Welchmaster Samba Member
Joined: January 26, 2011 Posts: 445 Location: Milwaukie, OR
Posted: Thu Jul 14, 2011 5:30 pm Post subject: Dometic CF50 portable cooler/ freezer |
Does anyone know the price of this unit or have one to review? i know Engel is suppose to be the best, but im curious with Dometic's version. seems to have a lot of good features. posts pictures of yours if you have a similar one!
Thanks
http://www.dometic.com/enus/Americas/USA/RV-Produc...taid=81811 _________________ ________________________
90 2wd Orly Blue Multivan weekender. "Van-Duzer"
"Further up, further in!" |
canasync Samba Member
Posted: Thu Jul 14, 2011 6:02 pm Post subject: |
I have seen these for as low as $520. The Dometic and Waeco are the same brand. Just as Norcold and Engel are the same.
The Engel uses a reciprocating compressor that has been around for over 30 years and is very reliable. Whereas the Dometic uses a Danfoss compressor that has become popular since about 2005. The Danfoss is a newer technology that draws less power, is quieter and produces less vibration. We will have to check back in another 20-30 years to see if the Danfoss has the same reliability, however from what we've seen in the RV industry the Danfoss is on the right track.
Even though there are people that like the Engel more in the following forum the second guy on this thread went for the Dometic/Waeco for the same reasons that I have chosen them. In the end its hard to say which one really is better and I don't think that you can go wrong with either brand.
http://forum.ih8mud.com/camping-outdoor-gear/233581-engel-mt45-classic-vs-new-mr040-plastic-2.html _________________ 1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift |
subter Samba Member
Posted: Thu Jul 14, 2011 7:59 pm Post subject: |
Thanks CanaSync,
that was very helpful. the reason i wanted to look elsewhere is the Engel is crazy spendy and i have a connection through Dometic where i should be able to get the item at cost.
ill post more when i have pricing from them.
Thanks _________________ ________________________
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9920 Location: Orbiting San Diego
Posted: Thu Jul 14, 2011 8:25 pm Post subject: |
While you are at it, how about checking into the CR-1050 and CR-1065 fridges?
http://www.dometic.com/c62cd8b4-cc5c-4231-8c3b-70ebc3067271.fodoc
Mark
Welchmaster wrote: |
Thanks CanaSync,
Thanks |
Posted: Thu Jul 14, 2011 8:42 pm Post subject: |
crazyvwvanman wrote: |
Mark
Thanks CanaSync,
Thanks |
Mark, for the Westy or for your Yatch? ill see what i can do! _________________ ________________________
Posted: Thu Jul 14, 2011 8:46 pm Post subject: |
For Vanagon campers, of course. The smaller one is the Dometic version of the Vitrifrigo and Truckfridge that many people install to replace the stock Westy fridges. The larger one needs more work to go in but might be worth the trouble.
Mark
Mark, for the Westy or for your Yatch? ill see what i can do! |
MacFhearguis Samba Member
Joined: March 03, 2011 Posts: 179 Location: Flagstaff
Posted: Thu Jul 14, 2011 9:07 pm Post subject: |
I have had experiences with both Norcold and Dometic.
I used an MT45 Norcold for several years in my Jeep, Landcruiser and other vehicles. From MX to MT it never failed, and ran daily for 2 years when we lived in LA.
I sold the Engel to upgrade to a larger fridge with a family of four. I bought a used Dometice 80L, the kind that can freeze/fridge or be a fridge only. Now, mind you it was used, but I still expected the fridge to work properly, and from the moment I got it, the compressor wouldnt cycle. After having the local RV place look at it, and several calls to customer support at Dometic, the problem was determined to be a bad circuit board causing a failure.
Not acceptable in my opinion, considering the environments I had taken my Engel through.
After doing a bit of reading, especially on the various different Australian boards, the Dometic/Waecos have had issues with electronic in the past, and while vastly improved, they still have minor annoyances.
If you are looking for a good quality, lower cost option, the Dometic will work for you, but do your research.
If you are buying on price point only, check out Whynter fridges.
I'll be going with an Engel again. Heck, maybe even a National Luna.
It says something about the Engels that you can buy a 20 year old fridge that works just fine, if just in need of some love on the outside. Those Sawafuji compressors are top notch. |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Thu Jul 14, 2011 9:15 pm Post subject: |
canasync wrote: |
The Danfoss is a newer technology that draws less power, is quieter and produces less vibration. |
I had the opposite experience going from a Vitro Frigo to an Engel. The engel makes less noise and less vibration and I think it uses less power, but I haven't measured consumption on either for a 24 hour period...
The VF would also warm up a little inside in hot weather where the engle always stays at the set temp and has no problem freezing a fridge full of food to below 0* F when you accidentally roll the knob to "freeze" when you care cleaning it
I don't like the top loader though and will be getting a 60 quart front loader from engel when I have the dough... _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10367 Location: Sunshine Coast B.C.
Posted: Tue Sep 11, 2012 12:56 pm Post subject: |
While you are at it, how about checking into the CR-1050 .....
I have a line on a used 2009 year Danfoss powered ....
Edit: will post new thread or search more. Sorry.
1988 West DIY 50º ABA
VE7TBN |
