Erik G Samba Member
Joined: October 16, 2002 Posts: 13283 Location: Tejas!
Posted: Mon Sep 15, 2014 1:05 pm Post subject: |
NICE!!
v6-star Samba Member
Joined: August 31, 2006 Posts: 193 Location: Neuenhaus/Deutschland
Posted: Mon Sep 15, 2014 2:47 pm Post subject: |
That is a temperature sensor.
I need the point to switch between warm up run and normal running.
Quote: |
What is sensor inside rocker chamber?
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Mon Sep 15, 2014 5:19 pm Post subject: |
Das ist zehr schone..... (My German is not good )
With the Swiss army history, the original (and blended in) primer paint, and lowered stance with Fuchs..... That is a stunning Kombi!!!! _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
lil_azza Samba Member
Joined: December 18, 2012 Posts: 249 Location: somerset
Posted: Tue Sep 16, 2014 12:55 pm Post subject: |
nice van such a great thread too |
Posted: Sun Oct 05, 2014 4:19 pm Post subject: |
Hi,
I drove ~1200km with the EFI.
We had only 4 hours for mapping in the night.
But it will runs very well.
Only the cold start up was not good.
But few tests later is the cold start no problem.
The engine need with 1500kg and 3800-4000 rpm 9,5l gas on 100km.
130km/h with a AT Gearbox.
Posted: Tue Feb 24, 2015 4:50 am Post subject: |
Momentan baue ich gerade einen 1776 zusammen,
90,5mm Mahle K&Z, Pauter Nocke, leichte Stößel, 1300er AB Köpfe.
Ich hoffe noch das ich richtige Drosselklappenteile bekomme oder die 34er PCI umbaue auf 39mm und Düsen in den Saugrohren.
Wenn das alles nicht klappt kommt kurzfristig erst mal wieder die 1600i Drosselklappe drauf.
Ist ein AS Motor.
Dann 4std in die Waschanlage
Dann Köpfe und Block ausrichten und größer fräsen für die 90,5mm Zylinder.
Dann noch Plexiglas Scheiben zum auslitern gefräst.
Kurbelwelle ist wieder zusammen mit neuen Lagern
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Tue Feb 24, 2015 8:20 am Post subject: |
You have a nice looking Kombi brother! I dig the low stance and all the hard work you are putting into it. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Thu May 21, 2015 5:44 pm Post subject: |
Hi,
I'm testing new wheels for the bus.
I want to put the Fuchs on my Ovali.
Here the Porsche steels.
4,5 & 6x15 with 165/50 & 195/65
Here the JJ Cosmic in 5,5x15 with 165/45 & 195/65
A new speedo
It fits to the 165/50 tires
New housing for the Kms display
The display is ok, it lookes broken on the picture.
I dove ~4000km on EFI.
It runs perfect.
I hope the new engine runs so good too. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu May 21, 2015 8:15 pm Post subject: |
how about a set of stock 15s? _________________ regards
Uli
Posted: Sun Oct 11, 2015 2:02 am Post subject: |
Last meeting this year
Posted: Mon Apr 18, 2016 7:05 am Post subject: Re: 1956 Windowbus - Kombi |
My new rims.
6x15 revolution.
