Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Wed Aug 10, 2011 6:36 pm Post subject: My attempt at a transaxle cooler (manual trans) |
I my experimenting with a transaxle cooler/filter for my syncro to see if the oil temps drop on the highway right now it runs at 170-185 on hot day and steep hills.The temp sensor in the trans starts the cooling pump at 150deg and shuts it off at 135deg it can not hurt to filter the oil as well.
westyventures Samba Member
Joined: December 29, 2004 Posts: 2305 Location: Oregon Outback
Posted: Wed Aug 10, 2011 7:30 pm Post subject: |
Looks good, colorful. Where did you locate the pump? I would recommend a guard of some sort for the lower hose, it would be bad to snag it going over some trail debris and lose all the oil. |
Posted: Wed Aug 10, 2011 7:43 pm Post subject: |
westyventures wrote: |
Not to worry the skid plate covers all of the hoses.I got the pump from here.
http://www.rbracing-rsr.com/oilsystems.htm |
Posted: Wed Aug 10, 2011 7:52 pm Post subject: |
Oh, yeah, skid plate... forgot that!
I meant where is the pump located, photo please? <edit - I see it now, the white thing?> |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6304 Location: Honolulu,Hawaii and France
insyncro Banned
Posted: Thu Aug 11, 2011 5:58 am Post subject: |
Interesting.
I see Weddle did similarly for EricA.
Curious to know if a drop in temp will help the longevity with a more powerful engine. |
RicoS Samba Member
RicoS Samba Member
Posted: Thu Aug 11, 2011 8:06 pm Post subject: |
ALIKA T3 wrote: |
Looks like a pretty simple worry free set up |
I like Herman's idea of using a power steering pump much better. Modern power steering pumps are a proven quantity, last damn near forever, are directly driven and cheap to boot.
Richie |
Posted: Thu Aug 11, 2011 8:16 pm Post subject: Re: My attempt at a transaxle cooler |
No, not at all the same setup. Alaric's is plug in and go, no internal oil channels, drilling etc. That's hardly what I'd call 'reinventing' anything. |
HeftySmurf Samba Member
Joined: June 15, 2008 Posts: 879 Location: Washington, USA
Posted: Fri Aug 12, 2011 8:45 am Post subject: |
Looks good Alaric _________________ -Lorenzo
90 GL w/ Bostig |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12102 Location: Port Manteau
Posted: Fri Aug 12, 2011 8:48 am Post subject: |
Is the silver cylinder in between the drain plug and the pump a check valve? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Fri Aug 12, 2011 9:17 am Post subject: |
Zeitgeist 13 wrote: |
Is the silver cylinder in between the drain plug and the pump a check valve? |
That might be the filter that he mentioned.
Looks good. |
Posted: Fri Aug 12, 2011 10:37 am Post subject: |
That is the reusable filter. |
Posted: Fri Aug 12, 2011 10:53 am Post subject: |
Ah hah! When you mentioned a filter, my mind automagically went to a spin-on design and wouldn't move off that thought. _________________ Casey--
y u rune klassik? |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 758 Location: Langley, BC, Canada
Posted: Fri Aug 12, 2011 12:04 pm Post subject: |
What size AN adapters did you use for the fill/drain port connections? I've been mulling over the same thing, but wasn't sure where to attach the inlet/outlet.
Very cool, BTW.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
Posted: Fri Aug 12, 2011 8:20 pm Post subject: |
squeegee_boy wrote: |
Very cool, BTW.
Robyn |
Lets see the fill is1/2 npt the drain is 24x1.5
and the hole you drill in the bottom of the trans for the temp switch is 3/4x16. |
Posted: Fri Aug 12, 2011 8:29 pm Post subject: |
I fired it up to prime it and the hose started weeping gear oil just about the whole length pretty good size mess bad hose I guess. |
Randy in Maine Samba Member
Posted: Sat Aug 13, 2011 5:27 am Post subject: |
And why do you think you need a transaxle cooler? Does it really run that hot? |
Posted: Wed Aug 24, 2011 5:26 am Post subject: |
I have driving with the trans cooler for a few thousand miles now and looking at the temp gauge there is a 40 deg drop in temp. In FL I unplugged it and the oil temp went to 183deg so I pulled over and plugged the pump in and the oil went to 145 deg in less than 2 minutes.I am in MI now and the out side temps are much lower so it is running at 115-125 deg the biggest difference is the shifting where it was very hard or notched to go in to gear it is looser now so shifting is easier. |
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Wed Aug 24, 2011 6:01 am Post subject: |
Thats a sexy setup.
Cant imagine here in New England that the internal temps are as high as in other parts of the country, but that looks like a great solution. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
