J. Chesham Samba Member
Posted: Sat Aug 27, 2011 4:13 am Post subject: Fuse box in a 6v '55 Oval |
During full body off resto the wiring loom was replaced and i kept the car as 6v. We seem to regularly have issues with the lights which usually results in a blown fuse, bulbs usually intact.
I have the original 4 x fuse box complete with paper insert but this is in German! I currently have fuses from right to left of red,red,white ,white. Its the white one second from left that seems to blow. All wiring has been checked, earthed etc properly.
I bought a NOS fuse box in order to obtain the missing lid for mine and this one came with white,white,white,blue fuses............
Does anyone know which fuses i should have in a 6v 4x fuse box please? Is the problem that some of them aren't man enough and i need bigger ones?
Any suggestions gratefully received. Thanks guys.
Jacqui |
caseydenise Samba Member
Joined: April 25, 2004 Posts: 1307 Location: Essex County, NJ
Posted: Sat Aug 27, 2011 6:20 am Post subject: |
Here is a picture of my fuse box paper in English
The Samba also has these great diagrams that helped me out
http://www.thesamba.com/vw/archives/info/wiring/bug_toaug55.jpg
I'm 99% sure that there is a small fuse box next to the driver fender next to the gas tank. It should have two fuses for the head lights.
When you say your having a problem, does the fuse hold for a while then blow?? Check the ignition, headlight switch, foot switch, and the battery connection for any problems. _________________
| EverettB wrote: | | That is badass |
billmetric Samba Member
Joined: March 16, 2006 Posts: 995 Location: Columbus City USA
Posted: Sat Aug 27, 2011 11:10 am Post subject: |
Note : is your '55 a semaphore car or bullet turn signals? regardless, there should be no red 16 amp fuses in any '55 fuse boxes, white 8 amp only, also only the small two fuse headlight box next to the gas tank has a lid, the headlight fuses are for high beam only, low beam headlights have no fuse, the 4 fuse box has no lid, observe the lack of hole in paper tags, also note that if you need a red or BLUE fuse (!) you have electrical problems, blue is 25 amp!, what kind of headlights are you running, Euro bulb and reflectors are 35 watt each bulbs, I think early 6V sealed beams should be 35-40 watts, maybe you have an overly powerful headlight bulb(s) white 8 amp fuses are plenty if wiring, switches, are short free,
1955 semaphore harness is same as 1954:
 _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
Motorhead55 Samba Member
Joined: August 22, 2007 Posts: 441 Location: California U.S.A.
Posted: Sun Aug 28, 2011 12:06 am Post subject: |
The ABSOLUTE most important thing for our old 6volt VWs is GOOD, CLEAN connections and switch contacts. Bad or dirty connections cause higher amp draw. The fuse panel spring ears are riveted to the square posts on the back side of the fuse panel. If you can twist the square screw post any then you will have a weak connection at that fuse. A dirty contact in the high/low beam switch can cause dim headlights. Feel with your hand or fingers around the various switches and connections while the load is turned on. If any are warm or hot to the touch then there is the area of high resistance or a poor connection. _________________ 1955 VW BUG European Deluxe Delivered to Holland. 1700cc single port, Zenith 2 barrel. Porsche A drum brakes.
2012 Jetta TDI Sportwagen. Tornado Red, Black interior.
2007 Dodge Cummins Diesel 4x4 6spd stick
1977 Mercedes 240D, 1939 WILLYS pickup |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 9501 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 28, 2011 7:43 am Post subject: |
Plus solder all the riveted connections in the fuse boxes, and the headlight switch makes a huge difference. See the type2.com library for the headlight switch repair article there. _________________ In Stereo, Where Available! |
Snort Samba Member
Joined: April 02, 2005 Posts: 1178 Location: Seattle, WA
Posted: Sun Aug 28, 2011 8:41 am Post subject: Re: Fuse box in a 6v '55 Oval |
| J. Chesham wrote: |
Does anyone know which fuses i should have in a 6v 4x fuse box please? |
Your fuses should all be white, 8 amp. Blowing a fuse in this case has nothing to do with the size of the fuse, but they are doing their job because you have a problem somewhere and the fuses are keeping your new wiring harness from becoming melted goo. |
johnny chingas Samba Member
Posted: Thu Feb 23, 2012 10:02 pm Post subject: Re: Fuse box in a 6v '55 Oval |
| Snort wrote: | | J. Chesham wrote: |
Your fuses should all be white, 8 amp. Blowing a fuse in this case has nothing to do with the size of the fuse, but they are doing their job because you have a problem somewhere and the fuses are keeping your new wiring harness from becoming melted goo. | is this the same for 12 volt cars? White 8 amp fuses? Anyone?? Thanks |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 643 Location: Norway
Posted: Fri Feb 24, 2012 6:52 am Post subject: Re: Fuse box in a 6v '55 Oval |
| johnny chingas wrote: | | Snort wrote: | | J. Chesham wrote: |
For 12V, you need half the size on the fuses, because it only use half the current.
That was the teory. _________________ I got a historic car, every scratch got a history...
My car, aug. 55 / a 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Posted: Fri Feb 24, 2012 8:34 am Post subject: |
1968 owner manual with 12 volt system shows VW still used the 8 Amp fuses.
