Photos of your Volksrod Exhaust
poomwah
poomwah is offline
PostPosted: Tue Aug 30, 2011 7:40 pm    Post subject: Photos of your Volksrod Exhaust Reply with quote
I'm not finding a whole lot of exhausts that are going to look good on a volksrod. This one would look great
http://www.shopatron.com/products/productdetail/pa...leshopping
am I right in my thinking that this exhaust would totally kill my low end?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Aug 30, 2011 7:44 pm    Post subject: Reply with quote
totally.
Glenn
Member #1009
#BlueSquare
vw_hank
vw_hank is offline
PostPosted: Tue Aug 30, 2011 7:47 pm    Post subject: Reply with quote
any exhausts that would work on say A dune buggy, would work on A Volksrod.
PS: some baja exhausts systems would look good also.
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
modok
modok is offline
tee-pee header
it's that simple
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Tue Aug 30, 2011 9:01 pm    Post subject: Reply with quote
make your own !
something no other person has !
Experience always triumphs over hearsay and You get to select which theory to believe
poomwah
poomwah is offline
PostPosted: Tue Aug 30, 2011 9:51 pm    Post subject: Reply with quote
JerryMCarter1 wrote:
make your own !
that's what I probably will do. I just need to decide on a style that's not going to hurt my performance
vw_hank
vw_hank is offline
PostPosted: Tue Aug 30, 2011 9:54 pm    Post subject: Reply with quote
Zoomies Twisted Evil
1302s sunroof..
JerryMCarter1
PostPosted: Tue Aug 30, 2011 9:56 pm    Post subject: Reply with quote
Very good
Back pressure is needed !
Jerry
vw_hank
vw_hank is offline
PostPosted: Tue Aug 30, 2011 10:18 pm    Post subject: Reply with quote
Very good
Jerry
Ok,,,
Zoomies with restrictors Twisted Evil
1302s sunroof..
poomwah
poomwah is offline
PostPosted: Tue Aug 30, 2011 10:49 pm    Post subject: Reply with quote
right now I'm trying to figure the best way to get back pressure, equalization from side to side without a merged header
JerryMCarter1
PostPosted: Wed Aug 31, 2011 9:06 am    Post subject: Reply with quote
I have never heard of anyone in here that knows those formulas.
In fact - years ago - guys would put on headers and their car would turn higher 1/4 mile numbers--Whoaaa
I think you’re in for a great challenge- maybe you should ask that exact question in a new thread
stasher1
stasher1 is offline
PostPosted: Wed Aug 31, 2011 11:14 am    Post subject: Reply with quote
http://www.bobhenneman.info/dragpipe.htm
http://www.bigdogbiker.com/forums/help-wanted/15057-homemade-baffles.html
http://www.nightrider.com/biketech/exhaust.htm
JerryMCarter1
PostPosted: Wed Aug 31, 2011 11:25 am    Post subject: Reply with quote
You are going to have to have a dyno
Jerry
stasher1
stasher1 is offline
PostPosted: Wed Aug 31, 2011 11:36 am    Post subject: Reply with quote
Jerry
Completely unnecessary. How many of the commonly available aftermarket VW exhausts were developed using the results of repeated dyno runs?
The OP is wanting to build a VolksRod, not a drag car, and he's worried about a loss of backpressure from aftermerket pipes killing his low-end. This is a common topic of conversation in the motorcycle world, and in the end, you only have a couple options.
1) Baffles
2) Mufflers
If he can't find mufflers that will offer the combination of looks and performance he needs, baffles may be the only (inexpensive) option.
JerryMCarter1
PostPosted: Wed Aug 31, 2011 11:43 am    Post subject: Reply with quote
Oh - I thought he was after a custom exhaust
poomwah
poomwah is offline
PostPosted: Wed Aug 31, 2011 1:18 pm    Post subject: Reply with quote
custom if I have to, over the counter if I can find it. I have an equal length merged header right now with a baffled stinger. Performance and sound is fine, its just going to look like crap in my opinion.
JerryMCarter1
PostPosted: Wed Aug 31, 2011 4:33 pm    Post subject: Reply with quote
Man I could build you something that would individualize that bug right to the magazines
Make some sketches - I am away from my shop for another month - E- mail me
The looks of the thing is the entire project!
Jerry
schadenfreude
Banned
schadenfreude is offline
PostPosted: Wed Aug 31, 2011 5:03 pm    Post subject: Reply with quote
get the old how to hot rod vw engines book, by bill fisher.
see the exhaust . section pg 43
and how you can't tune it right, because there is no 56" for a rear pipe.
sure there is power to be had over stock, stock is for quiet.
see page 11 curve 3 ,4:1, easy bolt on power (with tune)
steel pipe in 70 is steel pipe in 2011.
in the text he shows the best books written for the equations, if you like to break out the slide rule (grin).
really there can't bet a great set of headers. (not in the true sense like front engine or mid engine cars)
and not look like crap?
and still have some ground clearance ?
and not burn your girl friends legs , when you make her check oil levels.
but do tell.
poomwah
poomwah is offline
PostPosted: Wed Aug 31, 2011 9:17 pm    Post subject: Reply with quote
I would love to have 4 separate pipes, but even if I got the back pressure right, I know the scavenging effect wouldn't be there.
maybe 4 separate, equal length pipes, a connector between both pipes on each side, and a cross pipe going from one side to the other? but where? under the engine would be too low and would have heat beneath my engine rising right into my sump, I could go in front of the shroud, but then I've got a heat source right near my air intake. so....
maybe keep the header I have and put a T at the top and a pipe pointing back down on either side (instead of the u bend and single pipe on a lot of bajas)...
or I could win the lottery and put a turbo on top of my collector lol
I guess I should have also been more specific about the car and called it more "volksrod-ish"
it won't have an engine cover. Just a small "cowl"
poomwah
poomwah is offline
PostPosted: Wed Aug 31, 2011 9:19 pm    Post subject: Reply with quote
better shots of the exhaust
