914 tach wiring
porschevw
porschevw is offline
PostPosted: Thu Aug 25, 2011 9:26 am    Post subject: 914 tach wiring Reply with quote
I have a '74 914 and p.o "played" with the wiring to the tach. I can't seem to figure this out. Can anyone tell me how the tach is hooked up. I put a tach in my baywindow westy and all it needed (if I remember right) was power, splice into the dash lights, and run a wire to the negative side of the coil.
Thanks,
Jon
type47
type47 is offline
PostPosted: Mon Aug 29, 2011 5:48 am    Post subject: Reply with quote
tach is located in track 71
http://www.pelicanparts.com/914/parts/Electrical/914_electric_74D.jpg
looks like just 2 wires; black/purple is tach signal
Jim McLeod
155579 11/2010
mtwrench540
mtwrench540 is offline
PostPosted: Sun Sep 04, 2011 5:50 pm    Post subject: tach Reply with quote
what about ground?
87 wolfsberg,74 181w/1915 and lots of patina! learned to fix vw's from hot vw mag in 1964,VWOA instructor,DSM,69 to73,service mgr at different porsche-audi dealers etc,etc,now retired!!! first vw new 64,transplanted 356 eng in 65,400characters are not enough space!!
boxcar
boxcar is offline
PostPosted: Fri Aug 10, 2012 3:18 pm    Post subject: NinefourteenTach Reply with quote
It is a nice addition albeit BIG...
I am wiring up an Electromotive XDI/Cranktrigger unit.
I ran an old 914 tach before triggered off C(-)
Electomotive manual describes this "some older tachometers trigger off the high voltage signal from the ignition coil (c-). These type of tachometeters require the use of a tach amplifier....designed to trigger off a 120 volt signal."
Trying to figure out what the (-)side of the coi is putting out?
Just a 12v pulse? Or 120v as the manual describes...the FI picks up a pulse here also, and i looked but saw no test values in the EFI sticky(nice to have this!!)
Anyway, I bought an amplifier already so I am just confirming theory before i start stripping wires...thanks
mtwrench540
PostPosted: Fri Aug 10, 2012 4:27 pm    Post subject: tach Reply with quote
there only three connections that you need,#15 to ign source,#31 to ground,and last wire(i forgot #) to point side of coil,green wire!
