Basic Cylinder to case sealer question
Goto page Previous  1, 2
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
modok
modok is offline
PostPosted: Sun Jun 12, 2011 10:09 pm    Post subject: Reply with quote
have yall LOOKED at where the jugs go in the case?
how is the sealer going to escape out of there and get in the oil?
It's wedged in the gap between the cylinder skirt and the case.
Glen Urban
RockCrusher
RockCrusher is offline
PostPosted: Sun Jun 12, 2011 10:19 pm    Post subject: Reply with quote
Well....even though that makes perfect sense and only an idiot could F it up I think I will still write a stern letter to ALL the major vehicle manufacturers tomorrow and insist they stop using this evil RTV on all their engines immediately. I never realized until djkeev pointed it out that the stuff was so terrible. Laughing
Yeah....don't use it under the oil pump cover or to seal the block halves but the cylinder seal? Come on now!
RC
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
610-800-0569 (voice mail is Total Home Media.....soon to be changed)
Lettuce
Lettuce is offline
PostPosted: Mon Jun 13, 2011 1:51 am    Post subject: Reply with quote
djkeev wrote:
Question, why doesn't my Type I service manual printed in 1976 mention this?Dave
I agree. Some of the guys I know that worked with/for VW at the time do not remember ever dropping the paper gaskets either. Silicone is a "high performance" item that came around later. I use silicone on my cylinders but either way will work. I use anaerobic sealer for the oil pump and plate Cool
old school was is to install paper gaskets dry
djkeev
djkeev is offline
PostPosted: Mon Jun 13, 2011 6:27 am    Post subject: Reply with quote
Too funny RocKCrusher! You really only need to send that letter out to the current manufacturers of air cooled VW engines though. RTV has it's uses in many Other manufacturers applications.
Your engines, do as you wish, I'll dig out the silicone bits and fix them for you years down the road.
Anyone find that VW service bulletin yet?
Dave
(o\ ! /o) (o)=l=(o)
1974 Super Convertible
http://www.thesamba.com/vw/forum/viewtopic.php?t=482968&highlight=rust+repair
Creating a 69 1/2 Ghia Convertible out of a 69 Coupe and a 70 Convertible
And the newest arrival!....... 86 Vanagon Westy!
RockCrusher
PostPosted: Mon Jun 13, 2011 6:56 am    Post subject: Reply with quote
Although I absolutely DO use RTV for the cylinder seals you will never need to pick out any bits from my work. As mentioned by someone else here.....proper use is the key. If someone just blobs the stuff on it is surely going to be a mess and potential disaster. One things for sure, we can agree to disagree. There is more than one way to do most things successfully and well. Glad you didn't take my reply the wrong way. Smile
RC
ALB
ALB is offline
RC
At last...some people talking some sense in this thread!!!
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
Slalombuggy- Now I understand my trust issues...
Almost Alive
Almost Alive is offline
PostPosted: Mon Jun 13, 2011 9:07 am    Post subject: Reply with quote
Mooosman wrote:
Three-Bond #1211. I've used it on barrels, case halves, head studs, etc. Use just enough to make a very thin film, let it set up a minute, and put it together. I've never had a leak using it, on any VW or motorcycle engine I've used it on.
Japanese motorcycle makers have used Three Bond for decades, with no gaskets and with no leaks. If it works in those applications, it'll work on an ACVW.
Nick
Three-Bond is astounding. I use it on every engine I build and I've never had any leaks even after customers have brought me back overheated engines. Use sparingly of course. Anything more than about 1/16" around the cylinders or 1/32" layer for the case halves is too much.
Rest in peace Morgan.
Almost Alive Air Cooled - See my adds for new & vintage parts, new and rebuild engines as well as heads.
NOW SELLING BLACK GRADE 10 ENGINE HARDWARE
Click to view image
mark tucker
mark tucker is offline
PostPosted: Tue Jun 14, 2011 2:42 pm    Post subject: Reply with quote
hmm 3 bond, is that like yamaha bond2 or 3????
Almost Alive
PostPosted: Tue Jun 14, 2011 2:56 pm    Post subject: Reply with quote
http://www.threebond.co.jp/en/product/series/sealants/1200list.html
1200 Series (Silicone-based liquid gasket and potting agents)
This silicone-based liquid gasket fills gaps on a flange surface and thus completely prevent leaks. When cured, it forms an excellent rubber-like elastic body offering excellent resistance to vibration and shock. Also it has an excellent resistance to heat, and effectively seals joints that are subjected to high temperature. Select the product that best meets the needs for a particular location or set of working conditions.
Features and uses
1211
Low viscosity, fluidic, and excellent workability.
Can be used with solid gaskets and it can be used for temporary fixing of O rings.
Corrodes copper and copper-based alloys. Can not be used for copper and copper-based alloys in tightly-sealed state.
You can see the break down for the 1211 a little lower on the page. Commonly about $20-$25 per tube.
Click to view image
Mooosman
Mooosman is offline
PostPosted: Tue Jun 14, 2011 4:01 pm    Post subject: Reply with quote
Three-Bond makes Yamabond, Hondabond, and Fujibond (OEM Subaru sealer). The #1211 I used is similar to Yamabond #4 or Hondabond #4 (same thing).
It works great on case halves. Subaru engine cases go together just like a VW engine, and Subaru uses just a thin coat of Three-Bond between the case halves from the factory. They've been doing it that way for decades with no problems, and no leaks.
You can also use Permatex Moto-Seal, which is available at any regular parts store (Autozone, O'Reilly, etc.). It is just Permatex's own version of Three-Bond. I don't know how well it holds up, though.
Nick
(o\ ! /o) '69 Beetle---Subaru EJ22 powered---SOLD
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Thu Apr 26, 2012 10:46 pm    Post subject: Reply with quote
"I tend to go with the theory that silicone ANYWHERE on an air cooled VW engine without an aftermarket full flow oil filter is a major major no no"
I tend to disagree with that statement too. One of the biggest down falls of america's best selling pickup engine is the filter itself. The lint off of the cheaper paper oil filters clogs up the screens for the variable valve control valves and an engine rebuild is the only real fix. Oh, they use RTV on their engines too.
RTV is fine for certain parts of an engine. I wouldn't use it to seal the case halves. The key, as mentioned earlier, is to us it correctly. Remember, if you see it squeezing out, that's how much is squeezing in.
I like ultra grey for use on aluminum, especially near coolant. Ultra Black for all other uses.
Gordo.
modok
modok is offline
PostPosted: Thu Apr 26, 2012 11:13 pm    Post subject: Reply with quote
permatex "ultra grey" is reinforced, stronger, for filling larger gaps.
Like if you wanted to use it on the cylinders to form an "o-ring" between the cylinder skirt and case.
I do not think the grey would be needed anywhere else, there are very few larger gaps
Silicone is effective if you use the right kind for the application
But don't take my word for it, I sealed one of my engine cases together with ketchup, it's leaking a bit now, seems to be from under the cylinders, I used black silicone on the cylinders, maybe I shouda used ketchup there too?
Glen Urban
KopfenJager
KopfenJager is offline
PostPosted: Thu Apr 26, 2012 11:51 pm    Post subject: Reply with quote
We have used aviation form a gasket (permatex) for years. Our old VW machinist, who retired would machine our cylinder spigots just right so the cylinders would slide in with a slite tap of the hand. Our new bozo opens em up to where you can almost rock the cylinders back and fourth Shocked . He says thats not where the cylinders seal, they seal on the lip of the barrels and the sides of the case. Any hoo we have switched to Ultra black silicone for our barrels because the permatex wasn't sealing em. If new this I would have sent my case elswhere Evil or Very Mad . Still permatex and silicone is what works for us.
SI VIS PACEM PARA BELLUM
flemcadiddlehopper
PostPosted: Sat Apr 28, 2012 6:11 pm    Post subject: Reply with quote
Modok wins ...Ultra grey for cylinders.
Like this. not too much.
notice with spacer in place Ultra grey squeezes out, not into engine.
Another line of Ultra Grey on the spacer again and drop it into the case ready to be torqued down.
Gordo.
bugninva
bugninva is offline
PostPosted: Sat Apr 28, 2012 8:04 pm    Post subject: Reply with quote
When its squeezing out that much, you've used too much.
I prefer to refer to everyone as my "bitch".
bartman
bartman is offline
PostPosted: Sat Apr 28, 2012 9:32 pm    Post subject: Reply with quote
Yeah, but the squeezeout is harmless. I think his point is that there is no silicone squeezing in.
I do it the same way and when I pull the jugs there is a very thin layer that extends about a quarter inch or so down the skirt due to the bit of clearance between the parts. It's never been enough for me to say, "whoa, this is a problem!"
Remember, kids------> KCR Transmissions SUCKS
neil68
neil68 is offline
PostPosted: Sat Apr 28, 2012 9:33 pm    Post subject: silicone Reply with quote
For years, I've used Permatex orange or blue silicone RTV for the cylinder base. Just enough to squeeze out of the shims...seals perfectly Smile
Neil.
"Real men run drums."
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.8 seconds @ 104 mph
http://www.youtube.com/watch?v=FF2gCti3dro
udidwht
udidwht is offline
PostPosted: Sun Apr 29, 2012 2:18 am    Post subject: Reply with quote
Kuril - K2 or Hylomar HP
bugninva
bugninva is offline
PostPosted: Sun Apr 29, 2012 5:59 am    Post subject: Reply with quote
I'm aware of that, and agree that is likely the point... I commented because it was stated "like this. not too much".... yeah, it was... Wink
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 2
