my 1974 tintop westy...with pics and engine problem
Goto page 1, 2  Next
frankenwabbit
frankenwabbit is offline
PostPosted: Mon Jul 25, 2011 8:53 pm    Post subject: my 1974 tintop westy...with pics and engine problem Reply with quote
Up until yesterday my bus was running rather well; driving all over creation including up and down Big Bear, CA. It's a '74 tintop westy with a recent rebuilt 2.0L (PO said it was rebuilt by one of the guys at Fat Performance). Prior to driving 1500 miles, I did a tuneup and valve adjustment. A friend did say that after my valve adjustment, a couple of my valves sounded a lil loose.
Anywho, I heard some clanking noises coming from the engine compartment. Noticed the alternator was loose but the bolt was tightened. Also noticed that the vacuum hose to my SVDA distributor had come off the vacuum tee. I tee'd back the vac line.
Started her up again and it was still clanking but as I rev'd the motor the sound went away. I let it idle and then it died.
Motor is not seized. Starter turns the motor over. Nothing leaks other than the normal oil leak. Motor doesn't catch and fire. I checked for spark from the coil itself and from each spark plug wire and I'm getting spark.
Then I checked the spark plugs themselves. #1 was dry; #2 was a tiny bit wet from fuel, #3 and #4 were drenched in fuel.
Dried out the spark plugs, and tried again. No luck.
Any ideas? (sorry for the long post)
Last edited by frankenwabbit on Mon Jul 25, 2011 11:34 pm; edited 7 times in total
SGKent
SGKent is offline
PostPosted: Mon Jul 25, 2011 9:05 pm    Post subject: Reply with quote
you have some messes to clean up before you try to start again. That is what I see.
Start with fixing the alternator or whatever else is clanking.
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
Desertbusman
Desertbusman is offline
PostPosted: Mon Jul 25, 2011 9:06 pm    Post subject: Reply with quote
After driving the 1500 miles I'd carefully check the valves again. Adjust if necessary and keep a record of any gap adjustments you make. Any of the three routes up to Big Bear are real demanding on a bus and it might have gotten fairly hot.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
frankenwabbit
PostPosted: Mon Jul 25, 2011 9:28 pm    Post subject: Reply with quote
Yeah...I'm gonna check the valves next.
It doesn't sound right.
Any ideas?
RatCamper
RatCamper is offline
PostPosted: Mon Jul 25, 2011 9:50 pm    Post subject: Reply with quote
Well now. What I hear there sounds to me like air going in and out of every cylinder and no compression. That's ...that's concerning. It's either a nice pair of badly warped heads, blown out head gaskets (If yours has them), a complete set of holed pistons, valves unable to close for some reason or ???
You did that with the spark plugs in right? Without plugs in an engine tends to sound like that.
Also is it out of fuel? usually facets have that kind of rattle only when there is no fuel.
Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002.
El_Güero
El_Güero is offline
PostPosted: Mon Jul 25, 2011 9:52 pm    Post subject: Reply with quote
Sad
seems its spins with very low compression, id check that, could be shreded cam, valve train issue or something like that...
"Sé que en algún lugar sus dedos pelean con un tornillo" (Remembering Carlos Amat)
"Si quiero estar encabronado
hazte a un lado...cabrón!"
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Mon Jul 25, 2011 10:04 pm    Post subject: Reply with quote
Hmmm, it didn't actually sound like low compression to my ear. The cranking seemed even across all cylinders. Pull off the valve covers and have a look. Have you tried starting it with your foot into the throttle a bit? See if that gets it going at least. You need to do some investigating, but I have a funny feeling you will be okay.
"I will gladly pay you Tuesday for a hamburger today."
frankenwabbit
PostPosted: Mon Jul 25, 2011 10:05 pm    Post subject: Reply with quote
Plugs were in when I cranked her over. I haven't run a compression check yet.
When I checked the plugs, there was no oil on them, just a couple of fuel-fouled plugs (because I was pumping the gas pedal prior)
The pump is switch activated. So I flip the switch first and then turn the ignition switch. I did add fuel to the tank.
I also shot some starter fluid into each carb and the motor wouldn't fire.
Lionhart94010
Lionhart94010 is offline
PostPosted: Mon Jul 25, 2011 10:27 pm    Post subject: Reply with quote
To me it sounds like it’s not firing at all ;0), IMO due to fouling perhaps or maybe incorrect timing (too many lose items already re-check it…) as others have already said, readjust valve in case you have open valves causing lack of compression, re-check the plugs for fouling, if any fuel is present on plugs; disconnect power to coil and crank the engine with plugs out to make sure there aren’t any fuel puddles in the cylinders. (When I get any fouled plugs, I pull them all, clean them, then heat the tips on my gas stove to burn off any contaminants, let them cool, then re install them) to try to solve the fouling, check your fuel pressure, take the carbs apart and clean them out, check floats… also make sure your carb linkage is synced correctly, try again. If that does not work you could do a leak down test and see if that turns anything up…
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 72 KG GT;0) 12 JSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
Westfabulous
PostPosted: Mon Jul 25, 2011 10:34 pm    Post subject: Reply with quote
Lionhart94010 wrote:
also make sure your crab linkage is synced correctly, try again.
I've heard it said that these engines were powered by hampsters, but crabs are just scary. Wink
RatCamper
PostPosted: Mon Jul 25, 2011 11:09 pm    Post subject: Reply with quote
I spent a lot of time listening to a non-firing engine the past few days, and that sounds like a lot more than that.
Have you tried hand cranking the engine using whatever means you have? Probably not the best way but I use some variety of spanner or socket and bar on the alternator pulley. See how much of a fight the engine puts up on each compression stroke. It should take a reasonable amount of effort to turn it during compression strokes. Ie once every 1/2 turn of the crank.
While you are at it pop the distributor cap and make sure the rotor is rotating.
That whistle really does sound reciprocal to me. I've heard similar under a few circumstances. Check _everything_
Lionhart94010
PostPosted: Mon Jul 25, 2011 11:10 pm    Post subject: Reply with quote
Did you mean hampsters, or hamsters, or was that just a typo ;0)
frankenwabbit
PostPosted: Mon Jul 25, 2011 11:11 pm    Post subject: Reply with quote
Plugs were fouled because I was pumping the gas pedal repeatedly. Anywho...I'm gonna start with a valve adjustment first and go through each thing one at a time.
In the meantime...pics of the bus.
interior was pretty thrashed so I got some WCM foam; washed the fabric; hand stitched the loose welts and tears; and re did the seats.
Also redid the steering wheel. It looked like the Death Star. JB weld, paint, and leather wrap on the steering wheel done wonders. Also redid all the horn wiring. Ugh.
Oh...and I have one of these! York compressor is missing, but lines, condensor, evaporator, etc are intact.
nodrenim
nodrenim is offline
PostPosted: Tue Jul 26, 2011 5:14 am    Post subject: Reply with quote
OK, so you have a 2 liter engine. Does it have solid lifters or hydraulic? You did not say which and if you try to adjust the hydraulics the same way you do solids, it will not be the same, and vice-versa. Hope you get it solved, that looks like a sweet ride to me. Peace
frankenwabbit
PostPosted: Tue Jul 26, 2011 7:55 am    Post subject: Reply with quote
They're solid lifters. Thanks! Off to check the valves...
sneakyjack
sneakyjack is offline
PostPosted: Tue Jul 26, 2011 9:53 am    Post subject: Reply with quote
IN regards to the AC - I have the compressor out -
there should be a hole where it was, drivers side rear near battery.
search sneakyjack and my thread will come up with some pics.
Nice front seats.
Nothin left to do....
www.idolmakerfilms.com
NY NJ AND NEW ENGLANDERS - and anyone else -
check this event out for 2012 - Fun VW gathering
http://www.thesamba.com/vw/forum/viewtopic.php?t=461925
werksberg Premium Member
werksberg is online now
PostPosted: Tue Jul 26, 2011 10:41 am    Post subject: Reply with quote
Question here: Do tin top camper have wood or vinyl head liners?
Werksberg Products....Products that work!
I will NOT be going to BOR Sac. on May 26th as I hurt my back last weekend prepping my van!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!"
frankenwabbit
PostPosted: Tue Jul 26, 2011 10:54 am    Post subject: Reply with quote
Nice front seats.
Thanks! I just re-used the same seat covers. I wasn't about to spend 300 on new seat covers. There were some fabric tears, vinyl welt/piping coming off so I took care of it by hand-stitching as best as I could.
As for the AC, I'll definitely look at your pics I'm considering not using a York compressor...maybe run a more modern compressor but have the compressor sit above the motor and run the belt north/south to a modified smog pulley.
More interior pics later..
frankenwabbit
PostPosted: Tue Jul 26, 2011 10:55 am    Post subject: Reply with quote
Mine aren't original and had replacement wood panels so my guess would be wood.
Desertbusman
PostPosted: Tue Jul 26, 2011 1:34 pm    Post subject: Reply with quote
Wood ceiling. BTW, it's steel and not tin. Laughing And it's not a plastic top either.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
Goto page 1, 2  Next
