sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
i_am_cool_fred Samba Member
Joined: June 26, 2004 Posts: 1743 Location: Benton, AR
Posted: Thu Jul 07, 2011 6:43 am Post subject: |
how would something like that go on?? i'm trying to see how and can't. _________________ proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV |
Posted: Thu Jul 07, 2011 7:08 am Post subject: |
the threaded end goes through the clutch arm and the cable is fed around the pulley _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
hubcap Samba Member
Joined: December 05, 2006 Posts: 135 Location: Sussex UK
Posted: Thu Jul 07, 2011 9:22 am Post subject: My 02c |
Hi
Creative sell an off the peg kit here. They had to develop it for there airbag beams. It (as is most stuff in the UK) is not cheap, but knowing them it will work well. I guess you could source the items in the states and make your own.
Here is the link
www.creative-engineering.com/index.php?page=shop.p...;Itemid=26
Hope this is of interest. |
Posted: Thu Jul 07, 2011 9:25 am Post subject: |
sub-hatchtim wrote: |
the threaded end goes through the clutch arm and the cable is fed around the pulley |
but then what does the pulley attach to from there?? how does it get it's leverage?? _________________ proud owner of a defunct 1979 sunroof kombi
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Thu Jul 07, 2011 12:25 pm Post subject: Re: My 02c |
hubcap wrote: |
Hi
Here is the link
That looks decent, but you have to crawl under the bus to check or fill the fluid? I don't doubt the Wilwood slave cylinder is awesome. I'm only using the cheap-o one for now because I happened to have it. |
63single Samba Member
Joined: May 02, 2004 Posts: 122 Location: west coast of fla.
Posted: Thu Jul 07, 2011 2:12 pm Post subject: |
i_am_cool_fred wrote: |
but then what does the pulley attach to from there?? how does it get it's leverage?? |
the cable i believe attaches to the tranny _________________ 58' pg/sg silo fridge westy
76 911S |
T2 Samba Member
Joined: February 15, 2003 Posts: 187 Location: Yachats, Oregon
Posted: Fri Jul 08, 2011 6:49 am Post subject: |
Stupid idea and not nearly has high end but why couldn't you use the master cylinder mount from a junk bus and a typical brake master cylinder and just use pipe plugs for the holes your not using? I imagine this would be way cheaper overall and would make the clutch pedal work like the brake pedal? |
33 Willys Samba Member
Joined: January 28, 2008 Posts: 344 Location: Alamogordo, NM
Posted: Fri Jul 08, 2011 12:39 pm Post subject: hydraulic clutch |
One more time...the clutch arm at the transmission needs about 1 3/8" throw. A pull type slave sylinder needs about 1 3/8" throw to properly match the travel of the throwout bearing arm. When the clutch pedal is depressed to the floor the clutch master cylinder must move enough fluid to move the slave cylinder about 1 3/8". Granted, some of the mismatch can be taken up by the adjustments on the clutch pushrod and slave cylinder. If you find a brake M/C to do this fine but a new MATCHING M/C is only $43. Note that newer cars with mid engines use hydraulic clutches. |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
