Rocco 16 valve carb swap?
Forum Index -> Water-cooled VW Share: Facebook Twitter
dwfronk
dwfronk is offline
PostPosted: Thu Aug 18, 2011 7:19 pm    Post subject: Rocco 16 valve carb swap? Reply with quote
I have an 88 Scirocco and the CIS-E system is MUFFED UP! I am wanting to carb it anyways and i have seen where some ppl are using motor cycle side draft carbs. Is there a specific bike ppl are pulling the carbs off of?
dwfronk
dwfronk is offline
PostPosted: Fri Aug 19, 2011 8:34 pm    Post subject: Reply with quote
Ok so dose anyone know the answer to this?
wbrown45
wbrown45 is offline
PostPosted: Tue Aug 23, 2011 4:33 pm    Post subject: Reply with quote
Not sure of a motorcycle side-draft swap because most of them aren't big enough. Do you mean the side-draft Weber, Solex, or Mikuni adapted off of a car? Those can be made to work very well. This past weekend I put a single Weber on an '82 Rabbit convertible. I hated to take off the F.I., but the parts were going to cost too much for my friend to buy right now. I am pretty happy with it. Check out Redline for a place to start. Surprisingly I found the best place on his kit through J.C Whitney! It was a genuine Redline kit with a Spanish Weber. Who knew!?
OK Thang
hyperformancevw
hyperformancevw is offline
PostPosted: Sun Aug 28, 2011 11:07 am    Post subject: Reply with quote
i have done a few bike carbs on 8vs and 16vs. here is a bunch of info on them and the carbs you are looking for are yamaha r1 carbs late 90's early 00's they are plenty big enough for a fairly worked 16v.
http://forums.vwvortex.com/showthread.php?4647341-Switching-to-Bike-Carbs.-Heres-a-write-up!
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
