Super Beetle steering box adjustment??
Johnny Martin
Johnny Martin is offline
PostPosted: Sat Jul 09, 2011 1:32 pm    Post subject: Super Beetle steering box adjustment?? Reply with quote
Can anyone post any old literature on adjusting a steeringing wormgear box thats starting to bind and to replace the steering u joint thats connected to it? Someone told me today I dont have to buy a new steering box I can just adjust a skrew on it.
1971 SUPER BEETLE
AE489501 carb Solex 30 pict-2 with dist (I think its stock) 0 231 137 021
113 905 205 M
dont hide it, ride it...
smokey503
smokey503 is offline
PostPosted: Sat Jul 09, 2011 2:05 pm    Post subject: Reply with quote
I can't post anything for you, I can tell you how I did mine.
I raised the front end so the front wheels were off the ground. There is a inspection plate in the trunk on the right, facing the car. It is about 2 inches and you just take a screwdriver and pop it off. Below that is the steering box.
You will see on top what somewhat looks like the screw/nut on the rocker arms. Loosen the nut and take a screwdriver and either loosen the adjusting screw till you feel it in the worm gear, or tighten the screw too see which does better.
When I did mine, I tightened the adjusting screw and it made the steering tighter and I lost the shimmy. I did not get to drive the car for much longer to see if it held cus my wife wrecked the Bug.
If a car travels the speed of light, would the headlights work?
Johnny Martin
PostPosted: Sat Jul 09, 2011 2:36 pm    Post subject: Reply with quote
Yarrr bummer about the wrecked bug. Was the crash due to the steering?? Ill try to loosen the skrew. Ill let you know how it goes. Thanx for the info.
1971 SUPER BEETLE
113 905 205 M
smokey503
PostPosted: Sat Jul 09, 2011 2:39 pm    Post subject: Reply with quote
Nope!!!
Due to the wife not knowing how to drive a damn car in the rain, Or in any weather.
smokey503
PostPosted: Sat Jul 09, 2011 2:41 pm    Post subject: Reply with quote
I forgot to mention, you should be able to feel the worm gear when you loosen or tighten the adjusting screw. If you turn the screw and it is loose, you know you are out.
Some say that you can fill the steering box with gear oil. I did not do that. Probably would help a bit.
