Mexikrainian Samba Member
Joined: February 04, 2009 Posts: 127 Location: Reno, Nevada
Posted: Sun Aug 21, 2011 5:22 pm Post subject: How to fix PO's mistake. Help!!! |
Hi, I bought this 67 a couple months ago. All is good except the previous owner hacked the front clip off . I dont even know if this apron will work for my 67?
I know one of the fenders is wrong and the hood has been replaced also. I dont know what years hood would work for 67. My main concern is how do I fix that gap? Should I just put a scab over both, try to fill it in, or find a donor bug(67 may be difficult).
Anyway, advice would be very helpfull. |
schell '59 Samba Member
Posted: Mon Aug 22, 2011 5:19 am Post subject: |
yeah it'll work but you'll have to go back in and re-strengthen that repair...because he has such a gap...you can-t recut it and get it closer as he lost most of the existing steel.
you kight have to band it and fill it. _________________ WWW.401RESTOS.COM
see my "gallery" for more pics other than the website. |
Rex lucy Samba Member
Joined: April 10, 2008 Posts: 227 Location: pleasant plains arkansas
Posted: Wed Aug 24, 2011 2:51 pm Post subject: |
| that gap is not a real biggie if you would fiber glass it. i would use mat on both side. make sure no rust on metal. |
spook Samba Member
Joined: December 30, 2003 Posts: 2034 Location: in the shop 35750
Posted: Wed Aug 24, 2011 3:23 pm Post subject: |
| Rex lucy wrote: | | that gap is not a real biggie if you would fiber glass it. i would use mat on both side. make sure no rust on metal. |
bad _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 4601 Location: Ranson WV
Posted: Thu Aug 25, 2011 9:44 pm Post subject: |
| I agree. It will be welded for sure but I haven't figured the best way to close the gap. I'll think i'll try and recut a bit 1st, then fill the gap with a thin scab on the backside, then try to grind it smooth. |
Posted: Fri Aug 26, 2011 3:22 am Post subject: |
If it were me I'd get the hood fitting nicely, the fenders on and aligned and tack weld it in place. Then, slowly where there are gaps I'd cut it back so the gap was an inch or so, and fab a small strip to weld in it's place. Keep doing that until there is no gap. Just be sure to keep the heat down as much as possible. _________________ My 71 Ghia Been in my family since 1980
My 71 Super Driver
Our VW Club in the WV Panhandle PanairVWs.com |
Posted: Fri Aug 26, 2011 6:55 am Post subject: |
that's the "band" i was talking about....the only way to repair it correctly...you could go over the gap but way better to splice it in.
if the job was done right in the first place, it should have been but welded. _________________ WWW.401RESTOS.COM
Posted: Fri Aug 26, 2011 9:50 am Post subject: |
| sounds good. Thats what seemed best to me. |
Posted: Fri Aug 26, 2011 11:10 am Post subject: |
| What years of bug would you say to get a front clip from?? |
pdivizzle0112 Samba Member
Joined: July 13, 2011 Posts: 256 Location: Toluca Lake
Posted: Tue Aug 30, 2011 12:54 am Post subject: |
| i hate when people replace the front clip along those lines...the best place to cut is from the firewall-forward imo...much stronger..ive noticed that cars that have been cut at that area tend to bounce a lot in the front end |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12415 Location: Eugene, OR
Posted: Wed Aug 31, 2011 8:27 am Post subject: |
| Mexikrainian wrote: | | What years of bug would you say to get a front clip from?? |
Forget buying a different clip and finish welding the brand new clip on it. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6244 Location: N.W. Phoenix
Posted: Wed Aug 31, 2011 9:03 am Post subject: |
X2 Mike _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
