ax2ron@hotmail Samba Member
Posted: Thu Jul 14, 2011 12:06 pm Post subject: 78mm crank and 82mm crank |
Does the case have to be machined to install a 78mm or 82 crank? what has to be done in order for it to work? How does a larger crankshaft enlarge the CC of the motor? |
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Thu Jul 14, 2011 12:23 pm Post subject: |
oh boy. Those are 2 good questions.
Questions that someone who has built a motor, should have the answers to.
The case doesn't have to be 'machined' it can be clearanced by hand. Search on that topic.
The last question is the one that scares me _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
mxracer Samba Member
Posted: Thu Jul 14, 2011 12:27 pm Post subject: |
I'm a relative noob here too so I'll share some "noob wisdom" with you before you get hammered. Search
That being said. Yes the case needs to be machined to create room/clearance for the longer stroke of the crank.
The 78 or 82MM "larger" crank refers to the stroke (up and down) of the rod and piston connected to it. The two factors that make up the displacement (cc's) of the engine are the bore and stroke. Bore is the piston (or cylinder) diameter and stroke is the distance the piston (connected to the crank via the rod) moves in the cylinder.
BTW that is the very high level answer on displacement. Google "calculating displacement" and read on.
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Thu Jul 14, 2011 1:24 pm Post subject: |
Clearance the case by hand? yep...I can do that with no sweat.
Have some bastard files...a skill saw...pair of tin snips just in case...set of strong chisels...large hammer to use...elect drill with a set of grinding tools.
Why bother with a pro machine shop when I can do it myself and save $$$$. |
jsturtlebuggy Samba Member
Posted: Thu Jul 14, 2011 2:04 pm Post subject: |
Never used a skill saw.
Die grinder carbide bits,WD40, an sanding rolls is what I have used.
It is time consuming, but worth while if you have more time than money. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Thu Jul 14, 2011 2:11 pm Post subject: |
So when you install a stroker crankshaft, you need to install new class B pistons. The longer piston gives you more CC? Im guessing even after reading the aircooled article, the piston is longer along with a longer stroke from the crankshaft? |
Quickstraw Samba Member
Joined: August 06, 2010 Posts: 164 Location: Bakersfield, California
Posted: Thu Jul 14, 2011 2:19 pm Post subject: |
Quote: |
The longer piston gives you more CC? |
The longer stroke of the 82mm crank gives you more cc'c |
Posted: Thu Jul 14, 2011 2:25 pm Post subject: |
Stroker pistons usally have the wrist pin sitting higher in piston.
Meaning it is closer to top of piston and oil ring.
Pistons usally as shorter skirt for clearance.
Remember piston travels further away from center of crankshaft at top of stroke and closer at bottom of stroke.
Also longer connecting rods are use for some applications.
I have no idea how much mechanical knowledge or ability you have.
Building a stroker engine is really not something that you would want to try for your first build. _________________ Joseph
Elrod Motorsports
Posted: Thu Jul 14, 2011 3:14 pm Post subject: |
Have you built an aircooled engine before or any engine for that matter? If you have that helps. _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
66' His
57' Theirs
63' Hers
Posted: Thu Jul 14, 2011 4:26 pm Post subject: |
I was reading the off road modifications book and in engine performance chapter they said i could use the 85mm pistons and a stroker crank to get a @1800cc motor. i didnt understand how changing the stroke would make more CC, without adding more size to to the combustion chamber. I could see more compression with a stroker crank, its traveling farther. So i would need to get different pistons too, right? So in a stoke motor the pistons arent using the full stroke of the barrel? The barrels dont have to be longer?
I have taken the motor apart with a friend that knew what he was doing, so i observed more then i assembled, dissasamble no problem. |
ColtonMelson Samba Member
Joined: May 31, 2011 Posts: 247 Location: Medford, OR
Posted: Thu Jul 14, 2011 4:43 pm Post subject: |
from my understanding you can use up to a 76mm crank (this would make your 1600 into a 1745cc per http://www.aircooled.net/gnrlsite/resource/specgeninfo/calcs.htm ) and not have to change pistons. you would have to shim the P&Cs or get different size connection rods, not sure. ask about it you might be able to do this and save some money. _________________ -------------------------------
Im In Love With A SandRail... My Girl Friend is Pissed
1835cc, Scat c35 cam, duel 34s, 1-1/2in merged stinger, Stock Heads, 3rib bus trans, in 2 seat SandRail |
Posted: Thu Jul 14, 2011 5:01 pm Post subject: |
thanks for answering the question honestly.
A stroker motor requires a lot of measuring to accomplish right. You need to measure things you don't even know exist, in a simple breakdown/reassemble.
I think you CAN accomplish it with the help of several people on this forum, but to me, honestly build a stock motor and drive it and deal with those problems, before you spend a lot of money and something goes wrong, then it's all on you.
If you read this forum for 3 months, you would feel a lot more confident. Then build your motor _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
66' His
57' Theirs
63' Hers
Posted: Thu Jul 14, 2011 5:12 pm Post subject: |
I have had this bug for 25 years, it was one of my first cars. I kind of think its time to build a lil bigger. Im thinking a 1776 or so, im running 31' tires that require more power. I would like to have two motors, the 1600 thats in it and a bigger one for fun. So i could use a 76mm crankshaft without doing much clearancing? The 88mm slip in pistons too. Im reading, that some people say you can use the same stock connecting rods? I am searching things out too, i appreciate your advice guys. Ive been reading all sorts of stuff on this site for a while, so much to take in. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3559 Location: viroqua wi.
Posted: Thu Jul 14, 2011 5:28 pm Post subject: |
Do not use 88mm slip in pistons! 88 machine in's, great. I vote for stock 69 stroke or at most 74 stroke and 90.5 pistons. You will have to have your case opened up for the bigger cylinders but little or no clearance for the 74 stroke. |
Posted: Thu Jul 14, 2011 5:29 pm Post subject: |
you might even get lucky and not have to clearance the case for a 76mm Crank. i have heard some talk on here about the smaller cranks dropping right in, depending on the case number, and im sure it is still recommended to check and recheck that you are going to clear everything. i would say that also is a good thing to look into before paying some one for something you didnt need _________________ -------------------------------
Posted: Thu Jul 14, 2011 5:33 pm Post subject: |
http://cal-look.no/lounge/index.php?topic=8007.0
Read this thread. The first pic shows notching in the case to clear the rods. _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
66' His
57' Theirs
63' Hers
Posted: Thu Jul 14, 2011 5:34 pm Post subject: |
Damn you bsairhead you beat me to it.. but running the 88s are his choice. Some people gamble some dont. _________________ -------------------------------
Posted: Thu Jul 14, 2011 5:53 pm Post subject: |
I just saw a pair of thick walled 88's for sale on here, slip in i think. Maybe they were machine in 88s, no they said you only had to get heads machined only.
What book would be best for building a bigger Vw motor. Any good book? How much was the bug video? |
Posted: Thu Jul 14, 2011 6:07 pm Post subject: |
this is the list that DarthWeber gave me and said to read before i open my case lol
I'd recommend you get the following books and read them before you start taking anything apart:
The VW Bentley Manual
Tom Wilson's How to Rebuild Your VW Engine
John Muir's Idiot Manual
The Bug Me video on engine rebuilding
All of these give you a different slant on rebuilding VW engines but if you take the time to read (watch) what they have to say then I think you'll be much better prepared to tackle a rebuild.
I figure im gonna get 2 maybe 3 of them before i start _________________ -------------------------------
