slug_bug Samba Member
Joined: March 07, 2011 Posts: 14 Location: YAKIMA WASHINGTON
Posted: Wed Aug 31, 2011 7:27 pm Post subject: Please need help with my brakes.. |
hello every one i own a 1962 vw beetle im having trouble with my brakes. when i press down on it the pedal goes all the way down with no pressure. im guessing i need to replace the master cylinder?? could that be the problem???
thanks |
Chris659 Samba Member
Joined: June 14, 2011 Posts: 654 Location: Central Florida
Posted: Wed Aug 31, 2011 8:02 pm Post subject: |
Can you provide more info? Such as where they working then stopped or has this car been sitting a while? Have you checked fluid level, for leaks, bled brakes, adjusted them,etc? |
austin haro Samba Member
Joined: January 01, 2010 Posts: 58 Location: Mexico City
Posted: Wed Aug 31, 2011 8:06 pm Post subject: |
First check brake fluid level, check in the back of your drums or wheels if there is brake fluid leaking, could be the brake cylinder in any wheel, search for leaks in all the system before changing any part in order to avoid changing parts that are ok.
Once you have corrected the problem,
check all the brake system to avoid any future issue. |
wayne1230cars Samba Member
Posted: Wed Aug 31, 2011 8:11 pm Post subject: |
Could be M/C. Is your reservoir full of brake fluid? If not, check for leaks in the system. Steel lines, rubber hoses and wheel cylinders all need to be looked at. Check these out before you replace the MC. You want your braking system working at 100%. This is a 49 year old car and it needs lots of TLC especially on the braking system. Your life and your passengers depend on it. |
Nubby Samba Member
Joined: August 28, 2010 Posts: 605 Location: Down by the river
Posted: Wed Aug 31, 2011 9:28 pm Post subject: |
Well....what's the update? |
gottria Samba Member
Joined: April 28, 2011 Posts: 89 Location: Castro Valley,CA
Posted: Wed Aug 31, 2011 10:31 pm Post subject: |
austin haro wrote: |
Will you see brake fluid on the tires and ground or do you have to pull the drums? |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Sep 01, 2011 4:34 am Post subject: |
If your master is empty or real low, the fluid went somehwhere and you should see evidence of it at the wheels. Since stopping is kind of important, I'd suggest going over your braking system - how old are the flexible lines at the wheels? When was the last time time you did anything to the brakes? It could be a leaking line (metal or rubber), bad wheel cylinder, bad master cylinder - pretty much anything would cause loss of pedal pressure. _________________ D-Dubya Manx clone - 63 Short pan,1914.
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Thu Sep 01, 2011 10:58 am Post subject: |
gottria wrote: |
If any of the parts are in question or old, replace the basics- hardware, cylinders, hoses, shoes. Don't bother Mickey Mousing with the old stuff if it is ancient. Use German hose and new metal lines. Replace drums with new ones if needs be- stick with German or Italian. avoid any others. |
Posted: Thu Oct 27, 2011 7:21 pm Post subject: |
All it needed was brake fluid.....
SOUP721 Samba Member
Joined: October 27, 2011 Posts: 1 Location: LIBERTY, MO
Posted: Fri Oct 28, 2011 8:25 am Post subject: 1960 VW BEETLE |
Hi, I just bought a 1960 VW Beetle and need an Owner's Manual? Any idea where a guy could get one? |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri Oct 28, 2011 8:38 am Post subject: Re: 1960 VW BEETLE |
SOUP721 wrote: |
Try putting a want ad in the classifieds.
Also there are a lot of these things in the samba archives if you are just looking for one you could copy. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri Oct 28, 2011 1:40 pm Post subject: |
slug_bug wrote: |
But the question is why.....If it hasnt been checked for years - then that may be OK - if its that low after a year - then like I said - it's going somewhere........ _________________ D-Dubya Manx clone - 63 Short pan,1914.
