Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Sep 13, 2012 7:35 am Post subject: |
Just out of curiousity, what if you swapped your rear arms? That would take your negative camber and give you some positive. Once the engine and trans are in it should settle down almost flat......... |
geoffwg Samba Member
Posted: Thu Sep 13, 2012 12:04 pm Post subject: |
im definatly going to try that, on my other thread on dezert rangers, one of the guys was telling me he has the same arms but are fliped compaered to mine _________________ speed cost money.... how fast do you want to go?
http://www.thesamba.com/vw/forum/viewtopic.php?t=474256 |
vwracin2win Samba Member
Joined: December 04, 2005 Posts: 363 Location: Palmdale, CA
Posted: Sat Sep 15, 2012 7:13 am Post subject: |
nice! i bet thats a good feeling. are you going to be able to run lights in the head light holes? looks a little tight with the shock mount hoops |
Posted: Fri Sep 21, 2012 10:51 am Post subject: |
i was super exited when i got it on all fours!
but as for the lights, i will not be able to run lights in the fiberglass due to the hoops. _________________ speed cost money.... how fast do you want to go?
BajaBug222 Samba Member
Joined: September 04, 2012 Posts: 109 Location: Sahuarita
Posted: Tue Oct 02, 2012 11:53 am Post subject: |
nice build |
Posted: Thu Oct 11, 2012 11:17 am Post subject: |
thanks!
i flipped my arms around and that helped the camber issue,
i also finished up my front fire wall
and i bought a 002 trans!
i started looking it over and it seems to have a 091 bell housing, is there any benifit to this?
then the bellhousing numbers start with 091......... it was made in germany though. _________________ speed cost money.... how fast do you want to go?
Posted: Thu Oct 11, 2012 9:28 pm Post subject: |
What size are those rear tires? |
Posted: Fri Oct 12, 2012 4:45 am Post subject: |
geoffwg wrote: |
thanks!
I thought that may do it! Good job! |
Posted: Sun Oct 14, 2012 1:58 pm Post subject: |
tires are 33-10.5-15 they are on an 8 inch wide rim but i am thinking of going to a 4 inch wide.... seems to be what all the desert guys are running, of course they have bead locks...
hahaha i was about to cut off my frame horns and weld in my own pivots too! _________________ speed cost money.... how fast do you want to go?
bajamike560 Samba Member
Joined: December 11, 2009 Posts: 544 Location: Vancouver WA
Posted: Wed Nov 14, 2012 4:25 am Post subject: |
Is that it, after all this time?????? KIDDING
Looks good.... Keep at it and keep posting.
Mike _________________ Jackpot motorsports |
Posted: Thu Jan 10, 2013 8:36 pm Post subject: |
its been a while but this is what ive been up too.
got my gas tank, 17 to 18 gallon
2.5 10inch foa coil over resis, and i will be getting around 14 inches of travel.
so just have to buy 930 cv`s axles stub axles drive flanges, rear springs and some other do dads and i will be drivable. _________________ speed cost money.... how fast do you want to go?
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Jan 10, 2013 10:25 pm Post subject: |
Great build! _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Fri Jan 11, 2013 6:42 pm Post subject: |
thanks
got my starter so just need to get some paint on the cage and i can fire her up!
but cant drive around because the lack of drivetrain _________________ speed cost money.... how fast do you want to go?
Freakzinho81 Samba Member
Posted: Wed Jan 16, 2013 2:18 pm Post subject: Sick project! |
Your car looks awesome! I was just looking over your build but didn't find much information or pics how you did your steering, I noticed you're not using the vw steering box and upgraded to a rack & pinion system; if you have some time, could you shoot some more pics and kinda go over what you did?
Sorry to bust in your build thread like that but I really need to fix all the shake in my baja!!!!
Thanks really appreciate!
Keep up the good work, it looks sick already. |
Posted: Mon Jan 21, 2013 11:28 am Post subject: |
i will try and get some pics for ya soon, but i just bought the cheaper rack and pinion, i will probably upgrade to somethig a little better here in the future, but to run a rack and pinion you need to buy or make a rack mount, not to expensive, then find the centerpoint on your beam, then mock up your rack and tie rods, i used hiem joints. after every thing is set up you need to cycle through your suspension travel and try at adjust the bump steer to a minimum, you do this by rotating the rack on the beam. if you are using a stock steering colum you might have to do some cutting to be able to mate the two up to each other. hope this helps! ill try and get some pics for ya later.
paint
bumpstops
doorbars
on to electrical! _________________ speed cost money.... how fast do you want to go?
Posted: Tue Jan 22, 2013 8:01 pm Post subject: URRRR |
URRRR... sounds like a lot of work!!! Thanks for all the info, I'll see what I'll do about the "shakes" maybe just replace the tie rods, or change them to hiem joints (that's just a straight exchange right?) and go from there!
Your car is looking sick, the cage came out super nice!
I just finished the electrical on mine, so GOOD LUCK with yours LOL!!! (hate electrical stuff by the way)
Keep us posted |
whitemike Samba Member
Joined: June 21, 2007 Posts: 164 Location: huntington beach
Posted: Tue Jan 22, 2013 9:17 pm Post subject: |
car is coming along nicely. I hope to catch up soon. !! _________________ baja # 3 ! |
