repair of sliding door track
69doublecab
69doublecab is offline
PostPosted: Fri Jul 08, 2011 8:07 am    Post subject: repair of sliding door track Reply with quote
Has anyone done a satisfactory repair of the sliding door track? Is there any source for the parts? I don't really want to put the whole factory part in, just the rusty track and outer rocker. The rocker part from Bus Depot didn't fit at all!
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Nov55 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
Aug58 pressed bumper 23 window
To New owners: 69 doublecab ,71 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
goffoz
goffoz is offline
PostPosted: Fri Jul 08, 2011 8:27 am    Post subject: Reply with quote
Hi AL
Which track?...I assume the lower one, right
Do you have bad rust, holes?...or is it just pitted?
On my 2wd the door was loud and growlie, so I wire brushed and sanded the heck out of it....the applied a good coat or 2 of marine grade epoxy
I was so impressed with how quiet the slider was after that, that I decided to go further...I stripped down the lower roller and lubed and polished it ..then just as an experiment I put down a strip of 2" wide 6mill HDPE tape(the type used for wrapping connections in underground pipe joint.
Man that door is so quiet and smooth now...it still amazes me Shocked
ps:the tape has held up for 2months now, and looks unworn
69doublecab
PostPosted: Fri Jul 08, 2011 1:29 pm    Post subject: Reply with quote
The metal is completely rusted/ worn thru in places. I need to make a patch and fasten it in somehow, then put on a new outer rocker. I was hoping someone made a repair part. GERSON??
time to start with T3 parts?
Al
Al Brase
Vanagons:
82WestyMan
82WestyMan is offline
PostPosted: Fri Jul 08, 2011 3:30 pm    Post subject: Reply with quote
goffoz wrote:
... On my 2wd the door was loud and growlie, so I wire brushed and sanded the heck out of it....the applied a good coat or 2 of marine grade epoxy... stripped down the lower roller and lubed and polished it ... put down a strip of 2" wide 6mill HDPE tape... that door is so quiet and smooth now...it still amazes me :shock:
I'd don't mean to hijack this thread but I know I'm not the only one in the forum with an embarrassing loud sliding door... I hate having to open and close it late nights in a campground.
I think your above repair would make a great thread (perhaps a sticky???), complete with pictures, of the complete process.
... sounds like I have a new item for my "Westy To-Do" list
"The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine
goffoz
goffoz is offline
PostPosted: Fri Jul 08, 2011 7:42 pm    Post subject: Reply with quote
Al
Pick and pull and a battery operated sawsall....or maybe someone nearby has a parts van you can attack , and have it welded in?
kamzcab86
kamzcab86 is offline
PostPosted: Fri Jul 08, 2011 7:50 pm    Post subject: Reply with quote
It's on my lengthy to-do list, for sure. This thread http://www.thesamba.com/vw/forum/viewtopic.php?t=381226 doesn't have photos, but it does have a decent description and the OP used UHMW tape (same basic stuff??).
~Kamz Anxious
2016 Golf GTI S
carterzest
carterzest is offline
PostPosted: Sat Jul 09, 2011 10:49 am    Post subject: Reply with quote
I bought passenger and drivers entire rockers for $200/side, cut out for me by a local shop. Lots of junkyards would do the same thing, just show them what you want. Last post of this thread
I will have some more pics in the coming days. Slider track is marginally bad, but, I did not want to do the other repairs without also repairing the slider track. It is/was extremely crusty and sure to be an issue in the near future.
Happiness=Portland, Oregon in the rearview mirror!
