vws-microcars4jim Samba Member
Joined: September 25, 2005 Posts: 337 Location: Chicago
Posted: Wed Jul 16, 2014 1:58 pm Post subject: |
A friend showed me this dune buggy pickup recently. It does not match any pickups in the DBA or others seen here...Any ideas on the maker and value?
He has a 1962 title, and it is fairly complete. Round taillights are dated 1966.
Thank you experts for your help! |
ShortStuff Samba Member
Joined: August 01, 2011 Posts: 74 Location: Seattle, WA
Posted: Wed Jul 16, 2014 3:15 pm Post subject: This sits on a Bus chassis |
What is it?
Bob Elgin Samba Member
Unlimited1 Samba Member
Posted: Thu Jul 17, 2014 6:49 pm Post subject: Oddball body need ID, if you can |
No ID under hood removal or on body, Hood is separate from body a PITA to remove, I had to remove it as there was no fuel gauge installed (who does that?) in the tank, no more dipstick for me, lol
I have a 1964-7 swing axle transmission and did the internal grind mod to be able to fit a 200mm flywheel that i attached to the 1970 motor, other motor is 1973-74 and had the 180mm flywheel on it from the transmission.
I was not going to swap the 180mm flywheel as the motor produced more hp,
The info came from a Porsche 914 engine builder/racer (Black Forest Racing, Denver NC)Very patient and a very helpful guy.
If i do the later model independent axles (not a swing axle) I can move onto a 5 speed Porsche transmission. So that means the transmissions i have (1 Was just recently re-built) I will probably sell. This is a no rush project for me.
I really want to have a tube chassis with the roll cage similar to the new myers dual buggy before going on the road..but i have no ID or specs to fit a "ready Made chassis". Custom might be the way to go.. i would prefer the side rails be on the outside of the body and the roll bar to be Inside but Bolted to the outside Side rails.
Fitting the body on a fully welded chassis might pose another problem..so many type out there very hard to choose a correct application..it looks like 100" or 110" wheel base might fit..I will have to measure it eventually..
I made a general drawing of the front as the pic i had got lost and it is not local to where i am (YET) lol
it can fit 2 adults comfortably in the back, or 3 kids..
yes my drawing of the front (below pic , but better than nothing
AkioOhtori Samba Member
Posted: Fri Aug 01, 2014 6:48 am Post subject: Manx Clone ID |
Ok... so I am trying this again before I start my own thread. I'd like to find out why type of Manx clone I have and, better yet, get some history of the maker.
What I've got ID wise:
Flat Fenders
Fiberglass dash molded with the hood
Single Hood ridge
Inset to mount front plate below the "bumper"
The dash looks like it used to be 100% fiber and the aluminium added later. It also looks like there used to be a squarish hole on the passenger side that has been patched.
The tail box has been cut out by someone, so no help there.
According to the Dune Buggy Archives this can only be a "Dune Duster Mark I" but that isn't right.
Here a a few photos. Many more in my gallery:
Thoughts? |
scooterick86 Samba Member
Joined: August 11, 2014 Posts: 17 Location: league city, TX
Posted: Mon Aug 11, 2014 6:53 pm Post subject: newbie trying to figure out what make this one is |
I found a frame that I wanted and it came with this body and top.
Now I pretty much have two projects but I think I might build this one fast to have something to drive. And take my time on the other one. |
doubravsky Samba Member
Joined: July 30, 2014 Posts: 133 Location: Riverside, CA
Posted: Wed Aug 20, 2014 12:38 pm Post subject: |
Looking at this buggy.... tried the DBA and it looks like a Dune runner?
dickcharlton Samba Member
Joined: February 09, 2004 Posts: 257 Location: Victoria, B.C., Cold Canada
Posted: Wed Aug 27, 2014 12:01 pm Post subject: |
please identify my body i just picked up. i thought it was a sears rascal but am having second thoughts based on other rascals. ie: unattached dash, rear seat area, tail. it has blue metal flake paint underneath the yellow.
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sat Sep 06, 2014 7:13 am Post subject: |
dickcharlton wrote: |
The rib on the hood and the rear which looks like it had the small square license mount (that has since been cut out) both say early Rascal. It had a dash of some kind which is gone now so it could have been any kind. |
Posted: Sat Sep 06, 2014 1:52 pm Post subject: |
Here is the dash that came with it. It doesn't have a bracket to mount to the body. It only has a home-made bracket fiberglassed into the dash.
(my wife is a good helper.)
daddrod Samba Member
Joined: October 06, 2014 Posts: 10 Location: Kingston Ok
Posted: Mon Oct 06, 2014 5:49 pm Post subject: |
Work in progress. Any ideas?
joescoolcustoms Samba Member
Posted: Mon Oct 06, 2014 9:00 pm Post subject: |
I do not know what it is daddrod, but I like the front hood and bumper.
Welcome to the Samba! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
TDIvan Samba Member
Posted: Wed Oct 08, 2014 6:31 pm Post subject: |
Picked this up today, Manx clone of some sort. I looked through the archives and haven't found anything distinguishing about it.
Goofy taillight placement:
Has two raised ridges in roof:
Lace pattern painted on lower part of body:
_________________ still driving the holy snot out of buses |
TDIvan Samba Member
Posted: Thu Oct 09, 2014 7:02 am Post subject: |
PO said it was titled as a 61 (pan went missing a while back?).It does have a flat deck, no battery tray or spare tire well. Anyone have any ideas what it is?
monomanx Samba Member
Joined: September 25, 2004 Posts: 715 Location: Southeast
Posted: Thu Oct 09, 2014 2:20 pm Post subject: |
It has nice tail lights... |
BeauTrippie Samba Member
Joined: January 02, 2012 Posts: 145 Location: Tennessee
Posted: Thu Jan 01, 2015 9:33 am Post subject: style? |
Is this a Bandito? I looked on the DBA and it seems to be the closest thing.
Any help would be great. My buddy wants to sell it, but we want to know more about it so we sell it for the right price.
_________________ 73 Bay Transporter
73 Super Beetle |
vdub411 Samba Member
Joined: August 14, 2007 Posts: 264 Location: Mid Michigan
Posted: Mon Jan 05, 2015 3:17 pm Post subject: |
Rescued this from the woods here in Michigan. The plate on it has registration tags from 1976. Haven't been able to identify it on DBA. Another add to the x-files.
_________________ 1975 Baja Bug
1972 Type III Fastback
B&N Rattler Buggy
SandRails Coming Soon!!! |
Posted: Mon Jan 05, 2015 3:38 pm Post subject: |
vdub411 wrote: |
That is a Rattler. B & N Fiberglass out of Springfield Ohio manufactured them. Very high quality body. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Mon Jan 05, 2015 5:41 pm Post subject: |
Very cool. Thanks for the help. The pic in DBA threw me off with the paint and wing but it is definitely a rattler. This deserves to be back on the road......after I finish my rail. _________________ 1975 Baja Bug
B&N Rattler Buggy
Posted: Mon Jan 05, 2015 7:28 pm Post subject: |
One of the unique things that B&N Fiberglass did was to make their own seats. Nothing new about that, but, they made the backs of the fiberglass bucket seats in matching gell coat so once covered, the back was "pretty" too and matched the body.
The body's will take a really wide tire. The only original color I have seen is this kind of Turquoise. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
