Trojan36 Samba Member
Posted: Tue Oct 04, 2011 7:04 pm Post subject: will it fit ? |
just bought a 79 beetle vert that needs an engine . Rather than spend 3-4 grand buying something ready to drop in,I have a 1500 single port that came with another bug,and is just taking up space on my garage floor. Would it be reasonable to do a rebuild and drop that in the 79 untill I can scape up the cash for something with a lttle more poop?will the engine tins fit? will cooling be a problem? thanks. _________________ 67 bug
68 bug
79 bug vert
no money and even less sense....( even worse impulse control.) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Oct 04, 2011 7:06 pm Post subject: |
It will fit but the cylinder tins on a FI engine are wider so you'll have to fabricate some filler panels to close off the wider engine bay. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Oct 04, 2011 7:09 pm Post subject: |
thanks _________________ 67 bug
68 bug
79 bug vert
Glenn Mr. 010
Posted: Tue Oct 04, 2011 7:12 pm Post subject: |
You'll also have to wire up a regulator for the generator on the 1500 and remove the ring on the pressure plate so it matches the later throwout bearing. _________________ Glenn
Member #1009
#BlueSquare |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Tue Oct 04, 2011 7:39 pm Post subject: |
You'll also need to plug one of the fuel lines [no return needed with the 1500], remove the fuel pump under the tank and I'm not 100% sure but you might not be able to hook up the heater boxes the FI motor have a different set-up.
If you are planning on rebuilding the 1500, why don't you just rebuild the FI motor?
-jeffrey _________________ Der Kleiner Kampfwagens |
Jamies74sb Samba Member
Joined: March 22, 2011 Posts: 398 Location: Fresno ca
Posted: Tue Oct 04, 2011 9:56 pm Post subject: |
Won't pass smog if u have to do that ? |
Posted: Wed Oct 05, 2011 4:51 pm Post subject: |
thanks for the replies. can't rebuild the FI engine as I don't have one.(no engine...gone...empty....long boring story)...Car will be registered in Ohio ...no emissions testing... , : o ) _________________ 67 bug
68 bug
79 bug vert
