Melting heat exchanger? 82 air cooiled
drlong
drlong is offline
PostPosted: Sun Jul 10, 2011 5:58 pm    Post subject: Melting heat exchanger? 82 air cooiled Reply with quote
Is it possible / has anyone seen the insulating material inside a air cooled heat exchanger melt? I have this terrible plastic/ chemical melting smell. When I looked under the bus it looks like soldier has came out of the weep hole on the left heat exchanger and dripped back on to the exhaust.
If it's not broke it must not be a VW
FNGRUVN
FNGRUVN is offline
PostPosted: Sun Jul 10, 2011 7:49 pm    Post subject: Reply with quote
Is the blower hooked up to the alternator? If it is, is the air flow blocked or restricted?
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
drlong
drlong is offline
PostPosted: Mon Jul 11, 2011 3:45 pm    Post subject: Reply with quote
the air tube from alternator to the left side heat exchanger was off. It is back on now.. It really looks like the heat exchanger was melting... NOT GOOD....
Mr Brown
Mr Brown is offline
PostPosted: Mon Jul 11, 2011 8:22 pm    Post subject: Reply with quote
Mine were melted by the previous owner, the ducting forward of the heat exchangers was clogged.
drlong
drlong is offline
PostPosted: Tue Jul 12, 2011 6:19 am    Post subject: Reply with quote
That's crazy. What is the melting point of Aluminum?
RCB
RCB is offline
PostPosted: Tue Jul 12, 2011 6:23 am    Post subject: Reply with quote
Can you post a picture of it.
xoo00oox
xoo00oox is offline
PostPosted: Tue Jul 12, 2011 6:50 am    Post subject: Reply with quote
I also have seen them melted to a pudle of aluminum in the bottom of the heat exchanger.
drlong
drlong is offline
PostPosted: Tue Jul 12, 2011 9:09 am    Post subject: Reply with quote
Yes it seems as if it has puddled in the bottom and had dripped out the weep hole. It looks like aluminum has a melting point of 1200 f.. I'm afraid I have engine damage now. This must be made of cheaper stuff than the one in say a 1972.. kinda crappy. time to do a leek down test.
drlong
drlong is offline
PostPosted: Tue Jul 12, 2011 9:14 am    Post subject: Reply with quote
Maybe they are not made of exactly aluminum I can''t see it really getting to 1200F
