spot welds ?
68nofussbus
68nofussbus is offline
PostPosted: Wed Jul 27, 2011 12:45 pm    Post subject: spot welds ? Reply with quote
welding in a battery tray and a right rear corner in a 68 bus, is it better to spot weld -let it cooll then grind it down or spot weld a little here and there until complete then grind all at once ? Im trying my welding techniques again on this rear corner since i welded a wheel arch in and got it to hot and it sunk in / what a mess , read a lot of forums already so please help a vw brother out ! White Bay Bus
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Wed Jul 27, 2011 1:37 pm    Post subject: Reply with quote
I normally finish all my welds then grind. Just let it cool between spots and go easy when you grind. That can warp metal too.
eminence_front
eminence_front is offline
PostPosted: Wed Jul 27, 2011 2:51 pm    Post subject: Reply with quote
use a compressed air chuck to blow cool air on the welds after each spot weld. That can cool it 60 - 100 degrees quickly.
If you don't have a compressor, just pick up a couple cans of air-duster at your local frys, staples, wal-mart, etc.
68nofussbus
PostPosted: Thu Jul 28, 2011 12:23 pm    Post subject: Reply with quote
im going to use a pneumatic angle grinder to grind down the welds , whats the best grit (course ) of whee/ pad to get ? going to napa tommorow so id like to ask the pros on the samba first , thanks
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Mon Aug 08, 2011 1:15 pm    Post subject: Reply with quote
cold rag -- 3/4 inch of welding -- no more
Experience always triumphs over hearsay and You get to select which theory to believe
