type IV crankshaft needle bearing
timatt
timatt is offline
PostPosted: Thu Jun 09, 2011 8:10 am    Post subject: type IV crankshaft needle bearing Reply with quote
Can someone tell me what is involved with removal of the transmission input shaft needle bearing from the crankshaft? Is a puller required? I tried to pull it out with my finger with no luck.
Thanks
Tim
'79 Westy
aeromech
aeromech is offline
PostPosted: Thu Jun 09, 2011 8:17 am    Post subject: Reply with quote
Something like a slide hammer with a hooked end would work.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
rockerarm
rockerarm is offline
PostPosted: Thu Jun 09, 2011 8:25 am    Post subject: Reply with quote
Tool stores sell a specific pilot bearing puller for this. But a sweet trick if the bearing hasn't fallen apart or gotten too hot is to pack the entire area behind the bearing with a heavy grease. Then use a mainshaft/clutch centering tool and insert into bearing. Tap with a hammer and if it is not stuck too tight, it will come out. Not sure if those plastic clutch centering tool will work.
timatt
timatt is offline
PostPosted: Fri Jun 10, 2011 7:52 am    Post subject: It Worked Reply with quote
I've heard about using grease to remove a starter bushing for years but never had the opportunity to try it. I tried it last night for the pilot bearing and it worked. I cut a piece of aluminum rod on the lathe to fit the pilot busing and Bingo; came out after a few bangs with a 5 lb hammer.
Tim
'79 California Westy
rockerarm
PostPosted: Fri Jun 10, 2011 7:55 am    Post subject: Reply with quote
YEAH !! Simply amazing that physics stuff! Have a good one, brother.
jpeters
jpeters is offline
PostPosted: Wed Jun 19, 2013 5:27 am    Post subject: Reply with quote
Any other tips on removing the needle bearing? I tried the grease trick last night and I don't think enough space exists behind the bearing to allow the grease to push it out. Maybe a thicker grease would work.
'73 Westy (dual stock carbs, SVDA w/ compufire)
'68 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=484180
'65 Westy SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=435614
'65 Bug
'63 Bug
neverdnf on Instagram
jpeters
jpeters is offline
PostPosted: Wed Jun 19, 2013 7:02 am    Post subject: Reply with quote
I searched "pilot bearing" and was able to find some additional ideas. Looks like I'll be trying the chisel, then the dremel if all else fails.
'65 Bug
'63 Bug
Wildthings
Wildthings is offline
PostPosted: Wed Jun 19, 2013 8:59 am    Post subject: Reply with quote
Buy or rent a pilot bearing removal tool. If you try a chisel you will find out about the quality of steel used to make bearings.
jpeters
jpeters is offline
PostPosted: Wed Jun 19, 2013 9:06 am    Post subject: Reply with quote
One guy even mentioned putting shavings from a bar of soap behind the bearing instead of using grease and then pounding in the dowel in order to push out the bearing. I actually think that might work. I don't think the grease was working on mine because the grease was too light.
'65 Bug
'63 Bug
vwmaniaman
vwmaniaman is offline
PostPosted: Wed Jun 19, 2013 9:39 am    Post subject: Reply with quote
I put a long screw with 2 washers thru the bearing, put a nut on the outside threaded end and used a crow bar. Out it came. Cheapo instant puller. Put PB Blaster all around it first though and wait 15-20 minutes.
Working on a VW is like fun with a friend!
65 Beetle
75 Westy "Pumpkin Van"
86 Westy "Brown Betty"
87 Cabrio
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
vwmaniaman
PostPosted: Wed Jun 19, 2013 9:42 am    Post subject: Reply with quote
Forgot to say the screw is small compared to the center hole of the washers. They are a sloppy fit on the screw and edges grab the inside edge of the bearing.
65 Beetle
87 Cabrio
aeromech
aeromech is offline
PostPosted: Wed Jun 19, 2013 9:54 am    Post subject: Reply with quote
Look, maybe you guys don't know what a slide hammer is so here:
I'm not saying that you need to go buy a special tool like this but just look at it and you should understand how it works. All you need to do is grab the bearing on the back side with a metal hook and then whack it out of there using a heavy object. You can use a 2 pound hammer head, a hook, and connect them with wire or cable.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
