Brake adjuster leaf spring
tjettom
tjettom is offline
PostPosted: Mon Feb 17, 2014 6:49 pm    Post subject: Brake adjuster leaf spring Reply with quote
The ad for the spring said "welding required" and no other instructions. I have a new spring to repair a rear backing plate and my questions before I begin are ...Is it ok to simply weld the new spring upside down to the bottom of the adjuster block while the backing plate is still on the car or should it be removed first? and also would the heat of the weld ruin the temper of the spring. I have been wondering about what others opinions might be since I need to either do this repair or replace the backing plate with the new one I have on hand that I would rather return to the supplier.
Thanks so much for all insight!
Tom
Jeff_Birt
Jeff_Birt is offline
PostPosted: Mon Feb 17, 2014 6:58 pm    Post subject: Reply with quote
They only need to be tacked in place. A couple of spot welds is all it should take.
Multi69s
Multi69s is offline
PostPosted: Mon Feb 17, 2014 10:10 pm    Post subject: Reply with quote
Jeff is right. You need to generate minimal heat when you weld it. A spot welder would be perfect, next best is tig, then mig. Do not use gas. Pull of the backing plate, tack it on then cool it with a wet rag.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Jeff_Birt
PostPosted: Tue Feb 18, 2014 6:18 am    Post subject: Reply with quote
When I said spot weld I was meaning a plug/rosette weld with a MIG welder. Most folks will have easier access to a MIG than a resistance/spot welder. I'm not sure what you mean about 'don't use gas'.
Hyperspace
Hyperspace is offline
PostPosted: Tue Feb 18, 2014 9:56 am    Post subject: Reply with quote
he meant like a portapak
If you can't fix it with a hammer, it is an electrical fault.
Photo's http://www.thesamba.com/vw/forum/album_search.php?search_author=Hyperspace&show_results=summary
andk5591
andk5591 is offline
PostPosted: Tue Feb 18, 2014 10:52 am    Post subject: Reply with quote
I have had great luck just getting the old one out and peening the new one in place.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
tjettom
tjettom is offline
PostPosted: Tue Feb 18, 2014 11:00 am    Post subject: Reply with quote
Multi69's...What does pull of the backing plate mean? Did you mean pull off the backing plate? That would be a lot more work. Is pulling off the backing plate really necessary just for a spot weld?
Also, Is it advisable or even possible to drill a hole through the spring in order to spot weld it or should the spring merely be welded on each edge?
Just hoping to clear things up before I get started....Thanks!
Hyperspace...What is a portapak ?
Thanks,
Tom
Multi69s
Multi69s is offline
PostPosted: Tue Feb 18, 2014 3:02 pm    Post subject: Reply with quote
Tom,
If you can get plenty of clearance to work, then you don't have to pull off the backing plate, but if it looks iffy, then take it off. What I meant by do not use gas, is do not use an oxy / acet torch. Any type of gas welding will over heat the spring and remove its temper. If you have a drill bit that is sharp enough, then drill a center hole and plug weld it as Jeff mentioned. This will not only help to keep your heat down, but if the spring is welded at both ends, it may make it very difficult to turn the star wheel.
69 road Bug 2110
My builds
