geoffwg`s 1970 build thread
Page: Previous  1, 2, 3, 4, 5, 6, 7
chubby53
chubby53 is offline
PostPosted: Tue Jan 22, 2013 10:24 pm    Post subject: Reply with quote
build looks great. was curious what kind of rear brake drums you are using and how heavy you think you're car is going to weigh?
My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100
AZ-BUG
AZ-BUG is offline
PostPosted: Wed Jan 23, 2013 7:24 pm    Post subject: Reply with quote
Chubby, those are Type 181 (Thing) rear brake drums... direct bolt on to bug IRS rear stub axle, backing plate, brake shoes, etc... just slip the old drum off and bolt on the thing drum... was very common in the "old days" of class 5-1600 and 1/2-1600.
geoffwg
geoffwg is offline
PostPosted: Wed Mar 20, 2013 9:34 pm    Post subject: Reply with quote
thanks chubby! and i think its aroud 2000 to 2300,
and as for your shakes, i know its been a while but my vibreations were due to the front end being out of allingment.
and i finnaly got out to the desert!
heres some vids
http://www.youtube.com/watch?v=i00idDVbbLM
http://www.youtube.com/watch?v=wsR0VjckGZk
http://www.youtube.com/watch?v=CRBefVZl8qM
http://www.youtube.com/watch?v=M-HON_j3ne8
speed cost money.... how fast do you want to go?
http://www.thesamba.com/vw/forum/viewtopic.php?t=474256
azamudio09
azamudio09 is offline
PostPosted: Sun Mar 24, 2013 12:10 pm    Post subject: Reply with quote
before you finished the cage did you have the cage welded to the floor pan with the rear shocks mounted to it?
geoffwg
geoffwg is offline
PostPosted: Sun Mar 24, 2013 4:30 pm    Post subject: Reply with quote
Yes, but the cage was also welded to the torsion housing and frame horns
Hondub
Hondub is offline
PostPosted: Sun Apr 07, 2013 5:50 pm    Post subject: Reply with quote
Sweet build. Looks like it handles pretty good in the dirt. I'm waiting for the videos of the wheels leaving the ground next Twisted Evil
And pictures of it completely assembled?
My Honda powered Class 5 car build.
http://www.thesamba.com/vw/forum/viewtopic.php?p=6599511#6599511
geoffwg
geoffwg is offline
PostPosted: Sun Apr 07, 2013 7:28 pm    Post subject: Reply with quote
thanks hondub! just cause you asked here ya go
my buddie made this edit for me, enjoy Smile
http://www.youtube.com/watch?v=moPlyFrfDhY
first trip! the go pro batt died before we could find any real jumps.
http://www.youtube.com/watch?v=ReS682gWv_8
i was having problems with my carb flooding in the bumps so i made some vents, and that made a huge difference.
i took somemore video today so there will be more pics and vids coming soon.
Hondub
Hondub is offline
PostPosted: Fri Apr 12, 2013 5:44 pm    Post subject: Reply with quote
It may not have been a huge jump but it looked like that handles the jump pretty well.
You know, if you had fuel injection you wouldn't have to worry about the carb flooring out Laughing
geoffwg
geoffwg is offline
PostPosted: Wed Apr 24, 2013 10:45 pm    Post subject: Reply with quote
hahaha that is very true,
i revented my bowl and it made a world of difference,
i have some pics and vids but im having a hard time uploading right now ill try and get them up,
but i might be considering a new engine sistuation soon,
buick 3.8 or big vw?
Hondub
Hondub is offline
PostPosted: Wed Apr 24, 2013 10:52 pm    Post subject: Reply with quote
I'll keep an eye out for them.
Those are two very different options. Personally I think water cooled is the way to go. Half the price, twice the power and reliability, and it won't leak oil after the first oil change Very Happy
If you are planning on sticking with the transaxle you have, I would go with an Ecotec or other 4 cylinder engine.
geoffwg
geoffwg is offline
PostPosted: Wed Apr 24, 2013 10:56 pm    Post subject: Reply with quote
yeah i was looking at the 2.2 ecotec but this v6 is super cheap, just need to figure out the fuel delevery system and im good to go on that, and the trans will be gone through here soon,
Hondub
Hondub is offline
PostPosted: Thu Apr 25, 2013 7:10 am    Post subject: Reply with quote
I don't blame you. That's why I have a V6. It was cheaper than an Ecotec for higher, more reliable horsepower. Mine was pushing the bus box though so now I'm going a whole new route for a trans.
geoffwg
geoffwg is offline
PostPosted: Sun Jun 02, 2013 2:47 pm    Post subject: Reply with quote
well I got a 1915, spent most of the day cleaning the carbs and synchronizing them, (they are weber 44s) I have been adjusting the fuel air ratio set screws and i used a temp gun to check the temp of the headers to see if they were rich or lean, and got the engine too idle and run pretty good, set the timing at 9 degrees, fuel pressure is set too 6 pounds, It seems to stumble at 3000 rpms but once past that it keeps pulling hard. anyone come across this before? should I be adjusting my air bypass set screw? I have each one turned out a half turn. they were bottomed out when I got the engine.
larryvance66
larryvance66 is offline
PostPosted: Sun Jun 02, 2013 7:01 pm    Post subject: Reply with quote
Sounds like you need a little rejetting in there. I'd say try a richer main and see if the stumble goes away. Other than that, Wow! awesome build. I'm jealous, how much time total on all the tube and wiring work?
I got a Volkswagen for my wife....Best trade I ever made!
geoffwg
geoffwg is offline
PostPosted: Sun Jun 02, 2013 9:25 pm    Post subject: Reply with quote
thanks! its blowing a little black smoke when i rev it, could that be the accelerator pump? as for build time... it took two years too be drive able, i did the wiring in a couple days, tube work took a while. part of the reason that took so long was due too cash flow, so most of
that time was waiting on parts.
new engine with my rusty old exhaust, plan on moving the coil too the engine cage.
last run before the 1600 gave out
larryvance66
PostPosted: Mon Jun 03, 2013 3:40 am    Post subject: Reply with quote
I like your cars stance. How far did you push the front out and what arms are you running? (front and back?)
Bashr52
Bashr52 is offline
PostPosted: Mon Jun 03, 2013 6:45 am    Post subject: Reply with quote
Danger will robinson! Webers only like 2.5-3 psi. You are force feeding them at 6 pounds, likely blowing fuel right past the needle/float.
HILLBLAZER1326
HILLBLAZER1326 is offline
PostPosted: Sun Sep 22, 2013 4:36 am    Post subject: Reply with quote
Very nice Baja, love it
Page 7 of 7
