40 minute drive in town (a lot of start stop style driving) and a 20 minute drive on the motorway at 70 mph then a 2 minute drive to my house at 40 mph. As soon as I got home I popped the engine lid and stuck the themonitor down the dip stick tube all the way into the oil not touching the sump and I got a reading of 93 degrees Celsius after ten minutes of idle I rechecked and the temperature had fallen down to 88 degrees Celsius. Does this sound ok to you lot? Cheers
Hyperspace
Hyperspace is offline
PostPosted: Sun Jul 07, 2013 10:37 am    Post subject: Reply with quote
P.S. you mention running j-tubes, do you have the industrial tins installed that is supposed to be used with them?
http://www.thesamba.com/vw/forum/viewtopic.php?t=401943
If you can't fix it with a hammer, it is an electrical fault.
Photo's http://www.thesamba.com/vw/forum/album_search.php?search_author=Hyperspace&show_results=summary
68IHscout
68IHscout is offline
PostPosted: Sun Jul 07, 2013 11:13 am    Post subject: Reply with quote
Did ya have moisture resistant high heat paint on that pipe or just what it came with ?
PostPosted: Sun Jul 07, 2013 6:18 pm    Post subject: Reply with quote
93C = 200F so Yes.
88C = 190F so Yes again.
They are both in the "Normal" range above.
sb001
sb001 is offline
PostPosted: Thu Oct 03, 2013 6:58 pm    Post subject: Reply with quote
I have a 1600 SP engine and I have finally gotten my bug running great over the last few days. BUT-- after a period of driving (say 20 minutes at highway speed) when I come to a stop the oil warning light comes on. Normally I don't pay much attention to it as it has done this for as long as I can remember. But when I got home today I tried to touch the dipstick and it was blazing hot, no way I could touch it for even half a second. Ive read somewhere on here that you should be able to touch it for a few seconds. All my tin is present, valves are set perfectly, and my fan is working so assuming it is getting too hot (don't know for sure cause I dont have a thermometer to check) what do I need to do to cool this sucker down?
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Mr.Duncan
Mr.Duncan is offline
PostPosted: Thu Oct 03, 2013 7:43 pm    Post subject: Reply with quote
I had the same issue on a rebuilt engine with 2k miles.
I had all tin/seals/fantastic oil pressure and I checked everything.
After highway driving my oil got too hot and the light came on. (not pressure)
I had the temperature dipstick wired up to warn me when my oil reached 230-240F
Found my problem, my timing at 3500 RPM was at 32 Degrees.
I set my timing down to 30 Degrees at 3500 rpm and it made a world of difference.
My oil temps went down 30-20F !
Also ran much smoother.
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
sb001
sb001 is offline
PostPosted: Thu Oct 03, 2013 8:18 pm    Post subject: Reply with quote
Wow 2° made that kind of difference? OK I'll see about re-timing the engine, it may be over-timed by that much. Thanks for the info!
1600 SP engine
Mr.Duncan
PostPosted: Thu Oct 03, 2013 8:58 pm    Post subject: Reply with quote
Yes. I was surprised
Remember your DVDA times differently than my SVDA
1966 Ghia (sold)
1966 Red Beetle
sb001
sb001 is offline
PostPosted: Thu Oct 03, 2013 9:17 pm    Post subject: Reply with quote
My distributor was an SVDA it just had the wrong vacuum can (DVDA can) attached to it. The vacuum can went out on me the other day which was the cause of my running problems, I blocked it off and plugged the vacuum ports on the carb and re-timed the distributor to run mechanical advance only. There is a distinct possibility I didn't get it quite right, it is running great but I still get a small backfire every once in a while so I had the feeling it was still off by just a bit.
1600 SP engine
igne82
igne82 is offline
PostPosted: Tue Feb 18, 2014 4:01 pm    Post subject: Reply with quote
There are lots of reasons this could happen. When was the last time you changed the plugs and wires, checked your spark plug gaps, checked the timing, even poor carb adjusting can attribute to excessive heat. The dipstick test is hardly science also... you may want to get an oil gauge to help you troubleshoot.
Page: Previous  1, 2
Page 2 of 2
