hotrod100 Samba Member
Joined: September 07, 2011 Posts: 77 Location: Bullhead City, AZ.
Posted: Thu Nov 03, 2011 11:30 pm Post subject: |
Here's mine. At least the fronts anyway! They are 235/75R15 Goodyear Wranglers on BTR 15X5 wheels with 2.5 BS. It has a 6 inch wider beam with Fox 2.0 coilovers and rack & pinion steering. The rears are going to be 31-10.5's on BTR 15X7 wheels.
Ken48442 Samba Member
Joined: August 29, 2010 Posts: 112 Location: Holly, MI
Posted: Sat Nov 19, 2011 9:06 pm Post subject: |
Just put these on. BF Goodrich All Terrain TA/KOs. 235/75 in front and 31x10.5 in the back. Steel spoke wheels with reverse offset. Front tires don't rub. I get full turn left and right withoutthe tires hitting the car.
racergti Samba Member
Posted: Mon Nov 21, 2011 8:08 am Post subject: |
I'm putting the parts together for a budget baja build and one of the items in question is wheels. I have a set of Riviera wheels (the modern style with the flat pad on the spokes, not the rounded spoke vintage type) but read on a porsche 914 website that these wheels are just street cruiser wheels and not intended for anything more demanding than running to the burger joint.
My intention is to make a dual purpose car. Beyond some street driving for fun, I'd like to run the dunes in Michigan and around the midwest. I have no interest in rock crawling so I won't be too hard on them relative to side-load. I'm not particularly smitten by these wheels but I already own them, they are aluminum and I'm on a budget.
Anyone got experience with Rivieras offroad? _________________ boost = displacement |
auslander Samba Member
Joined: January 07, 2003 Posts: 1831 Location: Heart Of Dixie
Posted: Mon Nov 21, 2011 10:18 am Post subject: |
I've had no issues with them, i've had 7x15's and 215/75's on them...
_________________ Zombie
Wandering...Have you found what your looking for?
66 POS Bus
69 Class 11 Beetle
71 Cat-Look Beetle
64 Old Skool Baja
74 "Swamp" Thing
!!! F**k Cancer !!!
Time's Tide will Smother You
"You can't throw a rock in Long Beach without hitting a tweaker" Steve Tucci |
Bob Elgin Samba Member
Posted: Wed Apr 18, 2012 11:16 pm Post subject: Mountian buggy Suspension |
im in the process of building my spatz buggy again, first refresh since 1989, its bee all over Colorado with this suspension
I run 15-31x10 firestone on rear with this setup and it will climb any mountain in Colorado
mick cassidy Samba Member
Joined: June 30, 2009 Posts: 136 Location: Los Angeles
70BajaVert Samba Member
Joined: August 05, 2005 Posts: 10 Location: Bloomington,IN
Posted: Fri Jul 06, 2012 10:50 am Post subject: |
Here is my daily driver:
Front: 215/75R15 BFG MTs on 15X5 CMS wheels, torsions adjusters and Thing spindles, 10" stroke Fox shocks double bypass w/piggyback resi.
Rear: 33X9.50X15 BFG MTs on 15X7 CMS wheels, torsion adjusters and 3X3 arms, 930 CVs, 12" stroke Bilstein shocks w/ remote resi. |
McGruff38 Samba Member
Joined: September 17, 2012 Posts: 33 Location: So Cal
Posted: Tue Oct 30, 2012 8:20 pm Post subject: |
Manx102 wrote: |
Running these Padla Trak "stagger cut" for 36 years in the sand on our Manx. They are 16.50-15 mounted on 18" rims. We run a 1835cc with a very low end cam which gives us a very strong and responsive first gear and with this size tire that is what you need for good all-around performance in the dunes.
What I have learned in all our years and different sand tires is wider is better as it gives you more floatation and bite in the sand. But you have to match the power and weight of your Baja or buggy to the tire as you can easily overmatch them with too wide of sand tire.
What did you do to prevent the fenders from digging into the top of the tire when the suspension compresses?
I have a 64 dune buggy with chrome coil overs on the back. Other than that the suspension is stock. I tried running a set of 29x15x15 goodyear terra's on a 15x15 rim this past weekend in the sand. If I was really delicate it was ok, but if I hit a dip hard the suspension would compress enough to make the fender lip hit the top of the tire. Whats the easiest way to solve this problem? |
Vince@SDHQ Samba Member
Joined: December 21, 2012 Posts: 30 Location: Gilbert, AZ
Posted: Fri Dec 21, 2012 9:24 am Post subject: |
Method Rims and Yokohama Tires
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Fri Dec 28, 2012 7:31 pm Post subject: |
Vince@SDHQ wrote: |
Are those Super Diggers on the back? What kind of Yokohama's are those on the front? I raelly ike the look of your ride.
Tim |
Posted: Mon Dec 31, 2012 8:24 am Post subject: |
Casting Timmy wrote: |
Vince@SDHQ wrote: |
Tim |
They are Diggers in the rear. The front's are a tractor tire pretty much, but a lot of guys race on them.
http://sdhqoffroad.com/33yokohamasuperdigger.aspx _________________ Vince@SDHQ |
Posted: Sun Jan 06, 2013 7:07 am Post subject: |
Thanks again for the links and info |
buggy man Samba Member
Joined: January 23, 2013 Posts: 135 Location: AUSTRALIA
Posted: Thu Jan 24, 2013 3:24 am Post subject: |
hey quick question, whats the go with coilovers?
it would be stupid to run them with torsion bars as the coilovers will have much the same effect.
So do people take there torsion bars out? if so how does everythig stay together?
im taking about rear irs and balljoint front btw. in the rear could you do away with the springplate and torsion bars all together? and just run good trailing arms and coilovers to hold the weight, with limiting straps and bumpstops?
sorry if this has already been covered.. |
marcelo cenora Samba Member
Joined: October 27, 2009 Posts: 31 Location: sao paulo brazil
Posted: Tue Feb 12, 2013 2:55 pm Post subject: |
my old 84 orange, waiting for new weels... but can wait more time hehe |
HILLBLAZER1326 Samba Member
Joined: June 16, 2013 Posts: 200 Location: Franklin, NC
Posted: Tue Jun 25, 2013 2:49 am Post subject: Lift spec's? |
Marcelo, how did you get the lift on your bug? Look's great |
don't_bug_me Samba Member
Posted: Mon Aug 12, 2013 5:25 pm Post subject: |
215/65/15 fronts and 275/60/15 rears on chevy cragar 8"x 5lug 4-3/4 on 1" adapters, doesn't seem to stick out to far and has the stance I was looking for on a daily street driven baja buggy with stock suspension. Plenty more to do yet, hoping to have her ride ready by spring.
like2gofast Samba Member
Joined: August 17, 2013 Posts: 2 Location: Center Point, Texas
Posted: Sat Aug 17, 2013 10:31 am Post subject: front end |
[quote="CopperBaja"]
thext94 wrote: |
bajaanyone? wrote: |
They do make those tires still. I just ordered 4 Theyre just racer only |
Oh sweet! I've been looking everywhere for them, where did you find them? |
Discount Tire can get them. 7.00x15
You can get them in Yokohama, Hercules?, and Nankang.
[/quo Hey I dig that front end set up. How wide is that beam and what what are the specs on those trailing arms?te] |
Ecothing Samba Member
Joined: August 08, 2012 Posts: 14 Location: Phoenix, Az
Posted: Fri Aug 30, 2013 9:02 pm Post subject: |
Method beadlocks 15x7 with 30x9.50's |
( . Y . ) Samba Member
Joined: September 16, 2013 Posts: 15 Location: United States
Posted: Tue Sep 17, 2013 8:21 am Post subject: |
rick.d.brown wrote: |
Here's my contribution from the UK...
195R15 Colway MT fronts on 4" CMS rims with a-arm.com suspension.
31x10.5R15 Maxxis MT rears on 6" CMS rims with Eagle Performance 3x3 arms & coil-over conversion kit in the photos but rear tyres are now 33x10.5R15 BFG MTs.
3" lift on the body to give tyre clearance on the arches through the full range of suspension movement.
Fox 2.5 remote reservoir coil-overs all round. Not sure about the suspension travel but hope for about 10-12" at both ends |
Love your buggy. Mid travel buggies get me going. Too bad steering wheel is on the wrong side. |
dexter69 Samba Member
Joined: August 30, 2013 Posts: 61 Location: spring branch tx
Posted: Thu Sep 19, 2013 7:33 pm Post subject: |
Love those wheels!
Ken48442 wrote: |
